Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
75 registered members (2010Civic, ArrestMeRedZ, Al, 2009Edge, 53' Stude, AndyB, 7 invisible), 1,275 guests, and 41 spiders.
Topics290,929
Posts4,852,633
Members66,055
Most Online3,590
Jan 24th, 2017
Oil coming up through filler cap #4581804
11/22/17 12:20 PM
11/22/17 12:20 PM
Nebraska
Mathew_Boss Offline OP
Nebraska
2011 Dodge Durango 5.7l Hemi. 114k miles. We drove from Nebraska to Pennsylvania and in Ohio oil started coming up through the oil filler cap. I took the dipstick out and it doesn't come up through the dipstick tube after 2 miles. Causes or solutions? I recently replaced the PVC Valve, no oil leaking from drain plug or oil filter. Would a new filler cap be a good place to start or a waste of time to replace?
125k Mile 11 Dodge Durango 5.7L Hemi PP HM or QSUD 5w20 or 0w20 w/Purolator Boss or Wix XP
40k Mile 2015 Dodge Charger 3.6L Pentastar Pennzoil Platinum or QSUD 0/5W20, or 5W30
Re: Oil coming up through filler cap [Re: Mathew_Boss] #4581806
11/22/17 12:23 PM
11/22/17 12:23 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Sounds like a faulty PCV valve or blockage in the tubing that is connected to it. Also check the fresh air intake line running from the air box for restriction.
Failing that do a compression test, maybe you have excessive blowby on a cylinder.
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Oil coming up through filler cap [Re: Mathew_Boss] #4581832
11/22/17 12:44 PM
11/22/17 12:44 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Do you mean splashing out with the cap off? Most cars do that. What do you mean by coming up through the cap? You have a hole in the cap? That doesn't make any sense to me.
Why would you do a PCV on a 2011? They usually only need a cleaning with some mild solvent. They are just a metering oriface with an anti backfire pill valve. Get a dealer sourced part the orifice size is critical.
Wish you good luck getting this fixed on a nearly new vehicle smile
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Oil coming up through filler cap [Re: ARCOgraphite] #4581837
11/22/17 12:49 PM
11/22/17 12:49 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Oil fill cap gasket crumbled away or missing?
Re: Oil coming up through filler cap [Re: ARCOgraphite] #4581872
11/22/17 01:27 PM
11/22/17 01:27 PM
Nebraska
Nebraska
It's coming out with the cap on. When you stop at a rest stop on i80 smoke pours out from the hood. It's using. 5 to .75 quarts every tank. (400 miles) the spring was shot on the old pcv valve. We didn't have oil consumption in the past 1200 miles before the trip and made it about 900 miles with no consumption. Then all beck broke loose. The dodge dealer I talked to on the phone thinks either the new pcv valve failed or the gasket broke. I have a new cap ordered. I bought a Mopar PVC valve so I will warranty it when we get back it that ends up being the problem.
Re: Oil coming up through filler cap [Re: Mathew_Boss] #4581893
11/22/17 01:56 PM
11/22/17 01:56 PM
Atlanta, GA
RoGuE Offline
RoGuE  Offline
Atlanta, GA
My dad's Suburban with the 5.3l had oil leaking out from the cap all down the valve cover and the side of the block making a mess. I took a look and the rubber gasket slipped out of it's channel in the cap. I put it back in place and all was good again.
2007 Chevrolet Malibu
2.2L Ecotec
Re: Oil coming up through filler cap [Re: Mathew_Boss] #4581896
11/22/17 02:00 PM
11/22/17 02:00 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I looked it up on RockAuto because I was curious to see what the PCV looked like. It looks like it's suppose to lock and seal into something with its o-ring. I wonder if it twists and locks directly into the intake manifold.
http://www.rockauto.com/en/moreinfo.php?pk=5051982&cc=1447826&jsn=418
Re: Oil coming up through filler cap [Re: Merkava_4] #4581906
11/22/17 02:11 PM
11/22/17 02:11 PM
Nebraska
Nebraska
Yeah it does just spin in and out. I replaced it about 2k miles ago mopar out mopar in.
Re: Oil coming up through filler cap [Re: Mathew_Boss] #4585262
11/26/17 09:08 AM
11/26/17 09:08 AM
Nebraska
Nebraska
Update: On the way back to Nebraska. Replaced oil filler cap the local dodge dealer was able to get me a new one before I left. So far we are to Chicago from PA and no oil has come up through the cap since. The oddest thing about the whole ordeal is no one added oil or messed with the oil cap to male it fail it just started leaking on the interstate.
Re: Oil coming up through filler cap [Re: Mathew_Boss] #4585379
11/26/17 11:15 AM
11/26/17 11:15 AM
So. Calif.
turnbowm Online content
turnbowm  Online Content
So. Calif.
Glad to hear it was such a quick, inexpensive fix.
2015 Kia Optima EX 2.4L GDI
2015 Chevy Volt
Re: Oil coming up through filler cap [Re: Mathew_Boss] #4586515
11/27/17 12:42 PM
11/27/17 12:42 PM
N.H, U.S.A.
N.H, U.S.A.
I wouldn't speak too soon.
Was the gasket gone? Something missing here.
Very simple device with no mysteries.
Hope a squirrel didn't put an acorn into your CC air inlet hose.
I had 3 cups of acorns in my airbox last year - luckily on the dirty side of the filter!
Re: Oil coming up through filler cap [Re: ARCOgraphite] #4586640
11/27/17 02:54 PM
11/27/17 02:54 PM
Tennessee
ChevyMan93 Offline
ChevyMan93  Offline
Tennessee
Thats nuts!
2016 Chevrolet Silverado Z71 5.3
2017 Honda CR-V 2.4
Re: Oil coming up through filler cap [Re: ChevyMan93] #4586858
11/27/17 07:03 PM
11/27/17 07:03 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Thats nuts!
Indeed
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Oil coming up through filler cap [Re: ARCOgraphite] #4586876
11/27/17 07:25 PM
11/27/17 07:25 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
So a 2011 (nearly 7 model years old) is a nearly new car?
