VIRGIN ST2 STP FILTER CUT OPEN
by 53' Stude. 09/19/18 05:08 PM
Chrysler HOAT at 9 years...
by burla. 09/19/18 04:34 PM
Septic Tank pumping question
by wormwood1978. 09/19/18 03:46 PM
A5/B5 or A3/B3
by ka9mnx. 09/19/18 03:27 PM
LingLong
by sloinker. 09/19/18 02:42 PM
2018 Grand Caravan review
by tiger862. 09/19/18 02:39 PM
Diagnosing gas furnace
by Oro_O. 09/19/18 01:16 PM
Let's talk dipsticks and oil capacity
by csandste. 09/19/18 12:32 PM
Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
Alday714, Joephoto, tlelectric, sandin67, paigemoody547
66019 Registered Users
86 registered members (2009Edge, Ablebody, 53' Stude, ABomb369, ad244, ArrestMeRedZ, 7 invisible), 1,399 guests, and 31 spiders.
Topics290,676
Posts4,848,181
Members66,019
Most Online3,590
Jan 24th, 2017
5w-20 in Ford 4.0 for 80,000 miles. #4636527
01/16/18 11:05 AM
01/16/18 11:05 AM
Vermont
littleant Offline OP
Vermont
Ran into an older gentleman (older then me) at the hardware store and I commented on his 2010 Ford explorer with the 4.0. The vehicle was in great shape with 80,000 miles. He took in in for service Yesterday to the dealer where he purchased. He goes to the dealer for all his work and has all service records. I asked him what oil he use's and he said whatever they put in. He showed me the invoice and the service record printout and it showed XO5W20BSP.
They have been using this oil I believe its bulk 5w-20 synthetic blend since new. Then I opened my mouth and said I believe that is the incorrect oil. It should be 5w-30. He said he believes the dealer knows what they are doing. Told him to check his manual. He did and it said 5w30. He said he was going back to question them (we know what they are going to say). The engine sounded great no noise. He serviced it every 3,000 to 4,000 miles with filter change. I told him to hold on to his service reecords. I know ford sent out a tsb in 2001 changing what oil to use in certain engine's but the 4.0 stayed the same.
Is Is it possible ford corrected the issue that they had with the 4.0 (oil pump? they had 9 years to do it) and changed the oil specifications or added 5w20. These engines have had the timming chain issue back in 97-05?. Do you think any damage was done to his engine. I ask because the guy seemed worried. Would you have brought it to someone's attention? I would think if any damage was done to the engine it would have happened already. Your thoughts.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636536
01/16/18 11:14 AM
01/16/18 11:14 AM
Michigan
khittner Offline
khittner  Offline
Michigan
If his 8yr-old engine has gone this far, and lasted this long on the "wrong oil", how wrong could it really be?
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636546
01/16/18 11:23 AM
01/16/18 11:23 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
My son in law has three Merc Benz and uses reg M1 5-30 in all of them, which two are Diesels and one is the SL 500. I mentioned to him that reg 5-30 M1 wasn't the correct spec but he wasn't concerned. Results: All three engines are performing great. Go figure.
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636547
01/16/18 11:24 AM
01/16/18 11:24 AM
Guilford, CT
exranger06 Online confused
exranger06  Online Confused
Guilford, CT
Ford NEVER back-spec'd 5w20 for this engine. They recommended 5w30 right up until this engine went out of production in 2011. There must've been a reason for it. I would never use 5w20 in mine.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636549
01/16/18 11:28 AM
01/16/18 11:28 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
If he was towing at max capacity, I could see having an issue with too thin an oil, but for general retired guy driving, I'm sure the 5W20 was fine, perhaps even preferable if the oil never really got heated up?
07 Focus ZXW, 5spd manual, 210km M1 5W30
18 Outback 2.5 CVT 10km 0W20 "bulk subaru" whatever that is
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636553
01/16/18 11:30 AM
01/16/18 11:30 AM
NE Ohio
Ifixyawata Offline
Ifixyawata  Offline
NE Ohio
Maybe not the newer iterations but I know the earlier 3rd gen Explorers liked to eat timing chains/guides and as such stuck with 5w-30. The whole timing chain issue was why I insisted on a 4.6 while shopping for my Mountaineer.
