Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
89 registered members (Astro14, ABomb369, 94astro, 28oz, 64bawagon, 7 invisible), 1,617 guests, and 45 spiders.
Topics290,635
Posts4,847,780
Members66,011
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Car suddenly starts running rough and has no power #4639321
01/18/18 10:21 PM
01/18/18 10:21 PM
southwest Mo.
wtd Offline OP
wtd  Offline OP
southwest Mo.
This is on my 92 Cavalier with the 2.2L/auto with around 225,400 miles on it.
Today I headed out to go to Walmart which is about 3 miles from the house. The car starts and runs normally until I stop at a stop light that is only a few blocks from the store. The idle suddenly drops and the car acts like it's going to die and the engine is running very rough.
When the light turns green, I turn toward the store and the car has no power and is still running very rough. I get to the parking lot and park. I rev the engine a little bit and it sounds funny through the exhaust. I go feel the exhaust and it is coming out strong but is very hot and it's kind of popping. I pop the hood and the engine is shaking very badly and it sounds rough but it doesn't really sound like it's missing.
I do my shopping and head home and the car barely has any power but it does finally get up to about 55 mph. I finally get it home.
The CEL never came on. My initial thought with the power loss was that my Catalytic converter clogged up or something but with the exhaust coming out so strong, I'm not sure about that anymore. I had the original converter replaced at about 77,000 miles so the replacement has some miles on it.
Does anyone have any ideas what else to check? The plugs only have about 16,000 miles on them. Muffler only has about 20,000 miles on it. Fuel filter has less than 2,000 miles on it. I put in re-manufactured fuel injectors and a new fuel pressure regulator at around 130,700 miles. Pretty much all of the sensors have been replaced over the years. The car had 76,600 miles on it when I bought it.
Thanks for any ideas on what could have caused this all of a sudden.
Wayne
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639326
01/18/18 10:26 PM
01/18/18 10:26 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Even though you said it doesn't sound like it's missing, the symptoms sure sound like it's running on 3 cylinders and a misfire won't set a CEL on pre-OBD2 vehicles. How old are the wires?
2018 Challenger SRT
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639329
01/18/18 10:28 PM
01/18/18 10:28 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
do a dry and wet compression test
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639337
01/18/18 10:43 PM
01/18/18 10:43 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Wonder if it has water in the gas.
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639339
01/18/18 10:44 PM
01/18/18 10:44 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Check Fuel Pressure first! Is it TBI or MPI?
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639365
01/18/18 11:01 PM
01/18/18 11:01 PM
Massachusetts
VeryNoisyPoet Offline
Massachusetts
Compression test is a good idea, but a basic power balance test doesn't involve undoing spark plugs and is a good first step. Unplug one fuel injector at a time. If the rough idle gets worse or the engine stalls, that cylinder is producing power. Plug the first injector back in and unplug the next injector. If the idle does not change when an injector is unplugged, you have found your dead cylinder.
Check for spark at each of the plug wires. Remove wire from plug with engine off, prop wire end near the frame or block, and crank engine. Investigate if you get no spark or weak spark.
If you have an infrared thermometer, when the engine is warmed up, see if the pipe after the catalytic converter is super hot at idle compared to the pipe ahead of it. That suggests lots of unburned fuel getting into the exhaust, which could explain unusually hot exhaust you felt. In extreme cases, the cat and the pipe downstream can glow red.
1998 V70 GLT / 192k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639374
01/18/18 11:09 PM
01/18/18 11:09 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
This is just a TBI motor so I'm doubting it's on the fuel side, my money is on secondary ignition. Possible bad head gasket considering the mileage, but OP didn't mention it overheating recently.
2018 Challenger SRT
Re: Car suddenly starts running rough and has no power [Re: dishdude] #4639376
01/18/18 11:13 PM
01/18/18 11:13 PM
Massachusetts
Massachusetts
Interesting. Wikipedia claims '92 was when they introduced multiport on the 2.2, but that can always be wrong info. Up to the OP to let us know what is the case on this car.
"Use yah blinkah!"
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639377
01/18/18 11:14 PM
01/18/18 11:14 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Sounds like a ruptured/failed diaphragm in the fuel pressure regulator
Re: Car suddenly starts running rough and has no power [Re: VeryNoisyPoet] #4639378
01/18/18 11:15 PM
01/18/18 11:15 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
I guess I could be a year off. smile
2018 Challenger SRT
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639379
01/18/18 11:16 PM
01/18/18 11:16 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
TBI fuel pressure regulator tips:
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639380
01/18/18 11:18 PM
01/18/18 11:18 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
You're going to need a spark tester, a fuel pressure tester, an exhaust back pressure tester, and a compression tester.
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639384
01/18/18 11:20 PM
01/18/18 11:20 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639449
01/19/18 12:26 AM
01/19/18 12:26 AM
southwest Mo.
wtd Offline OP
wtd  Offline OP
southwest Mo.
I installed new plug wires when the car had 130,400 miles on the car so they have roughly 95,000 miles on them.
This car has four individual injectors on it. The injectors are almost impossible to get to with the intake manifold in place and I don't believe that I can unplug the wiring to them to see if the car runs any different with them unplugged one at a time.
Car has never overheated and the head gasket was replaced when the car had 82,500 miles on it. I will check the condition of the oil tomorrow to see if it looks like any water is in it.
This engine has no distributor and uses an Ignition Control Module and two coils. The ICM was replaced at 130,100 miles and the two coils at 126,600 miles. I do have a spark tester so I will use it to see if I'm getting fire to all cylinders.
I did do a wet and dry compression test several years ago but I don't remember the mileage on the car at the time. One cylinder was a little low but still within normal range.
I have all of the testers mentioned above except the back pressure tester but there is no fuel pressure port and If I remember correctly, you have to have some special setup to test fuel pressure on this car. Fuel pump is original as far as I know.
I do have an infrared thermometer so I will check readings before and after the cat.
Thanks for all of the replies and I will try testing the things that were suggested.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Car suddenly starts running rough and has no power [Re: wtd] #4639472
01/19/18 01:47 AM
01/19/18 01:47 AM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Pull one spark plug wire at a time and see if it changes how it runs.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Page 1 of 3 1 2 3
