Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
27 registered members (aleneros, csandste, Bailes1992, BlakeB, 5 invisible), 780 guests, and 39 spiders.
Topics290,867
Posts4,851,566
Members66,044
Most Online3,590
Jan 24th, 2017
What do I do about this parking brake cable? #4569104
11/09/17 06:22 PM
11/09/17 06:22 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
Hello,
I'm trying to fix my parking brake which hardly works anymore and went under the ashtray to find very uneven brake lines. 2003 Jetta 2.0L.
https://i.imgur.com/i6k7oEb.jpg
https://i.imgur.com/OoLV37A.jpg
I imagine tightening the nut here won't help, and I will need to adjust something on the caliper.
Does it look like my right brake is too loose and I need to adjust that at the caliper?
Thank you
Re: What do I do about this parking brake cable? [Re: llmercll] #4569122
11/09/17 06:40 PM
11/09/17 06:40 PM
Toronna
maxdustington Offline
Toronna
The calipers are nonadjustable. Your cable is most likely stretched and needs replacement.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
Re: What do I do about this parking brake cable? [Re: llmercll] #4569124
11/09/17 06:42 PM
11/09/17 06:42 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
What happens when you pull up on the handle? Are the cables free at the rear brakes? Your car is of an age where lack of use freezes things.
Thick oil is better grin2
Re: What do I do about this parking brake cable? [Re: llmercll] #4569159
11/09/17 07:35 PM
11/09/17 07:35 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I have done so many of these I cant remember how many, there is only one way to fix them properly so the brake works as it should.
First, replace the rear calipers, pads and rotors. All sorts of strange things happen with these calipers as they age from seizing of the e brake to the piston retracting on its own with the brake applied.
Rock Auto now carries Raybestos new optical calipers they are brand new with limited lifetime warranty not remans, you need left rear FRC11078N and right rear FRC11077N.
The BECK/ARNLEY 0832751Z are Zimmerman rotors and one of the best on this car an alternative that is also good is the PAGID 355105412 Pads should be PAGID 355018111
Get new cables clips, holders and tubes from VW only, do not go aftermarket for these parts, you might as well use the money for wipe paper. Don't forget the 2 tubes and rubber seal.
These can be a PITA to bleed but after bleeding you have to operate the hand brake quite a few times for the piston to find its correct spot before final adjustment of the nut.
Re: What do I do about this parking brake cable? [Re: maxdustington] #4569160
11/09/17 07:38 PM
11/09/17 07:38 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
Is there anything I can do to temporarily tighten them?
Re: What do I do about this parking brake cable? [Re: llmercll] #4569242
11/09/17 09:01 PM
11/09/17 09:01 PM
MN
WillsYoda Offline
WillsYoda  Offline
MN
Brake cables are cheap. But in my car you can add some washers where it can be adjusted (by an adjustment nut) under the arm rest/ center console. I'm pretty sure you can do the same thing.
Re: What do I do about this parking brake cable? [Re: llmercll] #4569246
11/09/17 09:03 PM
11/09/17 09:03 PM
ME
eljefino Offline
eljefino  Offline
ME
One caliper is presently mechanically frozen, which is why your divider thing is off center. Might as well fix it right like Trav says.
Pluck the cables like guitar strings. You'll get some uggas on the cable that goes to a working brake mechanism and have a very taut or very loose cable on the other side.
If you want to cheap out find out how and where the cable comes in at your calipers and try to free up whatever's jammed. Ball peen hammer, vise grips, whatever, you'll know if you get it and you'll know if you break it.
And if you're not good at brakes you should see a shop.
Re: What do I do about this parking brake cable? [Re: Trav] #4571415
11/12/17 02:01 AM
11/12/17 02:01 AM
ny
llmercll Offline OP
llmercll  Offline OP
ny
Yikes, that's going to be pricey. My car has 215k miles and I'm on a budget. While not being optimal, you don't think I could get by just purchasing some doorman cables from rock auto and changing those by themselves?
Re: What do I do about this parking brake cable? [Re: llmercll] #4571420
11/12/17 02:45 AM
11/12/17 02:45 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Dorman is a no go, imo. They make like one thing I would consider buying and its a stamped piece of steel transmission pan.
Everything Ive bought from them that was slightly complex like oil cooler hoses and control arms, started showing signs of distress after a year of service.
Im pretty sure they are just made for getting a car by until you trade it in.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: What do I do about this parking brake cable? [Re: llmercll] #4571717
11/12/17 12:14 PM
11/12/17 12:14 PM
Trav Offline
Trav  Offline
The problem with aftermarket cables is they are much lighter than OE which tend to stretch but the major problem is rarely fit the thin metal tubes going into the tunnel.
Before doing just cables you need to properly assess the system. Caliper operation, all cable holders and clips in place, are the tubes bent, rusted or damaged?
You may be able to get away with it but I wouldn't count on it.