2004 Mercury Mountaineer 4.6 M1 High Mileage 10w-40 (Summer)
2001 Ford Focus 2.0 Zetec Pennzoil Euro L 5w-30
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636566
01/16/18 11:44 AM
01/16/18 11:44 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
3000-4000 mi OCI would likely have [email protected]*C shears a Ford blend 5W20 to 7.5-8 cSt.
It's weakest link is probably timing chain wear.
It's saving grace would be short OCI, short tripping, daily driver , cool or cold ambients,no high load/high temperature driving, blend has a tiny bit of Mo etc.
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636622
01/16/18 12:47 PM
01/16/18 12:47 PM
Vermont
Vermont
Thanks guys. I put him at 70-75. He's Been to Florida 2 times and California 1 time. Probably Had the vehicle serviced in both states. He is set in 3-4,000 OCI. Why do so many folks have so much confidence in the dealers. What ticks me off is they have all the ford info at their finger tips and are either to lazy or stup## to use it. How is it when taking off the fill cap and seeing 5w30 don't they get.
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636671
01/16/18 01:40 PM
01/16/18 01:40 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Is him trusting his Ford dealer really any different than most guys here thinking they know better and using oil different than factory spec?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636705
01/16/18 02:07 PM
01/16/18 02:07 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Just wondering, is SN 5w-20 better than SL/SJ 5w-30?
Being a 2010, it was probably designed for SL/SJ oils (SM did not come out till 2010).
So is the thinner (and probably more shear stable) SM/SN 5w-20 oil really that bad compared to the thicker SL/SJ 5w-30 oil?
AS said, it has gotten the vehicle to where it is with no apparent issues.
1994 Honda VT1100: Peak 15w-40/PSL/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636747
01/16/18 02:39 PM
01/16/18 02:39 PM
Wisconsin
Black_Thunder Offline
Wisconsin
did he show you a receipt for every oil change?
It might have just been a one time screw up.
either way i'm sure it'll be fine.
I'd buy Callahan autoparts if I could.
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: AZjeff] #4636765
01/16/18 02:56 PM
01/16/18 02:56 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Agreed. The manufacturers oil specs and change requirements are always the best choice for long life...We've never seen any manufacturers change requirements.....AND we've never seen any sort of preventable failure when serviced according to manufacturers requirements....
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636814
01/16/18 03:29 PM
01/16/18 03:29 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
There was a guy here that would have said he is running exactly the right oil with xw20. Given the location and probable operating conditions its probably no worse for wear and tear. From your description I would be surprised if this engine ever really got the oil up to operating temps and over 2500 RPM.
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: Ifixyawata] #4636840
01/16/18 03:52 PM
01/16/18 03:52 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: Ifixyawata
...but I know the earlier 3rd gen Explorers liked to eat timing chains/guides and as such stuck with 5w-30.
^^^ THIS
Those late model 4.0 's are REALLY REALLY REALLY difficult to do the chains on, also!!
Re: 5w-20 in Ford 4.0 for 80,000 miles. [Re: littleant] #4636861
01/16/18 04:13 PM
01/16/18 04:13 PM
Lake County, Ohio
ls973800 Offline
ls973800  Offline
Lake County, Ohio
Wow, you must live in a world where if someone else does something you don't like, you get all bent out of shape. It's his truck, he's happy having the work done by the dealer, and he hasn't had any problems from what you said.
There are many people on this forum who use something different than what may be recommended by the manufacturer or the oil cap marking, or the owner's manual. Are they all stupid or too lazy also? Do they tick you off also? Can't they be allowed to do what they want with their own vehicles without you posting your rant or getting ticked off?
New flash, not all dealers are "stealer ships". Many people have confidence having their vehicles worked on and maintained by dealers. It's their choice again, not yours.
