My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned - I let someone else change my oil
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
98 registered members (Anduril, 97K15004WD, 93cruiser, andyd, 15 invisible), 1,942 guests, and 42 spiders.
Topics295,131
Posts4,928,249
Members66,691
Most Online2,553
Oct 27th, 2018
Question about E Cores #4613360
12/24/17 07:47 PM
12/24/17 07:47 PM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
I have read about ECores and saw the Fram Youtube video about various endcaps. I have never seen an ECore filter cut apart but may buy and cut one just for education. My question is this, has anyone ever seen an ECore fail in any manner? Not trying to start an argument, but, the ECore seems sturdier than the Fram fiber end caps. The Fram fiber end caps are just lightly glued onto the edge of the filter pleat, where the ECore seems to use a deep layer of adhesive that soaks into the edge and sides of the fllter pleat.
Thanks in advance for any advice.
Re: Question about E Cores [Re: Oldtom] #4613370
12/24/17 08:03 PM
12/24/17 08:03 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Ecore failures are typically media blowing through a wide spaced center tube cage. Don't see it much anymore, as I think the designers finally realized the center tube cage needed to be less open to provide adequate media support.
Also, some ecore filters have/had very flimsy attached and very thin end caps (ie, the old SupetTech filters). Actually the Frams have very firmly glued end caps - opposite of what you're thinking.
Most ecores today aren't too bad, and seem pretty reliable construction wise since we haven't seen failures posted here like a few years ago.
Re: Question about E Cores [Re: Oldtom] #4613373
12/24/17 08:04 PM
12/24/17 08:04 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
The Fram design works very well and the media is well bonded to the fiber end caps.
This is not a typical failure point.
The main rap on ecores was that the media could get blown through the plastic center tube.
I don't know how common this ever was and newer ecore designs seem to address this possibility.
These remain the cheapest filters out there. Fram's cheapy, intended for Walmart TLEs and their under twenty buck oil changes is an ecore.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Question about E Cores [Re: Oldtom] #4613376
12/24/17 08:10 PM
12/24/17 08:10 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1806202&page=all
BOOM!!
The paper can blow through the huge "windows"
Re: Question about E Cores [Re: Oldtom] #4613378
12/24/17 08:12 PM
12/24/17 08:12 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: Question about E Cores [Re: Oldtom] #4613390
12/24/17 08:29 PM
12/24/17 08:29 PM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
Yikes! Thanks for the pix. I guess that I will just run Fram Ultras or Tough Gards on everything for the small extra cost. The ECore seems a bit too cheap.
Thanks for the rapid reponse :-)
Re: Question about E Cores [Re: Oldtom] #4613404
12/24/17 08:53 PM
12/24/17 08:53 PM
So. Utah
strongt Offline
strongt  Offline
So. Utah
That tread with pics about ecores is from back in 2010. There has been design changes to the ecore cage since then.
2001 Oldsmobile Aurora 4.0 158,000 Miles
SuperTech 5W30
Re: Question about E Cores [Re: strongt] #4613449
12/24/17 09:42 PM
12/24/17 09:42 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Even so.......... Is it worth the gamble? (to some?)
I have been buying Wix/Hastings/Casite/Baldwin filters from Rock auto for $1-$2 on clearance.
I can't find e-cores that cheap, and I'm getting filters 10X better quality.
Re: Question about E Cores [Re: Oldtom] #4613481
12/24/17 10:45 PM
12/24/17 10:45 PM
socal
barkingspider Offline
socal
I have had no issues using ecore filters, but i no longer use them because non ecore filter can be had for less $$$
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Question about E Cores [Re: Oldtom] #4613484
12/24/17 11:21 PM
12/24/17 11:21 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
I used first gen ecores last decade. Although I never had a media failure in southern climate, I also never had an ecore retain ADBV function over the course of a 3K mile O/FCI. It makes me wonder how well the BPV functionality stands up over the course of a O/FCI. So I no longer use ecores, and as mentioned by others, I can find higher quality filters at equal or lower prices for my applications.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Question about E Cores [Re: barkingspider] #4613535
12/25/17 02:23 AM
12/25/17 02:23 AM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
This, Walmart recently sold me a bunch of ST filter that's non ecore for $1.50 ea.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Question about E Cores [Re: Oldtom] #4613756
12/25/17 10:12 AM
12/25/17 10:12 AM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
I have used quite a few eCores. They begin to lose ADBV function about 2500 miles into an oil change. The elements are pristine up to 6000 on the Ranger. The PF1250 is over priced in my view. WIX makes a better filter.
Here is a virgin cut and post.
PF1250 cut and post.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic 5W30 + Fram Tough Guard
Re: Question about E Cores [Re: Oldtom] #4613836
12/25/17 12:01 PM
12/25/17 12:01 PM
North Carolina
4ever4d Offline
4ever4d  Offline
North Carolina
I have personally used many an ecore filter without incident, mostly AC/Delco on past and present GM vehicles. I do indeed like the fact that the gaps in the cage have been made smaller. I have ran them out to the limit of the OLM that has reached 8k. Although they aren't my first choice i will use them without hesitation. My first choice is the Fram TG btw.
04 Chevy Colorado 3.5 I5 5w-30 OEF
07 Honda Element 2.4 I4 5w-20 OEM
10 Nissan Rogue AWD 2.5 I4 5w-30 OEF
Amsoil Products & Fram or Wix Filters
Re: Question about E Cores [Re: Oldtom] #4613914
12/25/17 02:08 PM
12/25/17 02:08 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Here is an STP (e-core) filter that was caked in gunk, and it held just fine.
The original design did have issues with blowouts, have not seen any in years.
I would use an e-core with no worries at all.
2018 Hyundai Santa Fe: Dealer oil and filter/5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: Question about E Cores [Re: Oldtom] #4615528
12/27/17 08:52 AM
12/27/17 08:52 AM
Great White North.. eh
webfors Offline
webfors  Offline
For those that say they have used them with no issues, I would like to see all your c&p threads for each and every single one please.
That first picture is from my thread... the conclusions were if the pleats were tight, plenty and even, the design is perfectly fine. If not, there's a risk of a blowout. You could run an ecore with a blown filter media for 10k miles and never know it. If they came in clear cans so I could inspect the filter media before use I would buy them. Otherwise, buy a filter with a steel center cage and a solid history.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w20, Fram DL11665
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
