What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
51 registered members (Bailes1992, 87sammy, billt460, alcyon, Black_Thunder, bcossa2001, 5 invisible), 708 guests, and 52 spiders.
Topics286,050
Posts4,901,499
Members67,551
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
AWD: driving with bad rear diff in 2WD (FW) mode ? #4608985
12/20/17 06:54 AM
12/20/17 06:54 AM
Reunion Island
Superflan Offline OP
Reunion Island
Hi,
today, my wife's car (Koleos in sig) began to make strange noises. After visual inspection (without tearing anything apart but the wheels), I went for some test drive. It seems to come from the rear differential (it's an AWD vehicle).
It goes like a HARD clunk, with some wheel locking when it happens. If I switch to 2WD mode, so far it stopped to clunk but there's some now some bad gears or worn bearings.
Do some of you think that, awaiting rear diff replacement, the vehicle can be driven in 2WD mode (fwd only) without causing direct severe injury from a shaft that would break, some wheel lock, or something along this ?
Right now I'm going to drain the rear diff oil to see if there's some big chunks of metal in it.
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealerís overfilled, 16000 Km
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: Superflan] #4609003
12/20/17 07:22 AM
12/20/17 07:22 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Lots of 4WD fans have used this method to get home after something breaks in their rear driveline.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: SteveSRT8] #4609004
12/20/17 07:25 AM
12/20/17 07:25 AM
Reunion Island
Reunion Island
Good to hear that, but in my case it's more doing something like approx. 1000 miles before getting parts replaced...
Maybe by emptying diff oil and removing the two rear halfshafts ?
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: SteveSRT8] #4609062
12/20/17 08:44 AM
12/20/17 08:44 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have also been there, done that.
As per your Koleos 2.0 .... let us know what you find when you pull the cover off the diff FIRST
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: Linctex] #4609084
12/20/17 09:11 AM
12/20/17 09:11 AM
Reunion Island
Reunion Island
Seems that the bolts on the upper side of the diff aren't accessible enough for me to pull out the cover without removing the diff from the driveline frown I just flushed the oil and this is what I found :
Oil leak from halfshafts, but the oil quantity in there was near OK (0.55l, found 0.45):
Left: fill plug, Right: drain plug with magnet and a lot of metal
Clean drain plug:
Shiny oil:
1-5mm metal chunks (found a lot but didn't take the pic):
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: Superflan] #4609090
12/20/17 09:22 AM
12/20/17 09:22 AM
PimTac Offline
PimTac  Offline
Ouch. How hard is it for you to get a diff considering where you are?
Cannot see signatures any longer so it doesn’t matter.
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: Superflan] #4609092
12/20/17 09:25 AM
12/20/17 09:25 AM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
What the heck is a Koleos? You say you had some wheel lock with the rear engaged, would there be a concern the chunks could get somewhere bad when disengaged while your wife is driving?
Trade cars so you get to deal with it until fixed?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: Superflan] #4609093
12/20/17 09:25 AM
12/20/17 09:25 AM
PimTac Offline
PimTac  Offline
I had to look up Koleos since itís an unknown name to me. From Renault-Nissan. Looks similar to a Rogue here but some differences. What year is yours?
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: PimTac] #4609099
12/20/17 09:32 AM
12/20/17 09:32 AM
Reunion Island
Reunion Island
We can have common spare parts here but a rear differential... must fetch from Europe or Korea. Approx 1000 euros (used one) + shipping... + random delay (could be weeks).
I was planning to do major suspension work (shocks, arms, ...), I guess I will have to do that later, money-wise.
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: AZjeff] #4609106
12/20/17 09:39 AM
12/20/17 09:39 AM
Reunion Island
Reunion Island
I guess Iíll flush and drive the diff many times with some cheap oil till it comes clear, since thereís no load on the gears it should be okay
Trade cars? Lol she cringe at the idea of driving my old Toyota Yaris, or my old Renault Kangoo smirk In fact, sheís driving 100 miles a day, doing door-to-door (visiting nurse). So sheís almost dependant of comfort, auto trans, and ground clearance, all of which my cars donít have.
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: PimTac] #4609112
12/20/17 09:41 AM
12/20/17 09:41 AM
Reunion Island
Reunion Island
2013. Itís a Renault-Nissan-Samsung, sold as QM5 in Korea
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: Superflan] #4609124
12/20/17 09:48 AM
12/20/17 09:48 AM
PimTac Offline
PimTac  Offline
Thanks for that info. Only four years old and the differential goes out? Has to be a fluke or it has been driven hard. How was the lube? Any water?
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: PimTac] #4609125
12/20/17 09:53 AM
12/20/17 09:53 AM
Reunion Island
Reunion Island
147000Km, factory fill (I was planning to finally change the oil), Renault specs it as lifetime fill. We bought the vehicle used with 25000km back in 2014.
Nissan specs the same diff (R145, same as rogue) for 50000km OCI.
I guess the severe service and the lack of oil change killed it prematurely.
No visible water in oil for now.
Do anyone knows how to tell if another R145 from another vehicle should be a bolt-on?
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: Superflan] #4609140
12/20/17 10:08 AM
12/20/17 10:08 AM
Reunion Island
Reunion Island
About the cover, it clamps the halfshafts seals with the other part of the case.
Re: AWD: driving with bad rear diff in 2WD (FW) mode ? [Re: Superflan] #4609144
12/20/17 10:10 AM
12/20/17 10:10 AM
NH
supton Offline
supton  Offline
NH
Well, looks like the oil made it to the end of life for that diff. So it was a lifetime fluid, eh?
If it's knocking then I'm guessing it'll eventually go. But if it's noise free in 2WD... perhaps you can just avoid using 4WD unless it's actually needed.
Question: is this a part time or full time AWD system? I have heard of some trucks having a proper center diff and "auto 4WD" will leave the center diff unlocked: but I thought most "AWD" vehicles simply did not use any user-selectable switch for 2WD.
I'm a little concerned if you left it in 4Hi "all the time" and thus this is wear coming from drivetrain binding.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Page 1 of 3 1 2 3
