Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
35 registered members (Black_Thunder, Char Baby, aleneros, CB900F2, Bjornviken, bluesubie, 4 invisible), 893 guests, and 44 spiders.
Topics295,207
Posts4,929,895
Members66,711
Most Online2,553
Oct 27th, 2018
'16 Camaro 2.0L Turbo AC DELCO 5W30 full syn #4624325
01/04/18 10:01 PM
01/04/18 10:01 PM
Alberta Canada
Roland1 Offline OP
Roland1  Offline OP
Alberta Canada
Hey everyone this is my first post!
45000 km/ 27961 miles on engine.
This is the fourth oil change.
First 3 OC's were M1 5w30. AC DELCO filters every time.
This was the last free oil change i could muster out of my local Chevy dealership.
What are your thoughts and opinions?
Also I would love a recommendation in an oil or two in 5w40. I do not have catalytic converters and the car gets driven ridiculously hard.
Currently I have 500km on shell Rotella T6 0w40 with an M1 synthetic filter in. Will do a UOA a little prematurely just to see how the first run with T6 goes. Also is it okay to run 0w40 year round? We do have cold nights and mornings for a lot of the year with the exception of peak summer. Like 40 to 55f .
Reason for 0w40 is our ambient temperature has hit below -40c/f lately.
The engine is a 2.0T DI. catless downpipe/ Intake / tune.
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4624328
01/04/18 10:08 PM
01/04/18 10:08 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
I guess this engine like the iron.
Why 5w40? I'd dump Castrol Edge 0/40 right into that engine.
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4624337
01/04/18 10:21 PM
01/04/18 10:21 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Nice car !
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4624374
01/04/18 11:11 PM
01/04/18 11:11 PM
5600 feet elevation, Arizona
double vanos Offline
Well, first off welcome sounds like a neat car. I believe that Edge 0w-40 would be ideal as well. A recent discussion here indicated that the German made version has a higher % PAO in it than the Edge made elsewhere. My Wally World carries the German version and thats what Im using in an Ecoboost F150. Let us know what you decide to do. And please take your chair here in the open air asylum also known as BITOG.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4624483
01/05/18 04:58 AM
01/05/18 04:58 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
welcome
What's the oil km ?
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4624556
01/05/18 07:07 AM
01/05/18 07:07 AM
New England
Virtus_Probi Offline
New England
Interesting to see an analysis for the AC Delco 5W30, thanks for sharing!
I'd guess this is their dexos1 Gen 2 oil with the relatively low calcium concentration as well as the high magnesium, looks sort of like M1 5W30 has for years in those respects.
Very interesting to see some titanium in there! I think that must have been from an oil additive as that is not a typical wear metal (except maybe in a MiG25's or SR71's oil? ;^).
I think when GM had a big recall for LSPI (a possibly destructive knock-like event) in their 1.5l DITs, they specified that the oil should be changed to AC Delco 5W30 in the US and M1 5W30 in Canada...you have likely had good protection from LSPI to date as you have only used those oils in your 2.0l DIT until the Rotella change, and I think that 5W40 (think your 0W40 must be a typo) is also a low calcium formulation that is likely to be LSPI resistant.
I am planning to stick with dexos1 Gen 2 oils in my 2.0l DIT from now on as they are tested for LSPI resistance, but you might be looking for higher HTHS oils if you drive the snot out of your vehicle. I have run M1 5W30 ESP in the past, it has a very high HTHS for its grade (3.58) and what I know about the formulation suggests that it should help prevent LSPI...the only downsides are that it is a dexos2 (diesel) oil that is not LSPI tested and it tends to be expensive.
Much like the GM 1.5ls, my Subaru 2.0l DIT was recalled to check for LSPI damage and reprogram the ECU...some folks got new engines from that recall. I have been extra sensitive to the LSPI issue ever since, although I was aware of it before that thanks to the fine folks at subaruforester.org and BITOG.
