New Struts and Springs
by Mathew_Boss. 04/21/19 05:36 PM
Float chargers?
by buck91. 04/21/19 05:32 PM
Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
95 registered members (alphadog, 2015_PSD, AdditiveOCD, 53' Stude, 2009Edge, AndyB, 11 invisible), 1,959 guests, and 26 spiders.
Topics287,854
Posts4,935,613
Members67,865
Most Online2,967
Mar 10th, 2019
How do you oil your air tools? #4532294
10/02/17 07:07 PM
10/02/17 07:07 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
How many drops of oil?
Before you start or after?
What oil do you like to use?
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: How do you oil your air tools? [Re: ZZman] #4532303
10/02/17 07:15 PM
10/02/17 07:15 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
I put a few drops in when I start. If lightly used, that's it. If heavy ill put a drop in partway or after use.
Re: How do you oil your air tools? [Re: ZZman] #4532304
10/02/17 07:16 PM
10/02/17 07:16 PM
Missouri
gabriel9766 Offline
gabriel9766  Offline
Missouri
I do every couple months. I should do it more cause i beat the [censored] out my tools at work.
2015 Malibu LT 2.5L PPPP 0w20 46.1K
2007 Escape XLT 3.0L 5Q STHM 5w30/1Q MC full syn 5W20 115K
2010 Fusion SE 2.5L MC 0w20 110K
2008 Escape XLT 2.3L MC 5w30 187K
2007 Fusion SE 2.3L- 173.5K STHM 0W20
Re: How do you oil your air tools? [Re: ZZman] #4532305
10/02/17 07:17 PM
10/02/17 07:17 PM
Seattle-ish, WA
Oro_O Online content
Oro_O  Online Content
Seattle-ish, WA
3 or 4 drops of air tool oil before using that day. I don't regularly use one enough to require re-oiling.
I know others use 3-in-1 or MMO regularly with no ill effects. When the Senco bottle is empty in another decade, I might just put some MMO in it.
Re: How do you oil your air tools? [Re: ZZman] #4532306
10/02/17 07:17 PM
10/02/17 07:17 PM
USA
ArcticDriver Offline
USA
# of drops depends on the tool I am using.
Before and during.
No preference on pnuematic tool oil brand.
They do make auto oilers.
I would recommend a filter/water remover at the compressor if you don't already have one. Build it with a disconnect at both ends so you can remove and box it when transporting compressor or it risks breakage.
I am assuming you are draining the water at the end of each day and leaving the petcock open until next use.
Multiple Diesel and Gasoline vehicles
Re: How do you oil your air tools? [Re: ZZman] #4532315
10/02/17 07:21 PM
10/02/17 07:21 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Maybe 4-5 drops. I don't really measure. Do it before I start. Sometimes after... I use the HF oil.
I also have the HF air tool cleaner which I use once and a while to keep them running well.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: How do you oil your air tools? [Re: ZZman] #4532355
10/02/17 07:56 PM
10/02/17 07:56 PM
Canada
i_hate_autofraud Offline
Canada
A few drops before use.
I'd like to use an auto-oiler, but hate having oil thru all my hoses that are also used in
other applications where oil is harmful.
Re: How do you oil your air tools? [Re: ZZman] #4532367
10/02/17 08:01 PM
10/02/17 08:01 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
So is anything over 5 drops of oil overkill and likely to be bad?
Re: How do you oil your air tools? [Re: ZZman] #4532387
10/02/17 08:18 PM
10/02/17 08:18 PM
Georgia
AVB Offline
AVB  Offline
Georgia
It just makes a mess when it blows out the exhaust.
Re: How do you oil your air tools? [Re: AVB] #4532392
10/02/17 08:24 PM
10/02/17 08:24 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
So it doesn't gum anything up?
Re: How do you oil your air tools? [Re: ZZman] #4532430
10/02/17 09:04 PM
10/02/17 09:04 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I use whatever used synthetic oil is just around.
New oil doesn't seem to make any difference.
I usually add a couple drops before use.
If you aren't getting *SOME* oil puking out the exhaust once in a while, you aren't using enough oil.
Re: How do you oil your air tools? [Re: ZZman] #4532456
10/02/17 09:34 PM
10/02/17 09:34 PM
Ohio
beast3300 Offline
beast3300  Offline
Ohio
Answer: at complete random at complete random times with complete random amount of oil.
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: How do you oil your air tools? [Re: ZZman] #4532475
10/02/17 10:03 PM
10/02/17 10:03 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I hold the trigger down and pour in about 5 drops or more. Then I hook up the air hose and pull the trigger. Usually at that moment, there's a plume of oil mist that shoots out the exhaust.
Re: How do you oil your air tools? [Re: ZZman] #4532476
10/02/17 10:04 PM
10/02/17 10:04 PM
Seattle-ish, WA
Seattle-ish, WA
No. Like he said, usually you'll see excess blow out if you look for it.
Re: How do you oil your air tools? [Re: ZZman] #4532502
10/02/17 10:38 PM
10/02/17 10:38 PM
Oklahoma
tomcruise Offline
tomcruise  Offline
Oklahoma
I use MMO's air tool oil. 5 or 6 drops before the first use of that day.
2016 Ford F150 Xlt 2.7L
Pennzoil Platinum Euro L 0w40
Motorcraft FL2062
