Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
France F1 Grand Prix
by DeepFriar
06/21/18 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
06/21/18 03:16 PM
Best additive in oil to clean sludge?
by ffgb
06/21/18 02:19 PM
Who is a Dirt Track regular?
by thooks
06/21/18 01:39 PM
ZEK, Dudewayne, kmdz, harborbirds, frascati
65292 Registered Users
23 registered (dishdude, buffalobob, bmod305, Char Baby, David_g, 2 invisible), 453 Guests and 29 Spiders online.
65292 Members
67 Forums
285749 Topics
Page 1 of 2 1 2 >
#4626501 - 01/06/18 11:10 PM Car using oil on long trips?
Jack2468 Offline
Loc: SC
My 98 Towncar seeks to be using oil on long trips.
I changed to Castrol Edge 5W30 with MC FL-820s and immediately took the car on a long (16 hr) trip. Had to add more than half a quart half way through the trip and another 1/2 qt after the trip was done. Then, after getting back and driving my normal amount and finishing out the OCI, it never used another drop.
I changed it again, using the same Edge and 820s as I used before, drove around about 500 miles of normal commuting without using any oil. Then took it on a 1000 mile trip somewhere and it used 3/4 qt on the way there. Drive it another 1000 back and it used a whole quart. After getting back, I put another 1000+ miles on the car doing normal driving and commuting and it didn't use any at all.
My daily commute is about 20 miles each way, taking 20 mins to get to work in the morning and about 45 mins (with traffic) on the way home. The Lincoln does not seem to use any oil in my normal commute, but if I take it on an extended road trip (6-8+ hours), it uses at least 1/2 to 1+ quart of oil. A shorter (roughly 3 hrs) road trip it will not use oil. There are no leaks under the car. Engine runs great, no smoke or oily burning smell from exhaust.
I just changed the oil again, this time using Mobil1 to see if it makes a difference. I know these 4.6 engines are known to have the valve stem seals wear when they get up there in mileage, but wouldn't it use oil all the time if that was the case? This thing only uses any on really long drives and never any on local or shorter trip driving. What do you all think would be causing this?
2017 Ford Focus ST (8200 miles)
- Pennzoil Platinum 5W-30
- MC FL-910S
1998 Lincoln Town Car (128,000 miles)
- Mobil1 5W-30
- MC FL-820S
#4626502 - 01/06/18 11:13 PM Re: Car using oil on long trips? [Re: Jack2468]
Run Offline
Loc: Canada
Replace PCV valve.
03 Neon 2.0 - VSP 5W-30 Pentius XL
#4626513 - 01/06/18 11:29 PM Re: Car using oil on long trips? [Re: Jack2468]
BrocLuno Offline
Loc: Kalifornia Kollective
So the long trip situation was high manifold vacuum at cruise. Around town and commuting is variable vacuum as you accelerate, etc. Different operating parameters.
Go through the PCV system and make sure it's all clean tight and working as it's supposed to.
Many of those Ford system have the PCV valve laying sideways and they gunk on one side. They'll pull oil any time they see high vacuum ...
#4626517 - 01/06/18 11:35 PM Re: Car using oil on long trips? [Re: Jack2468]
ecotourist Offline
Loc: British Columbia, Canada
On short trips you accumulate water and fuel in the oil, which you boil off on a long trip, making it appear there was sudden oil use. At least that's what people used to say. I'm not so sure there would be that much water and fuel in the oil however (1 quart in 5, or 20% seems unbelievable).
That doesn't explain why it would use a second quart on the trip extension.
But it could explain some of the apparent stopping of oil use when you get back.
Back in the day I had a Ford that burned oil. It seems it would be pretty good right after a change and then after a while it would start to use oil. At the time I assumed there was a gradual loss of viscosity and at some point the oil would be thin enough to get past the rings. But that was pure speculation.
And anyway I think oils maintain their viscosity better nowadays.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
#4626522 - 01/06/18 11:43 PM Re: Car using oil on long trips? [Re: Jack2468]
WyrTwister Offline
Loc: Texas
I too would investigate the PCV system .
