OVERKILL
$100 Site Donor 2021
At work we have a transport van for carpooling that often gets driven into the GTA. It's a 2011 Chevrolet Express that's been outfitted by Explorer Vans, so its well equipped.
It has the obnoxious windshield sprayers that are on the wiper arms which seem to always freeze up in the winter requiring either a trip to a car wash to defrost, or bringing it inside. Even using -40C rated washer fluid, it seems that if the van sits for a bit, the alcohol evaporates and the lines freeze, and because they are exposed above the hood, they do not get warmed up by engine heat, so they stay frozen.
This is not a minor annoyance, it's a rather major one and a potential safety issue because invariably nobody checks the thing to see if they work before leaving and if you are out on the 401 and they've been spraying the highway, your windshield soon gets coated and not being able to clean it becomes a serious problem at that juncture.
What the heck happened to the standard practice of putting the bloody things on the hood or in the cowl where the engine heat can defrost them in the event they freeze? I've literally NEVER had this problem on any vehicle I've ever owned but it is a persistent issue not only on this van, but also on our 5-ton straight trucks (Freightliner) which also have this "feature"
That's my rant for today as I was riding in it this weekend due to a job we had in the GTA and as soon as the temperature dropped on Friday night, they ceased to work for the entire weekend. Whoever designed this system without heated nozzles or some other mitigation technique needs a serious slap upside the head.
