I just make the wet mess on the floor but next time I have it split apart I've got a manual lever valve I'm going to install further up so I won't have as much water coming out the next time. I have about 20 feet of 2" pipe full of water each time. I'd bet you don't have that much water to lose. I recently installed the Hydrocheck switch on the primary.
https://www.hydrocheckproducts.com/product-page/hc6000-hi-low-sump-controller-dual-float
At my buddy's house where I just helped him with a pressure tank change out and converted the hard plastic into pex setup.
his is a straight shot out prob 10ft.
At the parents house it goes around 2 walls and up 6ft so... probably 20-30ft.
sump pit in sorta centered on inside(middle) wall in basement. Who knows why.
