Pennzoil - SN Plus and 0W-16 Q&A
Click here to participate in the Pennzoil Q&A
Are v6 engines being over stressed
by littleant
3 minutes 59 seconds ago
Delo 15W30!!
by racin4ds
40 minutes 50 seconds ago
CVT check fluid level or just use specification?
by NoNameJoe
Today at 04:41 AM
46 in mower ok for 2.25 acres?
by MuzzleFlash40
Today at 03:40 AM
Intermittent cold crank, no start 2001 Neon
by heyleescomet
Today at 03:07 AM
+P & +P+ Ammo
by BlueOvalFitter
Today at 03:03 AM
Need turbo exhaust advice
by Dylan1303
Yesterday at 10:51 PM
Out of balance or alignment
by Dohc98vteC
Yesterday at 10:25 PM
2006 Acura TSX ATF D&F
by maverickfhs
Yesterday at 10:11 PM
Just a photo of the '52, while out to eat.
by mrsilv04
Yesterday at 09:31 PM
Turtle Wax Ice--Got a Great Deal at Wally World
by IndyFan
Yesterday at 09:19 PM
7 & 8 speed transmissions
by edwardh1
Yesterday at 08:37 PM
Pennzoil Euro OW-40 - Why Is it Being Clearanced?
by 2015_PSD
Yesterday at 08:34 PM
New Honda vs new Mazda vs used Lexus
by Ddubya
Yesterday at 08:20 PM
Black widow spider “beware close up photo”
by Brolly
Yesterday at 08:15 PM
BMW Coolant Leak Inside Bell Housing
by kschachn
Yesterday at 07:59 PM
Health Care Nightmare
by Bluestream
Yesterday at 07:58 PM
2.4 Ecotec DI
by mobilaltima
Yesterday at 07:57 PM
Prestone may have discontinued Honda PS fluid
by slacktide_bitog
Yesterday at 07:45 PM
2002 Lincoln Continental
by Kira
Yesterday at 06:31 PM
4M41V5AWF, berg, TheLawnRanger, JeffThePilot, RoadBully
64502 Registered Users
83 registered (94astro, -SyN-, Bailes1992, 2009Edge, 4WD, 6 invisible), 1308 Guests and 122 Spiders online.
64502 Members
68 Forums
280049 Topics
#4647893 - 01/27/18 10:30 AM Anyone use Muriatic Acid?
Dobbie Offline
Loc: Chester County/Pa.
Its a beautiful day here today in my parts. Supposed to get up to 57 degrees & im looking forward to cleaning the brick on my one side of my house. The white siding has bled some down onto the brick & am wondering how muriatic acid would work mixing with water at the recommended parts to scrub/clean the brick?
#4647906 - 01/27/18 10:39 AM Re: Anyone use Muriatic Acid? [Re: Dobbie]
Leo99 Offline
Loc: NJ
Safety is no accident
Edited by Leo99 (01/27/18 10:39 AM)
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 333,000 miles
2015 Camry 40,000 miles
#4647907 - 01/27/18 10:40 AM Re: Anyone use Muriatic Acid? [Re: Dobbie]
Linctex Offline
Loc: Waco, TX
Have you tried just a power washer first? That usually does the trick.
It needs to be diluted a fair bit.
Try 3% or 5% at first, you can always add more acid as needed to strengthen it.
#4647927 - 01/27/18 11:15 AM Re: Anyone use Muriatic Acid? [Re: Dobbie]
oldhp Offline
Loc: USA
I used this back when I laid brick. Approx 16oz per 4gal in a 5 gal bucket. You can always do it twice......but you only burn it once. GOGGLES are a must!!!!! Have somebody back you up. Have fresh water on hand if you get it on you OR in your eyes. This is not something to take lightly.
#4647933 - 01/27/18 11:19 AM Re: Anyone use Muriatic Acid? [Re: Dobbie]
Dobbie Offline
I have tired power washing with a good cleaner to no prevail. Thats why I was wondering about going the muriatic acid route??
#4647952 - 01/27/18 11:46 AM Re: Anyone use Muriatic Acid? [Re: Dobbie]
3800Series Offline
Loc: Gulf Coast, MS
1 gallon too 5 gallons don't waste your time using less I've handled this stuff for 30+ years (many times bear handed). It's not until you get to the 1-2 and 1-1 can it really effect you.
#4647960 - 01/27/18 11:58 AM Re: Anyone use Muriatic Acid? [Re: Dobbie]
Delta Offline
Loc: South Central PA
Used to use it when I had the old house with the inground pool for PH control. Also use it for cleaning bare concrete before painting, usually a quart to a couple gallons.
'17 VW Golf GTI 2.0T - 6MT - 5K
'15 Camry SE - 2.5 - 18K
'12 Jeep Liberty 4x4 3.7 - 86k
'99 S10 - 2.2 5MT - 152K
#4647991 - 01/27/18 12:42 PM Re: Anyone use Muriatic Acid? [Re: Dobbie]
Pajero Offline
Loc: Rio Rancho, NM
Poured it on my driveway once (young dumb) and started scrubbing. Not for long. I didn't dilute it and was overcome by burning in the lungs. Never did that again. It works well. Read the directions carefully. Very strong acid.
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 128,xxx
Fram Ultra/ Snorkel with Pre-filter
#4648064 - 01/27/18 02:30 PM Re: Anyone use Muriatic Acid? [Re: Dobbie]
slowrench Offline
Loc: california
Im wondering exactly what bled onto brick.Maybe test a spot(3 parts water,1 part acid MAX).Ive only used muratic acid on stains caused by mortar,concrete or thinset,after the building process.
#4648167 - 01/27/18 04:32 PM Re: Anyone use Muriatic Acid? [Re: Dobbie]
jackz Offline
Loc: Cape Coral Fl.
Don't use that their are other acids check at Lowes or Home Depot It will work slower but much safer. I pressure cleaned over 20 years and muriatic acid is not safe to use even the smallest wind shift and you will not be able to breath . I use it in my swimming pool only for balance.
#4648608 - 01/28/18 04:43 AM Re: Anyone use Muriatic Acid? [Re: Dobbie]
jakewells Offline
Loc: Cave City KY
i use it to clean the aluminum transfer off crankshafts and cylinders when rebuilding engines.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 Fram XG8A
