Last night I had to replace some PVC pipe on my Sump Pump . I installed a Check Valve since there wasn't one . And since a Check Valve holds water in the pipe above it , removing the pipe would result in water spilling all over the floor . Is there something you can install above the Check Valve to drain the pipe before removal ? Just thinking ahead here .
