Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
jmd, alexislaborda, tbann, LisaMC, chops
67556 Registered Users
111 registered members (Arminius, AirBull, Alfred_B, Asterix, 53' Stude, aquariuscsm, 14 invisible), 2,142 guests, and 55 spiders.
Topics286,066
Posts4,901,902
Members67,556
Most Online2,967
Mar 10th, 2019
First oil change on '16 Camry. #4580615
11/21/17 12:42 AM
11/21/17 12:42 AM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
I have one ramp made from 2x8s screwed together. For the other side, I laid down a stray 528e wheel with tire and made a ramp out of a 54" piece of 2x6 and various thickness up to 6x6 to support it every foot or so. Not pretty, But close by. Worked fine for the job. Then I unrolled a 6x3' carpet strip and found the filter housing. My special oil socket worked. I'm glad I had gloves on. My bad, I should have read the directions that came with the filter. My only defense is that it was the first time I ever had a filter that came with directions. First time I have used 0w20. For a panicked second, I thought I was draining the transmission. The stuff is thin. The filter hosing comes with a drain plug. It was stuck fast and I had the housing in my hand. I have enough scrap around to screw together a matching ramp. I used STP 0w20 synthetic from A zone. The car sees a little short tripping combined with at least one run of 25 miles of mixed driving. The car seems to be set to a 5K OCI. I'm going for at least 7500. Next is going to be a drain and fill of the transmission. 6 speeds and no dipstick.
Thick oil is better grin2
Re: First oil change on '16 Camry. [Re: andyd] #4580647
11/21/17 02:49 AM
11/21/17 02:49 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You got two 2016 Camry's ?
Re: First oil change on '16 Camry. [Re: Merkava_4] #4580782
11/21/17 09:00 AM
11/21/17 09:00 AM
HondaBroMike Offline
Well, have you seen the 17 Camry? It blends in too much, imo. No clue how it drives but it could be mind numbing. Maybe they will discount them right away?
Re: First oil change on '16 Camry. [Re: andyd] #4580791
11/21/17 09:17 AM
11/21/17 09:17 AM
VA
Gebo Offline
Gebo  Offline
VA
Please buy some ramps.
Im curious, why the affection for STP? Just curious. Thats all.
Do a lot of YouTubeing before you start with the transmission fluid. Id definitely change it but it may be a little more complicated than changing the oil. I went and bought and scan gauge ii due to my initial mess up changing the atf in the Toyotas under my care. I drained them hot and measured what I took out not realizing how much ATF expands at operating temp. Consequently, I put back more than I removed. I know, its hard to wrap your mind around. If you drain them while overnight cold, you should be able to measure how much you took out and put that same amount back in.of course, this assumes they were properly filled from the factory.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: First oil change on '16 Camry. [Re: HondaBroMike] #4580868
11/21/17 10:51 AM
11/21/17 10:51 AM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
2016 and 2017 is the same
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: First oil change on '16 Camry. [Re: andyd] #4581068
11/21/17 02:37 PM
11/21/17 02:37 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Oil changes are every 10k miles. The MR light does go off every 5k for tire rotations and fluid level checks. So sometimes an oil change is needed and other times it's not needed.
Re: First oil change on '16 Camry. [Re: SatinSilver] #4581079
11/21/17 02:53 PM
11/21/17 02:53 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Forget to mention, around here the first two oil changes and tire rotations are free for 2 years/25k miles. The dealer here uses TGMO 0w20 and an oem filter.
Re: First oil change on '16 Camry. [Re: andyd] #4582328
11/22/17 09:00 PM
11/22/17 09:00 PM
Senoia, GA
thooks Offline
thooks  Offline
Senoia, GA
Don't do 10k oil changes. I was doing them on my 2011 Sequoia and 2014 Tundra. Sequoia has 100k on it. Went to change plugs and 3 tube seals are leaking. It also uses 1qt per 5k miles. I am gonna fix the tube seals and have been doing 5k oci
Also- nearly every car is operating on the severe schedule. Most folks don't want to admit it.
Re: First oil change on '16 Camry. [Re: thooks] #4582404
11/22/17 09:53 PM
11/22/17 09:53 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
The lack of transmission dipstick is no loss at all, since Honda is the only one who seems to know how to make an accurate one.
But for an OCI over 7500, use M1/Edge/PP 0w20 and a Mahle oil filter smile
