Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
75 registered members (allgm59, 97prizm, Aichiguy, 2010Civic, beanoil, 8 invisible), 1,251 guests, and 62 spiders.
Topics286,216
Posts4,904,436
Members67,579
Most Online2,967
Mar 10th, 2019
0W16 & 5W16 #4659677
02/08/18 06:34 AM
02/08/18 06:34 AM
Cajun Country, La.
BlueOvalFitter Offline OP
Cajun Country, La.
Why haven't I seen these (2) oils in the stores yet? Are there ANY manufacturers engines that spec this oil? If your engine is spec'd 5W20, can this oil be used in said engine?
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659703
02/08/18 07:10 AM
02/08/18 07:10 AM
Murfreesboro, TN
Veilside Offline
Veilside  Offline
Murfreesboro, TN
Newest Toyotas spec this weight.
2011 Hyundai Sonata 2.4 GDI
2011 Toyota Sienna Limited
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659704
02/08/18 07:13 AM
02/08/18 07:13 AM
NY
demarpaint Offline
demarpaint  Offline
NY
It has been discussed here a while back. Unless your engine was specifically designed to run on a 16 grade oil it would not be advisable to use it in an application calling for a 20 grade oil.
God Bless Our Troops
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659715
02/08/18 07:28 AM
02/08/18 07:28 AM
Cajun Country, La.
Cajun Country, La.
I wanted to get more information on these 2 oils so I GOOGLED them. I was surprised to see that there is an 0W8 and an 0W12 engine oil in production as well. As of this reply, it's the first time I have ever heard of these 2 aforementioned oils. I would imagine they are very thin.
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659716
02/08/18 07:28 AM
02/08/18 07:28 AM
Texas
Dallas69 Offline
Dallas69  Offline
Texas
Why would you want to?
You will get no benefit out of this.
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
Re: 0W16 & 5W16 [Re: Dallas69] #4659718
02/08/18 07:33 AM
02/08/18 07:33 AM
Cajun Country, La.
Cajun Country, La.
Have you ever heard of the saying,"Reading is knowledge and knowledge is power!"
I like to be kept updated in certain areas as to use this information in the future if needed. thumbsup
That is okay with you, right?
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659720
02/08/18 07:38 AM
02/08/18 07:38 AM
Pennsylvania
Astro_Guy Offline
Astro_Guy  Offline
Pennsylvania
I wonder if any earlier model year Toyotas will be back spec'd to 0W16? Are there any significant differences between the engines from 2017 to 2018 that would allow for 0w16?
'01 Volvo V70XC, 236k, 10W-30 M1 High Mileage
'16 Accord, 28k, 0W-20 M1 EP
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659728
02/08/18 07:54 AM
02/08/18 07:54 AM
Chattanooga, TN
Spector Offline
Spector  Offline
Chattanooga, TN
I was at Toyota dealer yesterday and noted the 0W16 on shelf. The rep stated that the new Camry spec is the 0W16. I inquired if the engine had changed or just a lower viscosity oil for mileage. He said it was a totally new engine design but could not state whether the XW20 weight would be acceptable. I did not see an owner's manual to see any options.
They had their 0W20 brand of synthetic on sale, 4.99 a quart, not bad for a dealer price.
We did discuss that the 0W16 may make sense in Canada but for TN, the climate is pretty moderate and hot summers so the old discussion of a 0W16 holding up yielding no new thoughts. So, assuming Toyota tested the oil enough to be comfortable in all climates.
The employees had no idea who developed/refined the oil for Toyota and nothing on the bottles either,
Re: 0W16 & 5W16 [Re: Spector] #4659736
02/08/18 08:05 AM
02/08/18 08:05 AM
NY
demarpaint Offline
demarpaint  Offline
NY
IIRC I read somewhere they are using different bearings, perhaps other parts were changed as well. It was designed to run on the "thinner oil." I would not chance that oil in a engine that wasn't designed with that grade of oil in mind. The risk vs. reward doesn't make any sense at all to me.
Re: 0W16 & 5W16 [Re: demarpaint] #4659749
02/08/18 08:22 AM
02/08/18 08:22 AM
Cajun Country, La.
Cajun Country, La.
I would have to agree with you on this. But, I wonder if someone HAS tried it and the results were not so good? ???
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659757
02/08/18 08:40 AM
02/08/18 08:40 AM
Florida
Artem Offline
Artem  Offline
Florida
Lol. I'm sure there have been plenty of your average Turbo Direct injected 4 bangers used for short trips who diluted the 0w20 oil in their sump by 2-3 points down to a 0w18 or so without any catastrophic engine failure. Maybe a pinch more engine wear if any.
I'm sure that oil is loaded with Moly or some other expensive anti wear additive to keep metal to metal contact at bay.
I would be interested in seeing this oil in a 0w20 spec mid 2000s engine. I say it will be just fine... temporarily. LOL
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659806
02/08/18 09:35 AM
02/08/18 09:35 AM
NY
demarpaint Offline
demarpaint  Offline
NY
This is Bitog, if someone hasn't tried it someone will. Stay tuned!!!! wink
Re: 0W16 & 5W16 [Re: demarpaint] #4659822
02/08/18 09:49 AM
02/08/18 09:49 AM
Texas
Dallas69 Offline
Dallas69  Offline
Texas
I wouldn't use it in an engine not specs for it.
And not in anything in the summer in the South.
But maybe someone here will give it a try.
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659850
02/08/18 10:25 AM
02/08/18 10:25 AM
USA
oldhp Offline
oldhp  Offline
USA
Pretty soon MMO will suffice for "thin motor oil" with extra cleaning to boot!!!
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: 0W16 & 5W16 [Re: BlueOvalFitter] #4659852
02/08/18 10:27 AM
02/08/18 10:27 AM
Pennsylvania
grisby Offline
grisby  Offline
Pennsylvania
Advance Auto has the 0w16 here locally (Pennsylvania) in their Carquest brand
72 Buick GS Stage1
2006 Buick Lucerne
2017 Buick Lacrosse