2014 Forester XT, 90000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Virtus_Probi] #4624678
01/05/18 09:17 AM
01/05/18 09:17 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Typo on the 0W40. I think not.
If you want the job done right......do it yourself.
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4624707
01/05/18 09:47 AM
01/05/18 09:47 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Though I know of the 0W-40 T6 I have never seen it in any stores here.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4624711
01/05/18 09:49 AM
01/05/18 09:49 AM
MN
oil_film_movies Offline
MN
For the extreme cold in the winter, you could use any 0w40 you see (all brands are good in the 0w40 arena). Plus, when you change the oil with the thick (hot) 0w40, leave it a half-quart low on purpose, like half-way between the Add and Full lines, and put in a pint (half-liter) of Kreen, Seafoam, or Gumout Multi-System in the oil to assist in the extreme cold startups. It will gradually burn off, as designed, and will temporarily get you through the cold months as you add it. (Then stop putting it in when the temperatures gets above about -15 degC or so when its not needed.) Never over-fill, but you can keep the level at the full line during the cold months using the thinner fluids.
Also for extreme cold weather, you should definitely be running a Fram Ultra oil filter with its wire-backed media and silicone ADBV, essential. Nothing filters better than Fram Ultra.
From another Canadian who put in dealership AC-Delco oil, webfors, in another thread:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4612350/Re:_AC_Delco_D1G2_5w30_-_Deale#Post4612196
Originally Posted By: oil_film_movies
The fact that Ca is around ~1,000 ppm and Mg is ~500 ppm or so does mean this is very likely a dexos1 Gen2 oil, confirmed that. (LSPI protection with lower Ca instead of the old usual ~2,000 ppm Ca.)
Also, the Ti at 18 ppm resembles the amount of Ti that Castrol puts into their Syntec line. Much less than what Kendall typically does though.
Interesting that AC-Delco oil has now hopped on the Afton Titanium bandwagon. https://www.nist.gov/news-events/news/20...ive-engine-oils
It could be Canada-GM sources their AC-Delco (really just a re-branded oil) from Castrol. I have yet to see titanium in AC-Delco oil in the U.S.
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: DoubleWasp] #4624714
01/05/18 09:55 AM
01/05/18 09:55 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Comming back,,,, I would agree with this oil .
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: CT8] #4624735
01/05/18 10:08 AM
01/05/18 10:08 AM
Snagglefoot Offline
Snagglefoot  Offline
The photo was taken in Cranbrook, BC, Canada, not that far from Idaho.
SF
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Snagglefoot] #4624736
01/05/18 10:08 AM
01/05/18 10:08 AM
New England
New England
My mistake on that!! I've never seen or even heard of Rotella 0W40 before...Canadian market only??
Last Change;
M1 5W30 d1G2
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4624765
01/05/18 10:31 AM
01/05/18 10:31 AM
Snagglefoot Offline
Snagglefoot  Offline
Maybe. Notice the French writing on the bottle and the fact that it's a 5 liter container. Usually we see 5 quart containers (4.73 liters). Also the terrible price is $47.99 Canadian dollars. That's the price at Canadian Tire, the hardware chain in Canada that is infamous for posting inflated prices and then having sales. The $47.99 oil goes on sale for $37.99 Canadian which is $30 U.S.
SF
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: Roland1] #4625126
01/05/18 04:15 PM
01/05/18 04:15 PM
Down Under
SR5 Online content
SR5  Online Content
Down Under
Welcome !!!
Wow AC Delco with 25 ppm Titanium and Rotella 0W-40. I need to pay better attention, both of these surprised me.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: '16 Camaro 2.0L Turbo AC DELCO 5W30 full syn [Re: SR5] #4625142
01/05/18 04:23 PM
01/05/18 04:23 PM
New England
New England
Originally Posted By: SR5
Welcome !!!
Last Change;
M1 5W30 d1G2
