List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
91 registered members (alchargo, Bman90, 53' Stude, Al, A310, 12 invisible), 1,793 guests, and 44 spiders.
Topics290,898
Posts4,852,098
Members66,047
Most Online3,590
Jan 24th, 2017
Best oil for my vehicle #4555165
10/26/17 01:25 PM
10/26/17 01:25 PM
Mississippi
jhammermil2008 Offline OP
Mississippi
Hello. Needing oil recommendations for my 1999 Honda Civic LX
1. 1999 Honda Civic LX D16y7 engine
2. Owners manual recommends 5w-30 or 10w-30 depending on weather conditions.
New Honda chart state's 5w-30 with 5w-20 being acceptable.
3. I live in Hattiesburg, MS
4. Driving is easy. Never above 3000 rpm's.
5. I drive short trips. About 10 miles per day for about 4-5 days per week.
6. Very minor oil leak. Not enough to notice much loss between oil changes. Does not use oil.
The car has about 225,000 miles. I've used 5w-30 since I've owned it with 180,000 miles. Not sure what was used before then. I'd like to keep this car as long as possible. I was curious to know your thoughts about 0w-20. The Honda charts state's 5w-30 with 5w-20 being acceptable. I wonder if I could use 0w-20? What do you think?
Thanks for you helps.
Re: Best oil for my vehicle [Re: jhammermil2008] #4555172
10/26/17 01:28 PM
10/26/17 01:28 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
On an older car like that I'd stick with 5w30. Since you mention an oil leak I'd go with some Valvoline Maxlife red bottle/jug. Also be sure to change the pcv valve with an oem unit if it hasn't been done lately.
Re: Best oil for my vehicle [Re: jhammermil2008] #4555173
10/26/17 01:29 PM
10/26/17 01:29 PM
Fly-over country
zuluplus30 Offline
zuluplus30  Offline
Fly-over country
Any HM 5w or 10w30 would be good here. May help slow your leak. 10w if it starts consuming. D16s can be run on 20w but Iíve always had good results with 30w on the D and B series Hondaís. MaxLife is a great oil for the price. Ditto on the PCV valve. Mine was filthy at 165k and all but ended my oil consumption on my Y8.
Re: Best oil for my vehicle [Re: jhammermil2008] #4555181
10/26/17 01:39 PM
10/26/17 01:39 PM
Florida
Dumc87 Offline
Dumc87  Offline
Florida
Check a local Advance Auto Parts for Pennzoil Yellow Bottle High Mileage 10w40. Got a few jugs for $3.15 and went on to read that it shears down to a thick 10w30.
Quaker State Defy should be on clearance too, but prices are random. Might be $.45 a quart, could be $6.97 lol
'90 Z32 - PP HM 10w30
'98 ZJ - PYB HM 10w40
'02 G20 - QS UD 5w30
'09 Matrix - QS UD 0w20
Re: Best oil for my vehicle [Re: SatinSilver] #4555185
10/26/17 01:45 PM
10/26/17 01:45 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
+1
2018 Hyundai Elantra VE -- 4K
2013 Honda Pilot EX-L 4WD -- 56K
2002 Honda Accord EX-L -- 211K
Re: Best oil for my vehicle [Re: jhammermil2008] #4555187
10/26/17 01:45 PM
10/26/17 01:45 PM
FL, USA
shurguywutt Offline
shurguywutt  Offline
FL, USA
I had a 6th gen 97 civic ex as my first car. Used to run dino 10w30 in it. The D16 is legendary when it comes to reliability. I would think you could easily get another 150k with proper maintenance and maybe some valvoline maxlife 5 or 10w 30, Id recommend the silver bottle red cap full synthetic 5w30 maxlife because of your short commutes. Your real problem will be rust and corrosion on the body so make sure you keep it clean and waxed. Touchup and repair any rust asap.
2008 Pilot 2WD J35Z1 148k
Maxlife Blend 10w-30
FRAM Ultra Synthetic
Fumoto F106SX
Re: Best oil for my vehicle [Re: jhammermil2008] #4555196
10/26/17 01:58 PM
10/26/17 01:58 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I want to know how you never go over 3000 rpm in that car?
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Best oil for my vehicle [Re: jhammermil2008] #4555197
10/26/17 01:58 PM
10/26/17 01:58 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
That many miles, I would not be looking at a 20 ... Clearances have opened up some with wear, so stay 30, or maybe even go 40 if it is noisy at all ...
Maxlife red bottle is good on higher mileage engines like yours smile
Re: Best oil for my vehicle [Re: Chris142] #4555202
10/26/17 02:08 PM
10/26/17 02:08 PM
Mississippi
Mississippi
Ok, perhaps I may have gone over 3000 rpm a few times, but very rarely. Just trying to preserve engine life.
Wouldn't a 40 weight be too thick for engine start up and thus shorten engine life?
Thanks for the suggestions thus far. I see the consensus is not to use 20 weight oil. I wonder why Honda would allow a 20 weight oil in their older vehicles?
Re: Best oil for my vehicle [Re: jhammermil2008] #4555210
10/26/17 02:20 PM
10/26/17 02:20 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Because they are trying to raise fuel economy a small amount on all vehicles, new and old.
I agree with a 10w30, especially in MS where it never really gets cold.
Thick vs Thin test: 15k / 43k miles complete
Re: Best oil for my vehicle [Re: jhammermil2008] #4555222
10/26/17 02:43 PM
10/26/17 02:43 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
Valvoline Maxlife 5w30. Move up in grade as it burns/leaks more oil over time.
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
Re: Best oil for my vehicle [Re: jhammermil2008] #4555249
10/26/17 03:28 PM
10/26/17 03:28 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Occasional runs to 3500-4500 rpm might actually enhance engine life by burning off carbon deposits on rings/pistons etc. Going slow all the time isn't ideal for the engine. But, if the car has never seen anything over 3500 rpm, then maybe best not to go any higher. Occasional extended runs on the highway would be good too.
With only 2500 miles per year you can get by with a single Oil Change. If you had 2 OCI's per year, the 10w-30 would be an excellent summer oil choice in your location.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Best oil for my vehicle [Re: jhammermil2008] #4555277
10/26/17 03:55 PM
10/26/17 03:55 PM
California
jj51702 Offline
jj51702  Offline
California
Whatever meets your owners manual spec. If ur worried about the leak or any burnoff use hm oil to try and slow it down.
Its a Honda that's almost 20 years old. What more do u want from it?
Re: Best oil for my vehicle [Re: jhammermil2008] #4555349
10/26/17 05:07 PM
10/26/17 05:07 PM
Pennsylvania
K23Turbo Offline
K23Turbo  Offline
Pennsylvania
Castrol Magnatec 10W30
Re: Best oil for my vehicle [Re: jhammermil2008] #4555432
10/26/17 06:23 PM
10/26/17 06:23 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Your favorite brand 10w-30.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
