Trying to fix chainsaw
by turtlevette
2 minutes 46 seconds ago
tire rotation
by marine65
Reese hitch $30 Walmart YMMV
by pda1122
36 minutes 46 seconds ago
Managing Anger During Unexpected Tire Change
by TheLawnRanger
37 minutes 32 seconds ago
2016 Honda Pilot appears to be consuming oil
by pilot1226
50 minutes 44 seconds ago
New belt squeal cause damage to belt?
by pda1122
Today at 05:33 PM
Food Safety - If You Have Children
by Zee09
Today at 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
Today at 05:02 PM
Chain cleaning and lube
by dadinfo
Today at 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
Today at 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
Today at 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
Today at 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
Today at 04:30 PM
mobil 1 rebate check
by Fitter30
Today at 03:52 PM
Cab mount failure
by ram_man
Today at 03:31 PM
02 Saab aero oil?
by Newuser
Today at 03:00 PM
Extend wifi range
by clarkflower
Today at 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
Today at 01:57 PM
Lease Buyout by Dealer
by Throt
Today at 01:52 PM
13 Ford Escape
by RedOak
Today at 01:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
78 registered (2015_PSD, 2004tdigls, Balrog006, asiancivicmaniac, AndyB, 10 invisible), 1468 Guests and 50 Spiders online.
65303 Members
67 Forums
285870 Topics
Page 1 of 2 1 2 >
#4517159 - 09/15/17 03:10 PM Thin oil for better winter performance
camrydriver111 Offline
Loc: Canada
My car (2005 325i) takes a lot longer to heat up in the winter than some of my previous cars.
The car feels rather sluggish in the winter. In the summer the engine runs super smooth and is a lot more responsive.
Do you think switching from a 0W40 oil to a thinner one can improve my winter performance?
How thin do you think I could go on a M54 motor?
If you are thinking thermostat, mine is 2 years old. It seems to operate at 92 Celsius instead of 97 Celsius like it's supposed to. However, there are only two brands available, Behr and Wahler. One brand leaks from the temperature sensor and one brand runs a bit cool. So given the choice between the two I would rather run a few degrees cold than leak coolant.
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
#4517164 - 09/15/17 03:17 PM Re: Thin oil for better winter performance [Re: camrydriver111]
rfeir Offline
Loc: NY
Great oil, keep using it. Slow warm up could be a design feature or your thermostat needs replacement.
RPF
#4517167 - 09/15/17 03:21 PM Re: Thin oil for better winter performance [Re: camrydriver111]
bigj_16 Offline
Loc: Douglas County, Colorado
Can you do a partial radiator or cooler blockoff and see what happens?
#4517168 - 09/15/17 03:25 PM Re: Thin oil for better winter performance [Re: camrydriver111]
JohnnyJohnson Online   content
Loc: Wet side WA
What does your owners manual say?
2004 Toyota Corolla 121790
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4517175 - 09/15/17 03:32 PM Re: Thin oil for better winter performance [Re: JohnnyJohnson]
Loc: Canada
I think it says 5W30 ACEA oil.
I think it's the design. Big engine, small displacement. The car also has a fan clutch.
#4517177 - 09/15/17 03:41 PM Re: Thin oil for better winter performance [Re: camrydriver111]
Oro_O Offline
Loc: Seattle-ish, WA
I would still verify the thermostat is opening where it should and is fully closed when cold. The easiest way this can be done is with an IR thermometer if you or someone you know has one. A stuck-open thermometer will still cool the car obviously, but will cause it to warm more slowly. This has knock-on effects on performance just like you describe.
Run a 5w-30 or 0w-30 that meets the relevant BMW spec, but also check the thermostat. What you are describing is not caused by oil choice.
#4517184 - 09/15/17 03:52 PM Re: Thin oil for better winter performance [Re: camrydriver111]
JC1 Online   content
Loc: Oshawa, Ontario Canada
Where are you located in Canada? Can you use a block heater or that's not an option?
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4517191 - 09/15/17 04:03 PM Re: Thin oil for better winter performance [Re: JC1]
FZ1 Offline
Loc: Texas
This ^^^^.
