Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
87 registered members (2009Edge, ABomb369, aquariuscsm, AndyB, 4WD, 7 invisible), 1,418 guests, and 34 spiders.
Topics295,209
Posts4,929,980
Members66,711
Most Online2,553
Oct 27th, 2018
Engine teardown with weight comparison? #4639926
01/19/18 12:59 PM
01/19/18 12:59 PM
Delco, PA
BullittGT Offline OP
Delco, PA
Hi. I think this may be the best sub to ask in.
I know it's probably unlikely, but has anyone ever done comparisons of engines that have similar miles that have run different weight oils? For example 3 taxies that went into service in the similar time that ran with 5w-20, 5w-30 and 5w-40 oil in them for their lifetime and compared later to see the wear differences?
Hoping for a 2019/2020 Mustang BULLITT
Current: 2018 Q50 Red Sport 400 AWD
Re: Engine teardown with weight comparison? [Re: BullittGT] #4639927
01/19/18 01:04 PM
01/19/18 01:04 PM
CA, USA
paulri Offline
paulri  Offline
CA, USA
I remember one poster here saying that he worked at a Ford shop (or was he doing training?), and they tore down engines that were running 5w30, and also the newer ones with 5w20. He said that they looked the same, but that the 5w20 ones were cleaner around the pistons.
I'll try to find that thread. Wish me luck. smile
2005 Toyota Sienna LE; 156,000 miles
1998 Honda Civic DX; 202,000 miles
Re: Engine teardown with weight comparison? [Re: BullittGT] #4639933
01/19/18 01:09 PM
01/19/18 01:09 PM
Tennessee, United States
ZraHamilton Offline
ZraHamilton  Offline
Another thing to consider would be fuel economy. It would be hard to find an average fuel economy for an engine's entire life though.
Re: Engine teardown with weight comparison? [Re: BullittGT] #4639939
01/19/18 01:12 PM
01/19/18 01:12 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
The sample size isn't large enough or controlled enough, usually; you need fleet data.
Best source of readily (web) available data would be public utilities like maybe a State School Bus or Police fleet or (if you can find it) military sources. They do these kinds of things from time to time, and they will have cost-benefit data to go with it, which is what you really want.
There are almost certainly other sources, but the problem is getting the data from private sources, whom might see it as competitive-restricted or proprietary information.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Engine teardown with weight comparison? [Re: ZraHamilton] #4639940
01/19/18 01:13 PM
01/19/18 01:13 PM
Delco, PA
Delco, PA
I'm sure this will matter to some people, but my main thought is on the long term protection. I don't mind paying a bit more for fuel if it means a little more peace of mind, even if it is only a small amount of peace.
Re: Engine teardown with weight comparison? [Re: BullittGT] #4639968
01/19/18 01:34 PM
01/19/18 01:34 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
I'm disappointed with the amount of data out there. Surely there must be police garages, or taxi garages that have tried long term tests using different oils. Also, you would think there would be more info from our Universities and colleges. Just downright disappointing.
If you want the job done right......do it yourself.
Re: Engine teardown with weight comparison? [Re: BullittGT] #4639973
01/19/18 01:38 PM
01/19/18 01:38 PM
CA, USA
paulri Offline
paulri  Offline
CA, USA
For what its worth, in the mid 90s, Toyota did some testing with oils that had an HTHS equal to 20 and 30 weight, and found that the 20 weight oils recorded fairly equal engine wear (this was oils with an HTHS of 2.6 and 3.1). They even threw in an oil with 2.4 HTHS and found that in most of their tests, even that oil did well. Unfortunately the text was in Japanese, but the charts showed the results.
Try this link: https://www.beamium.com/v/ZVYVMTDM
The site takes a while to upload the next page when you click on the right arrow, but it does go from one page to the next.
Re: Engine teardown with weight comparison? [Re: BullittGT] #4640035
01/19/18 02:24 PM
01/19/18 02:24 PM
MN
oil_film_movies Offline
MN
BullittGT: Deposit on a Bullit I see. Awesome. Best looking machine.
