E
Originally Posted By: SilverFusion2010
Originally Posted By: ArcticDriver
Originally Posted By: Johnny2Bad
When the Asians first imported vehicles to the Vancouver terminal some did not come with block heaters installed. A few hundred full-engine warranty claims later, that practice stopped about 50 years ago.
This May be moving to far off topic but can you provide further insight? How does the lack of a block heater result in a full-engine warranty claim? The temperature dropped so low the coolant froze?
Inadequate flow on cold start mainly.
Thanks.
It would be interesting to see the geographic regions these failures occurred. It.must have been in regions of marginally cold temperatures (for instance, similar to the the Chicago region) since residents of very frigid winter temperatures (ND/WY/MN/WI etc). would have immediately installed after-market heating devices and known to allow a sufficient period of warm-up prior to placing load on these motors. Having grown up in one of these "ice boxes" of America, such practices of adding a block heater in freeze plugs, have been SOP since prior to the era Asian cars were first popularized. For example, KATZ has.been around since 1948:
http://www.fivestarmanufacturing.com/about_us
Back in that era, a typical engine might have a 100K mile lifetime (of course excluding BITOG-type owners). At what mileage were these catastrophic failures occurring on Asian vehicles often enough that a trend was identified?
EDIT:
I see Johnnie indicated a timeline of over 50 years ago (basically the 1960's) in Vancouver for Canadian consumers. Interestingly, I used to.work on VWs of this same era and many of them did not come with factory installed block heaters.
Thanks.
EDIT:
