Pennzoil - SN Plus and 0W-16 Q&A
Click here to participate in the Pennzoil Q&A
Easter Oil Sales - Australia
by B320i
03/20/18 02:10 AM
Full cases (12 ct) of ACDelco Oil Filters for $4-7
by Oneill5491
03/20/18 12:40 AM
Springfield XD MOD.2. vs XD(M)
by lukejo
03/19/18 10:55 PM
Slight Oil Overfill
by TheLawnRanger
03/19/18 10:18 PM
SuperTech White Can for $1?
by RonRonnster
03/19/18 10:16 PM
Pennzoil High Mileage Platinum 0w20 @ 63k Miles?
by David2431
03/19/18 09:39 PM
Duracell auto battery
by oilstudent24
03/19/18 09:20 PM
Low oil pressure code when following the olm
by ram_man
03/19/18 08:04 PM
by car51
03/19/18 08:03 PM
2015 Honda Pilot Idle Learn Procedure?
by Dave Sherman
03/19/18 07:54 PM
Wad cutter shooting
by CourierDriver
03/19/18 07:39 PM
Generator Maintenance
by doolah02
03/19/18 07:38 PM
When to tighten control arm bolts?
by dlundblad
03/19/18 07:25 PM
Super cool vid
by Jake777
03/19/18 07:19 PM
Meijer clearance of Puro Boss: 75% off
by fdcg27
03/19/18 07:10 PM
Trouble Pairing Phones On New Toyota Camry
by billt460
03/19/18 07:08 PM
Headlamps on a Poulan riding mower
by 92saturnsl2
03/19/18 06:40 PM
Diff fluid OCI in 2018 Chevy 2500HD Duramax
by oliver88
03/19/18 06:29 PM
How long do digital units stay in spec?
by Hemispheres
03/19/18 06:02 PM
Repair manual sources - 2015 Corolla
by NissanMaxima
03/19/18 06:01 PM
TroubledGnom, TwoMile, mbres2000, The_Griz, mcclusk
64507 Registered Users
14 registered (crainholio, B320i, DejaVue, Char Baby, 4 invisible), 793 Guests and 146 Spiders online.
64507 Members
68 Forums
280095 Topics
Page 1 of 2 1 2 >
#4629855 - 01/09/18 10:11 PM Which is a good oil extractor?
lukejo Offline
Loc: IL
Looking for advice on a good oil extractor (through the dipstick tube). I assume an electric is better than a manual pump. Good recommendations?
#4629857 - 01/09/18 10:15 PM Re: Which is a good oil extractor? [Re: lukejo]
FermeLaPorte Offline
Loc: Texas (south)
I'll go for a cheap one
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
#4629860 - 01/09/18 10:19 PM Re: Which is a good oil extractor? [Re: lukejo]
Ben Boyle Offline
Loc: Michigan
#4629865 - 01/09/18 10:25 PM Re: Which is a good oil extractor? [Re: lukejo]
UncleDave Offline
Loc: Ca.
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
#4629873 - 01/09/18 10:36 PM Re: Which is a good oil extractor? [Re: lukejo]
redbone3 Offline
Loc: Reno, NV
From the reviews I have seen the "Topsider" is tops:
2014 Passat Wolfsburg, 1995 Miata.
#4629874 - 01/09/18 10:38 PM Re: Which is a good oil extractor? [Re: lukejo]
TMoto Offline
Loc: CO
+1 for MItyvac, I like my MV7201.
#4629876 - 01/09/18 10:39 PM Re: Which is a good oil extractor? [Re: lukejo]
CharlieBauer Offline
Loc: CA
I have a Mityvac and I like it.
But in retrospect, first I would have gone for a cheap electric or even hand pump without a reservoir that would put the used oil directly into the container that goes for recycling.
Where the Mityvac has come in useful is when I remove ATF, I can see the exact amount removed and put that back in.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
#4629880 - 01/09/18 10:45 PM Re: Which is a good oil extractor? [Re: lukejo]
tomcat27 Offline
Loc: Chicago, IL
I've had a topsider and now a Tempo (which looks alot like the mightyvac)
The Tempo has lasted longer; but I'm sure both are fine.
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
#4629886 - 01/09/18 10:51 PM Re: Which is a good oil extractor? [Re: Ben Boyle]
Pajero Offline
Loc: Rio Rancho, NM
That is kinda neat! Thanks for posting Ben Boyle.
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 128,xxx
Fram Ultra/ Snorkel with Pre-filter
#4629899 - 01/09/18 11:16 PM Re: Which is a good oil extractor? [Re: lukejo]
Danno Offline
Loc: Northern Ontario, Canada
I use this one, works great. Price is right too.
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
#4629927 - 01/10/18 12:25 AM Re: Which is a good oil extractor? [Re: lukejo]
PimTac Offline
Loc: Soviet State of Washington
Iíve been looking at these as well. Is there any real difference between the Mityvac 7400 and 7201? Size obviously but the 7201 has the pump separate from the tank.
2017 Mazda CX-5 GT. Idemitsu 0w-20 factory fill. Factory Denso filter.
#4629950 - 01/10/18 02:31 AM Re: Which is a good oil extractor? [Re: lukejo]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Have several of the large HFT units and love them.
For pumping directly into a container, I have had fantastic experience using the "orange pump" hand pump kit you find under a million brands at a million places.
Using the little black hose, it will suck 8 hot quarts out of a 454 with surprisingly few pumps. Trick is to give it time to fill with oil on the suction stroke. Removes a lot of oil with each pump.
#4629973 - 01/10/18 04:35 AM Re: Which is a good oil extractor? [Re: lukejo]
Oldtom Offline
Loc: Maryland
Another vote for the Topsider. I use mine to pull trans fluid out of my Dodge Caravan and changing oil in mowers. The Topsider has several small gaskets that must be in place to work. I tend to lose things, so, I keep all small parts in a ziplock bag stored with the Topsider.
#4629998 - 01/10/18 06:11 AM Re: Which is a good oil extractor? [Re: lukejo]
demarpaint Offline
Loc: NY
Another vote for the Mity-Vac.
God Bless Our Troops
#4630007 - 01/10/18 06:30 AM Re: Which is a good oil extractor? [Re: lukejo]
Virtus_Probi Offline
Loc: New England
Bought this one on sale from Pep Boys for about $50.
I'm sure an electric pump would work faster, but this one works quickly enough for me. I like the 6l reservoir because my used oil is going to go into the container for the new oil and I need to have a temporary spot for it. I think the person who complained in the reviews about it only holding 4 quarts must have had a different unit, mine holds the ~5.4 quarts of oil from the FXT with room to spare. Also like the gradations on the reservoir to let me see just how much I've sucked out.
2014 Forester XT, 75300 miles
Last Change;
Pennzoil Gold 5W30 d1G2
Tokyo Roki 15208AA170 filter
Page 1 of 2 1 2 >
