2019 Subaru Crosstrek FB20D - Oil choices
by cluster5. 03/26/19 09:31 PM
.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
87 registered members (4WD, 555, 2015_PSD, advocate, 2010Civic, 2002 Maxima SE, 10 invisible), 1,813 guests, and 97 spiders.
Topics286,477
Posts4,909,136
Members67,635
Most Online2,967
Mar 10th, 2019
Page 1 of 6 1 2 6
Fumoto Valve, near disaster #4514945
09/13/17 09:38 AM
09/13/17 09:38 AM
South Dakota
otis24 Offline OP
otis24  Offline OP
South Dakota
I installed a Fumoto Valve on my 2016 Dodge Grand Caravan right after I purchased it. Went out to the gun range shooting. Dirt road with some grass and stubble in the middle and along the sides, about four or five inches high. After shooting, we drove down another dirt road near the river. I wanted to show our pastor's son where to go fishing. I turned around at the top of the hill. As I started back, there was a trail of liquid about twenty feet from where I had just come. The trial was going back towards me. As I looked, it was obvious that it had come from my vehicle. Sure enough, I look underneath and oil was pouring from the valve. I was able to shut the engine off before it all leaked out. Unfortunately, it was difficult to get to the drain valve and it was hot. I finally succeeded in getting the valve closed. But not before losing five quarts of PUP. I was about 4k miles into my OCI. I am part of the Pennzoil UOA program. I called my wife and she brought me a case of oil. I only put five in, it has a 6 quart sump. Checked it this morning and it appears to be full. Now, I have to drain the oil into a clean container. I'm pulling the Fumoto Valve and replacing it with a drain plug. I will not take that chance again!
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
(3.6 V6) 46500 miles
Re: Fumoto Valve, near disaster [Re: otis24] #4514948
09/13/17 09:41 AM
09/13/17 09:41 AM
KS
FordBroncoVWJeta Online content
FordBroncoVWJeta  Online Content
KS
Thats kinda of scarry. I was thinking on putting on on my jetta. But I will occasionally go deer hunting and drive through some fields. Not going to take a chance if this has happened to you. Thanks for the information!
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2001 Pontiac Sunfire 2.2
Re: Fumoto Valve, near disaster [Re: otis24] #4514955
09/13/17 09:48 AM
09/13/17 09:48 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Perhaps I'm missing something here.. So the valve assembly came loose from the pan or the valve lever got moved to the open position? That's a highly unlikely scenario.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Fumoto Valve, near disaster [Re: otis24] #4514964
09/13/17 09:58 AM
09/13/17 09:58 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
I never understood why anyone would want a Fumoto valve. I mean, you add obvious dangers of the thing getting hit, add more chances of leaks all for a for maybe 2 minutes saved on an oil change because you don't need to remove a drain plug and then you actually lose time because it flows slower than with the plug removed. I like to see the drain plug and wipe it clean during an oil change and most are magnetic which I prefer over a non magnetic Fumuto. I understand it may be cleaner to drain the pan but you only have to "suffer" thru a messy oil change a few times a year.
Re: Fumoto Valve, near disaster [Re: otis24] #4514966
09/13/17 10:01 AM
09/13/17 10:01 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
A lazy mans accident waiting to happen. There will never be one of these on any of my cars.
2004 Corolla 130107
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Fumoto Valve, near disaster [Re: otis24] #4514971
09/13/17 10:06 AM
09/13/17 10:06 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
The only problem I have with a drain plug is I always forget to bring a paper towel, so I have to walk back into the house with an oily hand. Oh well. Really it's walk through the garage.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Fumoto Valve, near disaster [Re: otis24] #4514972
09/13/17 10:07 AM
09/13/17 10:07 AM
Houston, Texas
Houston, Texas
Didn't you put the little anti open thing on it? I thought it had a spring or something to keep it from opening.
Re: Fumoto Valve, near disaster [Re: otis24] #4514974
09/13/17 10:08 AM
09/13/17 10:08 AM
South Dakota
otis24 Offline OP
otis24  Offline OP
South Dakota
The valve lever got moved and opened the drain. I had the plastic safety clip on it too. Lesson learned. I could be in a situation where I am making payments on a new vehicle with a blown engine with no means to repair it. Yikes!
Re: Fumoto Valve, near disaster [Re: otis24] #4514975
09/13/17 10:09 AM
09/13/17 10:09 AM
The land of USA-made Subies!
SubieRubyRoo Offline
There is a lock for the Fumoto valve that they sell, it locks the handle in place. I have not had any issues with my Fumoto, but I don't know the orientation of your valve. Maybe you can rotate it to get the handle up out of the way?
Re: Fumoto Valve, near disaster [Re: JohnnyJohnson] #4514977
09/13/17 10:11 AM
09/13/17 10:11 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Agreed.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Fumoto Valve, near disaster [Re: otis24] #4514989
09/13/17 10:16 AM
09/13/17 10:16 AM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
never happened to me. Been "soft-roading" on a lowered car to get to mountain bike trailheads and never an issue with the Fumoto Valve. Didn't need to use a constant tension spring clamp, that I originally bought.
I'd use it on the current car, but since the oil filter is mounted up top, I suck the oil out through the dipstick.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Fumoto Valve, near disaster [Re: otis24] #4514998
09/13/17 10:29 AM
09/13/17 10:29 AM
Houston, TX
2015_PSD Online content
2015_PSD  Online Content
Houston, TX
The scenario you described/experienced is the primary reason I elected not to install one on my PSD. Secondary is it would take "forever" to drain 3.5 gallons out through it.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: Fumoto Valve, near disaster [Re: otis24] #4515000
09/13/17 10:31 AM
09/13/17 10:31 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
On the vehicles I installed Fumotos on, the drain plug was high up, out of the way and covered by an engine belly pan. I always ordered them with the hose barb attached and I installed a rubber/plastic cap over the barb for added protection.
Re: Fumoto Valve, near disaster [Re: JTK] #4515005
09/13/17 10:37 AM
09/13/17 10:37 AM
Ontario, Canada
Ontario, Canada
Sounds like more work than just the factory drain bolt. I really don't see the appeal of these at all.
Mighty Mouse Tech
Re: Fumoto Valve, near disaster [Re: otis24] #4515015
09/13/17 10:46 AM
09/13/17 10:46 AM
CO
UberArchetype Offline
CO
Those things have always been nothing but a lazy man's solution looking for a problem.
Page 1 of 6 1 2 6
