Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
25 registered (citationxeleven, clinebarger, Black, bbhero, ctechbob, boom10ful, 3 invisible), 942 Guests and 36 Spiders online.
65282 Members
67 Forums
285683 Topics
Page 1 of 2 1 2 >
#4576695 - 11/17/17 05:09 AM Timing Belt Questions
artbuc Offline
Loc: West Chester, PA
I have a Mitsuboshi CD304 timing belt from an Aisin kit. It is pliable and hangs in a smooth loop. I also got a Bando TB307 belt which is required for my application. The Bando belt is very stiff and has 4 bends that are set in the belt. That is, the weight of the hanging belt does not straighten the bends. The Amazon seller removed the belt from its Bando box and then jammed the belt and the Bando box in a smaller outer box for shipping. Iím going to ask Bando about this but was wondering what you folks thought. I remember installing a Gates timing belt that was stiff similar to the Bando belt. It worked fine but was noisy. After a couple months I replaced it with a Mitsuboshi belt which was much quieter. Thanks.
Edited by artbuc (11/17/17 05:14 AM)
#4576696 - 11/17/17 05:26 AM Re: Timing Belt Questions [Re: artbuc]
JC1 Offline
Loc: Oshawa, Ontario Canada
I would return that belt.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4576705 - 11/17/17 05:43 AM Re: Timing Belt Questions [Re: artbuc]
Char Baby Offline
Loc: ROCHESTER, NY
Use only Mitsuboshi or Aisin(KITS) when it comes to timing belts and their related parts(tensioners, oil seals, water pumps).
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4576712 - 11/17/17 06:17 AM Re: Timing Belt Questions [Re: artbuc]
Gebo Offline
Loc: VA
I don't know. The Band is a drive belt, right? Power steering, alternator, AC?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
#4576755 - 11/17/17 07:20 AM Re: Timing Belt Questions [Re: JC1]
artbuc Offline
Agree. Just affixed return label.
#4576756 - 11/17/17 07:21 AM Re: Timing Belt Questions [Re: Gebo]
artbuc Offline
Huh?
#4576761 - 11/17/17 07:27 AM Re: Timing Belt Questions [Re: artbuc]
Gebo Offline
Loc: VA
Huh?
Your Bando belt is not the timing belt, correct? It's one of the skinny belts for the PS. ALT or AC.
IF it is not the timing belt, I'd put in on. I don't think it would ever "relax" out like the thinner more pliable timing belt.
Edited by Gebo (11/17/17 07:33 AM)
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4576762 - 11/17/17 07:29 AM Re: Timing Belt Questions [Re: artbuc]
Trav Offline
Loc: MA, Mittelfranken.de
Both timing belts are they? The Bando is a good belt no reason not to use it, a serpentine belt (I assume the Bando) is constructed differently than a timing belt.
#4576778 - 11/17/17 07:45 AM Re: Timing Belt Questions [Re: artbuc]
artbuc Offline
Sorry for the confusion. The Bando is also timing belt. Had to buy because the Mitsuboshi timing belt in the Aisin kit does not fit but all other parts do. I have had very good experience with both Bando and Mitsuboshi timing belts. But I never got one that was repackaged in a way that caused bends in the belt that have such a set the belt wonít straighten itself under its own weight.
#4576791 - 11/17/17 07:55 AM Re: Timing Belt Questions [Re: artbuc]
Gebo Offline
Loc: VA
Gotcha! In my packages I had got the Bando as one or both of the serpentine belts. That's why I was asking. If the timing belt is all cattywampus, yeah, I'd send it back. At least I'd sleep better at night
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4576803 - 11/17/17 08:04 AM Re: Timing Belt Questions [Re: artbuc]
Bottom_Feeder Offline
Loc: Occupied Virginia
That didn't raise any red flags that you may have the wrong kit?
I have, twice. It's not a cause for concern. Bends are fine. Kinks are what you need to worry about.
#4576824 - 11/17/17 08:21 AM Re: Timing Belt Questions [Re: Bottom_Feeder]
artbuc Offline
Guess it is hard to tell the difference between a bend and a kink. Re the kit, yes I had to carefully check and recheck OEM part numbers. The kit is for Subaru Foresters and Imprezas which use a modified curvilinear timing belt. The Outback uses all of the other parts except it takes a curvilinear belt. The only other part in question was the cog idler which took a little sorting out. I bought an OEM as backup but donít think I will need it.
#4576891 - 11/17/17 09:27 AM Re: Timing Belt Questions [Re: artbuc]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
OEM
#4576955 - 11/17/17 10:16 AM Re: Timing Belt Questions [Re: Yah-Tah-Hey]
artbuc Offline
Originally Posted By: HosteenJorje
OEM
For timing belt, cog idler or everything? Everything in the kit except Mitsuboshi belt is OEM or equivalent - NTN tensioner, Koyo and NSK idlers and the made in Japan Aisin WP which almost certainly was sourced from Yamada.
#4577019 - 11/17/17 11:16 AM Re: Timing Belt Questions [Re: artbuc]
Audios Offline
Loc: Lyndhurst NJ
We get Gates and Conti timing belts all the time that have some bends in them, as long as they're not creased its not a problem.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2005 BMW M3 BMW Twin Power 10/60
1998 BMW M3/4/5 Fuchs 5/40
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
Page 1 of 2 1 2 >