It does depend on the engine model. Recommended weight in the Owner's Manual is what the engineers know will pass their durability testing, and thats plenty.
The more surface area and the less loading on bearings governs how viscous the oil has to be to provide a non-zero thick oil film. So its engine design as much as anything that governs the question.
5w20 (or 0w20) is all a lot of engines need. I would go up to a 5w30 on an xw20-spec engine if towing or racing in hot weather just to be sure it doesn't thin too much.
Push the video slider to the 1:44 point to see how a 5w20 does very well in a Ford 4.6L engine:
Re: Engine teardown with weight comparison? [Re: oil_film_movies] #4640070
01/19/18 02:56 PM
01/19/18 02:56 PM
US
JLTD Offline
JLTD  Offline
US
I don't know that I can agree on the part part of your post bolded in italics above; I recall reading on here somewhere that the oil recommendation in the owner's manual is required to be the oil used for CAFE figures, and ONLY the oil grade used for those figures. Seems to me if that's what the government is requiring, then the engineers no longer write the manual in that respect.
edit: there's also a video of the Schaeffer Oil 1,000,000 mile van engine teardown:
https://www.youtube.com/watch?v=hDF1zcaxrNU
That engine was super clean and showed no measurable wear either.
I emailed the company (Schaeffer) awhile back, they said that they had used 15w40 diesel oil in the Ford 5.4L gas V8.
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 41k, OE 5w30/Wix
Re: Engine teardown with weight comparison? [Re: paulri] #4640186
01/19/18 04:19 PM
01/19/18 04:19 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Is he suggesting that the straighter oil resulted in cleaner rings? I'm shocked.
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
Re: Engine teardown with weight comparison? [Re: BullittGT] #4640199
01/19/18 04:29 PM
01/19/18 04:29 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Consumer Reports did this 10 or 15 years ago.
2015 Ford F250 w/Powerstroke
Re: Engine teardown with weight comparison? [Re: JLTD] #4640232
01/19/18 04:55 PM
01/19/18 04:55 PM
MN
MN
The EPA (CAFE people) have never required the use of xw20 oils.
The automakers have turned to xw20 oils to get about 1% better fuel economy compared to using xw30 oils, and that does count on the EPA FTP MPG CAFE.
Note its the automakers choice to use xw20 to get 1% better CAFE. They didn't have to do it. Never forced to.
That said, the engineers have been designing engines to keep the Stribeck Curve in the same or similar position by making the bearing surfaces larger to accomodate xw20 oils. Durability remains the same or similar.
It is true engines spec'ed to xw20 will run just fine on xw30 oil, with a small MPG penalty. Automakers do perform durability testing to be confident xw20 oils aren't too thin to sacrifice durability.
Re: Engine teardown with weight comparison? [Re: BullittGT] #4640261
01/19/18 05:18 PM
01/19/18 05:18 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
ExxonMobil owns fleets of Taxis in Las Vegas and many other cities. That's where they do their testing.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Engine teardown with weight comparison? [Re: BullittGT] #4640475
01/19/18 08:58 PM
01/19/18 08:58 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
All else being equal, operating viscosity matters for components protection. It's physics.
Quote:
Abstract of Toyota research says:
Lowering the viscosity of engine oil is effectice in reducing the fluid friction.
However, it decreases the oil film thickness, and causes the increase in the wear of the engine parts.
But does it matter to others, that's a different issue altogether.
Re: Engine teardown with weight comparison? [Re: zeng] #4640495
01/19/18 09:21 PM
01/19/18 09:21 PM
CA, USA
paulri Offline
paulri  Offline
CA, USA
The sentence you quoted is followed by another, that summarizes the findings:
Through the engine wear tests using an [sic] radioisotope tracer technique, it was clarified that an HTHS viscosity of 2.6 mPa-s was the lower limit to prevent the increasing wear.