Wyr
God bless
#4626583 - 01/07/18 04:14 AM Re: Car using oil on long trips? [Re: Jack2468]
demarpaint Offline
Loc: NY
I would check the PCV system as already mentioned. It could also be that the longer trips are getting the oil to full operating temperature and it is staying there for a long time. The hot oil at operational viscosity might be getting past parts like worn valve guides and/or worn rings, both of which can have signs of wear. The vehicle in question is from 1998 and has 126K miles on it. That could be a possibility. If the PCV system checks out you might want to try something like Mobil 1 0W40. Or it could be as simple as bad valve stem seals.
God Bless Our Troops
#4626622 - 01/07/18 07:05 AM Re: Car using oil on long trips? [Re: Jack2468]
dlundblad Offline
Loc: Indiana
Does the car see much higher RPM's on the road trips?
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4626646 - 01/07/18 07:49 AM Re: Car using oil on long trips? [Re: Jack2468]
tig1 Offline
Loc: Illinois
If you aren't seeing smoke on engine start or hard acceleration from a red light, then valve seals are most likely not the problem. PCV change would be my first thought to change. My 96 Merc GM had 218K on it when sold and used a qt every 6500 Miles from new to when sold. Try M1 10-30 HM for several oil changes.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4626700 - 01/07/18 08:59 AM Re: Car using oil on long trips? [Re: ecotourist]
eljefino Offline
Loc: ME
yeah but it started out with brand new oil. I like the PCV idea.
#4626775 - 01/07/18 10:47 AM Re: Car using oil on long trips? [Re: Jack2468]
Linctex Offline
Loc: Waco, TX
The PCV valve is almost always the one thing to blame with weird oil consumption patterns on the 4.6 Ford V8.
#4626827 - 01/07/18 11:33 AM Re: Car using oil on long trips? [Re: Jack2468]
bubbatime Offline
Loc: South Florida
Has the car been on conventional its whole life? If so, I'd expect some consumption with a fresh synthetic oil at 125K miles.
Try some Maxlife syn blend 5W30 next time.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4626846 - 01/07/18 11:46 AM Re: Car using oil on long trips? [Re: dlundblad]
Jack2468 Offline
Loc: SC
No, the engine on this car barely turns over on the highway, the RPMs are probably like <2000 at 80mph. When I'm driving around town, I accelerate much harder and RPMs come up much higher than they do when I take it on long, easy freeway cruises.
- MC FL-910S
- Mobil1 5W-30
- MC FL-820S
#4626863 - 01/07/18 11:52 AM Re: Car using oil on long trips? [Re: eljefino]
ecotourist Offline
I do too. I'd investigate the PCV.
2000 BMW 528i 5MT
#4626864 - 01/07/18 11:52 AM Re: Car using oil on long trips? [Re: bubbatime]
Jack2468 Offline
Loc: SC
I acquired the car with 105k on it and started using full synthetic around the 110k mark. Never seemed to use any oil before and I was using either Mobil1 or Valvoline synthetic but the last 2 oil changes prior to this most recent one with M1 I used Castrol synthetic and it seemed to use some when I ran it, but only on really long trips. Haven't had this most recent fill of M1 in long enough to tell if it's using any more oil yet.
Based on what service records I have, the previous owner ran either 5W20 or 5W30 conventional or stnthetic blend. I've always done 5W-30 since I've had it and full syn for the past 11,000+ miles.
Another detail I may add is I am driving this car a LOT more than I was when I got it, too. I was only putting on about 1500-2000 miles a year when I first acquired the car about 4 years ago. This past 10 months, I've done about 8,000 miles so far and in the next 2 months I am on track for another 2000 or so.
- MC FL-910S
- Mobil1 5W-30
- MC FL-820S
#4626868 - 01/07/18 11:56 AM Re: Car using oil on long trips? [Re: Jack2468]
Jack2468 Offline
Loc: SC
I'll go buy a new PCV valve and change it out to see if that helps. It is really sounding like that is the case with my car, especially with how many people in this thread have suggested it.
I really don't think (and am hoping it is not) the rings or valve seals, and the lack of oil burning smell and exhaust smoke and the fact that it doesn't use oil all the time, only on long drives, leads me to believe that is not the case.
- MC FL-910S
- Mobil1 5W-30
- MC FL-820S
Page 1 of 2 1 2 >
