windows 10 - list of available printers
Near the beach in Delaware
When I do into an application like Chrome I see a couple of Xerox Phaser printers. I only have one Xerox Phaser printers. I have tried and installed the Xerox Phaser a few times. Under Settings --> Printers I see only one Xerox Phaser printer.
How do I get rid of the extra printers that show up in a application I want to print from?
Go into the Printers & Scanners settings in the control panel and there should be a list of printers, click on the printer you want to remove and options should appear under it and select Remove Device
My point is under the settings --> printers the proper printers show up. Under the list when I click Print in an application is a list that includes printers I installed and removed (and the correct ones).