#4517193 - 09/15/17 04:03 PM Re: Thin oil for better winter performance [Re: camrydriver111]
bioburner Offline
Loc: Minnesota
If it were me I would both block off the radiator and get a block heater installed. I do here in MN. Just running the block heater for an hour or so before launch helps a lot in getting the cabin warm way sooner and no need to have much air flow past the cooling system in winter. Helps mileage too.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4517195 - 09/15/17 04:06 PM Re: Thin oil for better winter performance [Re: JC1]
Loc: Canada
Block heater is not an option.
My gut feeling is that if I replaced the thermostat it would be the same and I would be out $150.
That's why I am asking about the oil.
#4517206 - 09/15/17 04:13 PM Re: Thin oil for better winter performance [Re: camrydriver111]
ArcticDriver Offline
Loc: USA
$150. Ouch. You can't purchase a genuine BMW thermostat which is absent the two issues you described earlier? (Not as the solution to your winter performance concern.)
You have not mentioned fuel as a means of improving winter performance.
Can you describe your fuel practice in both winter and summer?
EDIT:
Would an engine running at 92*C instead of the design 97*C not run slightly richer and therefore result in no change or possibly slightly improved acceleration rather than less?
Edited by ArcticDriver (09/15/17 04:17 PM)
Multiple Diesel and Gasoline vehicles
#4517340 - 09/15/17 07:24 PM Re: Thin oil for better winter performance [Re: ArcticDriver]
Loc: Canada
A genuine BMW thermostat is a re-branded Wahler which will leak from the temperature sensor. I actually replaced a Wahler after 5 months because it leaked and I can't tell a difference between my current thermostat other than the digital temperature readout.
I use the cheapest 91 octane fuel and I don't let the tank get too low in the winter. Fill up every other week.
#4517357 - 09/15/17 07:50 PM Re: Thin oil for better winter performance [Re: camrydriver111]
Oro_O Offline
Testing the thermostat is *free,* however. And what you should do before trying to force a diagnosis on an exceedingly unlikely cause. "Where you hear hoof beats, think horses...," etc. If the behavior is the same, that's a strong indicator it may NOT be the thermostat, but if you replaced one bad one with another, it wouldn't act differently. And that sometimes happens.
Another thing to investigate is the warming circuit for the throttle body. If the temp. sensor isn't working it could create this. I don't know if a code would be thrown on your car, presumably none are registering, correct? I would also verify the fan is not always on, providing extra cooling when it should not.
Arcticdriver also has a good point - if your area's winter fuel is particularly diluted, it will be the main cause if you are sensitive to it (I am; I feel it even in my granny-driven SUV). If you don't find a solution before winter, try buying real gas (there is an app for that which will show you who sells it - "Real Gas"). That could help neck down the problem.
#4517363 - 09/15/17 08:01 PM Re: Thin oil for better winter performance [Re: camrydriver111]
andyd Offline
Loc: Marshfield , MA
IR thermometers are not expensive <20$. The no frills method is a cheap thermometer and a pot of water. I haven't even located the oil filter on mine. A scanner is way easier. Do you know another Camry and could ask what normal is. If You're in the greater Toronto area, you prob'bly wouldn't need a block heater. If the t'stat is no good,at least it failed open. Supposedly, the good ones have that feature. grin2
Thick oil is better grin2
#4517366 - 09/15/17 08:11 PM Re: Thin oil for better winter performance [Re: camrydriver111]
LotI Online   sleepy
Loc: America's Dairyland
ACEA doesn't rate oils by viscosity. Like the MINI I had, I bet the engine bay has a sticker that says Castrol/BMW oil is recommended. That marketing agreement has been dissolved. You can use any grade that meets BMW LL01.
If you run short trips of less than 20 miles I would say definitely run a thinner oil like M1 0w-30 or an A1/B1 oil that would be a 30 grade.
If your driving is more than 20 miles so you get some heat in the oil stick with the ACEA A3/B4 LL01 that BMW recommends.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Page 1 of 2 1 2 >
