Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
IPhone SE or flip phone?
by 53' Stude. 12/18/18 05:49 PM
1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
Sportbiker, trollhattan, MuhThugga, wxo, dbierman
66718 Registered Users
22 registered members (Char Baby, Bailes1992, 4WD, cdlamb, berniedd, 2 invisible), 841 guests, and 47 spiders.
Topics295,248
Posts4,930,854
Members66,718
Most Online2,553
Oct 27th, 2018
Fuel leak from filler neck #4516821
09/15/17 07:12 AM
09/15/17 07:12 AM
WI
HoosierJeeper Offline OP
WI
I got gas in my LR3 yesterday and when I got home, gas was literally pouring out of the filler neck. I've had the neck replaced before (exactly a year ago, same thing). It was also running a bit rough. No CEL. This morning I took it for a quick ride and it's all back to normal. Any ideas? I just used the autoshut off on the pump, didn't top it off after it stopped.
Thanks!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Fuel leak from filler neck [Re: HoosierJeeper] #4516917
09/15/17 09:07 AM
09/15/17 09:07 AM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
Are you routinely topping off the tank after the nozzle shuts off? this is not good for your charcoal filter system.
Next guess is the day got warmer right after you parked the car with the over-filled fuel tank, expanding the fuel with no-where to go other than out.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Fuel leak from filler neck [Re: HoosierJeeper] #4517094
09/15/17 12:51 PM
09/15/17 12:51 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: HoosierJeeper
I got gas in my LR3 yesterday and when I got home, gas was literally pouring out of the filler neck. This morning I took it for a quick ride and it's all back to normal. Any ideas?
Something wrong with the way it's vented/vacuumed. Always stop at the "first click"
Re: Fuel leak from filler neck [Re: HoosierJeeper] #4517111
09/15/17 01:11 PM
09/15/17 01:11 PM
WI
WI
I stopped it right when the pump stopped, didn't force any more in. Never have pumped more gas after the pump stops. I'm going to run it down to a half tank again this weekend and top it off, see what happens.
What you mean by first click? Like the pump or tightening the gas cap? I've always done 3-4 clicks on the gas cap.
Re: Fuel leak from filler neck [Re: HoosierJeeper] #4517147
09/15/17 01:46 PM
09/15/17 01:46 PM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
What I was trying to describe is while you are holding the pump nozzle at the gas station, squeezing the lever, watching the dial head to $65 or so dollars..when the nozzle 'clicks' that's really when you should pull the nozzle out of the filler neck and put back in the pump holder.
The idea is to prevent too much fuel in the filler neck of your LR3 tank.
As far as tightening your fuel cap on the LR3, 3 or 4 'clicks' should do it. Any more - you're just playing. grin
1984 Yamaha XJ750RL
Re: Fuel leak from filler neck [Re: HoosierJeeper] #4517214
09/15/17 03:25 PM
09/15/17 03:25 PM
WI
WI
Yep, that's exactly what I do.
Re: Fuel leak from filler neck [Re: HoosierJeeper] #4519164
09/18/17 06:02 AM
09/18/17 06:02 AM
A Warm place to live in
berniedd Online content
berniedd  Online Content
try filling only to the 3/4 tank level for the next 4 gas ups and see what happens to the leak issue. If it stayed fixed, I'd keep doing it that way.(Lazy man that I am.)
