If you have an exposed exhaust manifold take an IR thermometer and aim it at the exhaust manifold flange of each cyl close to the head right after cold start, if one is cooler than the others that's the one you need to look at.
This works best on steel and tube style manifolds but if there is a little separation it also works fine on iron. I would guess secondary ignition issues that may possibly have now overheated and damaged the cat.
Meaning if you find the root cause was not cat related a new cat may be in your future anyway.
