VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
30 registered members (4WD, A1O, antik, billt460, bfleeman, ctechbob, 4 invisible), 497 guests, and 57 spiders.
Topics286,267
Posts4,905,521
Members67,589
Most Online2,967
Mar 10th, 2019
Motorcraft Synblend 5w30 Flash Point #4656893
02/05/18 01:01 PM
02/05/18 01:01 PM
North Carolina
oilchangeguy Offline OP
North Carolina
The specs on this oil show it only has a 402 degree flash point. Isnt that too low to run in an Ecoboost engine?
2015 Dodge Ram 1500 Quaker State Ultimate/ Mopar Filter
2017 Ford Edge SE Kendall GT1 Syn Blend/ Motorcraft Filter
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4656900
02/05/18 01:12 PM
02/05/18 01:12 PM
Midwest
volk06 Offline
volk06  Offline
Midwest
No.
/end thread.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4656908
02/05/18 01:22 PM
02/05/18 01:22 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
My recent UOA showed a flash point of 385*F after 4,275 miles using Motorcraft 5W-30 in our 2.3 EB engine. Blackstone is indicating it should be >365*F. While the oil sheared to a 20 weight oil the wear metals were fine. Would I trust it to Ford's 10,000 mile iOLM recommendation using the Motorcraft 5W-30, NO, but that's me shrug.
Whimsey
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4656932
02/05/18 01:49 PM
02/05/18 01:49 PM
MA.
Camprunner Offline
Camprunner  Offline
MA.
I have a friend that works for Ford he told me they have now been beating the living tar out of Ecoboost motors on the dyno and in cars and trucks for years. And I'm talking massive abuse! Then they tear them apart and evaluate the wear and look for ways to improve things. They exclusively run Motorcraft oil in several weights depending on the motor. He told me several times there may be better oil out there but on an engine tear down they don't see any reason to change to some other oil. He said to me the wear is quite low in all areas of the motor. There is no reason you can't get several hundred thousand miles running Motorcraft oil in your EB.
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4656939
02/05/18 01:56 PM
02/05/18 01:56 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
If it was too low then the container would state "The flash point of this oil is too low for use in an Ecoboost engine."
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Motorcraft Synblend 5w30 Flash Point [Re: kschachn] #4656944
02/05/18 01:59 PM
02/05/18 01:59 PM
North Carolina
North Carolina
thumbsup
Re: Motorcraft Synblend 5w30 Flash Point [Re: Camprunner] #4656946
02/05/18 02:01 PM
02/05/18 02:01 PM
North Carolina
North Carolina
banana
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4657002
02/05/18 02:50 PM
02/05/18 02:50 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I have to ask what gives you the idea about the flash point ?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4657017
02/05/18 03:05 PM
02/05/18 03:05 PM
North Carolina
North Carolina
if parts of an engine are subjected to extreme heat, one would think you want the temp at which oil ignites to be as high as possible?
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4657233
02/05/18 06:14 PM
02/05/18 06:14 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
No.
don't use.
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4657264
02/05/18 06:49 PM
02/05/18 06:49 PM
USA
slacktide_bitog Offline
USA
The flash point is probably fine, but for a turbo you should use a full synthetic smile
Re: Motorcraft Synblend 5w30 Flash Point [Re: slacktide_bitog] #4657325
02/05/18 07:55 PM
02/05/18 07:55 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
trolling crackmeup
don't use.
Re: Motorcraft Synblend 5w30 Flash Point [Re: oilchangeguy] #4657471
02/05/18 11:00 PM
02/05/18 11:00 PM
Danville, Indiana
IndyFan Offline
IndyFan  Offline
Danville, Indiana
One thing I know is that Ecoboosts don't run well without oil. Mine had a filter installed improperly at a lube shop. (double filter gasket, with one pinched). It pushed all the oil out and then I'm not sure how long it ran. We were able to drive it to the dealer, and it sounded fine. It wasn't. The bearings were turned into beautiful, shiny, sliver sand that filled up the oil filter. The engine and turbos were toast.
It is getting a Ford remanufactured engine, as I type this. It will get what I gave it before. Mobil 1 EP 5w30, with oil changes guided by the OLM, which will be around 10k miles. I just have to make sure it keeps the oil in there.
18 Jeep JLUR Wrangler 3.6 15k
15 Ford Transit 106k, Reman 3.5 @85k
08 Jeep Wrangler 3.8 127k
01 Ford F150 Crew 5.4 90k
99 Mercedes E430 Sport 90k
