VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
45 registered members (4WD, BobFout, billt460, AurionX2, 97K15004WD, BlakeB, 6 invisible), 689 guests, and 53 spiders.
Topics286,268
Posts4,905,538
Members67,589
Most Online2,967
Mar 10th, 2019
Bathtub spout fitting removal help? #4623677
01/04/18 11:47 AM
01/04/18 11:47 AM
Southeast
Rtstrider Offline OP
Southeast
Hey guys I have an old delta faucet from 88 that just messed the bed. The diverter gave out and well...This is not a diverter that can be just changed out. It's a whole spout replacement deal. Here's the issue my spout is a 3/4 inch spout and all I can find are 1/2 inch replacements. I tried getting a delta faucet (universal) replacement with no luck either. It had all the fittings but...Here's the kicker...The fitting thats on the pipe looks or feels like it may have been soldered on. There is not a set screw so I'm not sure how to remove this. I tried applying heat from a torch and it didn't budge. I have a pic below of the setup. Any ideas or any way to point me in the right direction of just leaving the fitting on there and replacing the spout?
Re: Bathtub spout fitting removal help? [Re: Rtstrider] #4623685
01/04/18 11:56 AM
01/04/18 11:56 AM
USA
mk378 Offline
mk378  Offline
USA
It is soldered on. Remove the o-ring so it doesn't burn and heat with a torch.
Re: Bathtub spout fitting removal help? [Re: Rtstrider] #4623691
01/04/18 11:58 AM
01/04/18 11:58 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Yes, you appear to have the soldered on version: https://www.deltafaucet.com/files/live/s...t%20install.pdf
https://www.youtube.com/watch?v=iccz9l13bUk
Wrap the copper pipe with a wet towel within an inch or so of the fitting for a heat sink (into the wall), then apply a lot more heat to the fitting to get the solder to release.
I'm surprised that Delta does not have a replacement spout that just screws onto the existing fitting. Whenever I have called them, they are superb at assisting with old faucet parts.
Re: Bathtub spout fitting removal help? [Re: doitmyself] #4623695
01/04/18 12:05 PM
01/04/18 12:05 PM
Southeast
Southeast
Thanks for the youtube vid! I'll get a second set of hands for the channel locks and try again over lunch
Re: Bathtub spout fitting removal help? [Re: Rtstrider] #4623708
01/04/18 12:16 PM
01/04/18 12:16 PM
Southeast
Southeast
doitmyself you are the man/woman! That got it! Now...Time to hit up the local hardware store to get the new spout!
Re: Bathtub spout fitting removal help? [Re: Rtstrider] #4623722
01/04/18 12:25 PM
01/04/18 12:25 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I know you probably need it today, but generally Delta has a lifetime warranty on their products.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Bathtub spout fitting removal help? [Re: Rtstrider] #4623723
01/04/18 12:25 PM
01/04/18 12:25 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Not sure if this video will work for you:
https://www.youtube.com/watch?v=fPWmVWxx1HY
  • 2017 Toyota Sienna
Re: Bathtub spout fitting removal help? [Re: Rtstrider] #4623729
01/04/18 12:28 PM
01/04/18 12:28 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Ditto above. Send Delta the pictures and they should send you the parts. Most fixtures sold by major companies like Delta have lifetime warranties.
I just got a Symmons part, sent them the picture with my address and they knew exactly what the problem was and sent me the part.
Re: Bathtub spout fitting removal help? [Re: Rtstrider] #4623735
01/04/18 12:32 PM
01/04/18 12:32 PM
Southeast
Southeast
This is an el cheapo delta plastic spout and I wanted to upgrade to a metal one that has a replaceable diverter anyways so decided now was the best time/excuse to upgrade
Re: Bathtub spout fitting removal help? [Re: Rtstrider] #4624163
01/04/18 07:16 PM
01/04/18 07:16 PM
california
slowrench Offline
slowrench  Offline
california
Dayco makes a metal spout, that has a separate fittng, that clamps onto 1/2 in. copper pipe.Then spout threads onto fitting.Also has rebuildable diverter kit.
