It's AMSOILŪ, not Amsoil
by Rat407
Today at 06:39 AM
VW Passat 2007
by madRiver
Today at 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
Today at 03:40 AM
Towing without 85w140?
by OilFilters
Today at 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
Yesterday at 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
Yesterday at 11:13 PM
Darn dogs
by AZjeff
Yesterday at 10:21 PM
New GC?
by Bullwinkle007
Yesterday at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Yesterday at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Yesterday at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Yesterday at 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Yesterday at 07:41 PM
Decent MP3 player
by Ed_T
Yesterday at 07:08 PM
Letgo
by Donald
Yesterday at 06:52 PM
Tire buying advice
by supton
Yesterday at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Yesterday at 06:21 PM
No older cars in New York State?
by Oldtom
Yesterday at 06:19 PM
2009 Taurus strut mount noise
by terry274
Yesterday at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Yesterday at 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
100 registered (1JZ_E46, 2004tdigls, Bailes1992, 2002 Maxima SE, andyd, alcyon, 13 invisible), 1462 Guests and 61 Spiders online.
65319 Members
67 Forums
285959 Topics
#4513091 - 09/11/17 10:46 AM Tips for replacing front rotors, pads 2007Explorer
2James1 Offline
Loc: Union County, PA
I maybe replacing pads and rotors for first time myself. Have done it with help awhile back on a 2000 Chevy Express. What all is different? I do have a metric allen socket set on the way(atd tools). Suggestions? Tips?
2005 Chevrolet Malibu V6
Mobil 1 HM 5w-30/ Mobil 1 M1-101
#4513094 - 09/11/17 10:48 AM Re: Tips for replacing front rotors, pads 2007Explorer [Re: 2James1]
jeepman3071 Offline
Loc: Storrs, Connecticut
My advice would be to look up a youtube video on how to do it for that specific vehicle. That way you know the process and what tools you will need before doing the job.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4513161 - 09/11/17 11:51 AM Re: Tips for replacing front rotors, pads 2007Explorer [Re: 2James1]
emmett442 Offline
Loc: Wisconsin
Nice thing about brakes is that there's only one way they will go together. You really can't do it wrong.
Being in PA, make sure you thoroughly clean and lube the caliper bracket before you put it back together. Special attention to the guide pins and the notches that the pad hardware clip into. The goal is to keep everything corrosion free and un-seized for the life of the brakes.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
#4513184 - 09/11/17 12:15 PM Re: Tips for replacing front rotors, pads 2007Explorer [Re: 2James1]
MNgopher Offline
Loc: Lakeville, MN
Don't think you will need any Allen wrenches. I didn't on my '07 explorer. All metric bolts.
Check the slider pins and lube them. Last change I ended up replacing the caliper brackets too as the pins were rusted in place to the bracket.
Otherwise, straightforward...
#4513214 - 09/11/17 12:49 PM Re: Tips for replacing front rotors, pads 2007Explorer [Re: 2James1]
tig1 Offline
Loc: Illinois
Also use a torque wrench to torque the lug nuts, which helps to prevent rotor warping.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4513309 - 09/11/17 02:15 PM Re: Tips for replacing front rotors, pads 2007Explorer [Re: 2James1]
Merkava_4 Offline
Loc: Clovis, CA
This is or a 2003, but it should be similar.
#4513310 - 09/11/17 02:15 PM Re: Tips for replacing front rotors, pads 2007Explorer [Re: 2James1]
HoosierJeeper Offline
Loc: WI
Save a brake pad and use that with a c clamp to compress the piston, make sure it's even and going in easy.
Also use blue loctite on all hardware with a torque wrench. I didn't and one time I had a brake caliper bracket come loose and destroy a wheel which stranded me. So don't be me. smile
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4513436 - 09/11/17 04:13 PM Re: Tips for replacing front rotors, pads 2007Explorer [Re: HoosierJeeper]
Kira Offline
Loc: Champlain/Hudson Valley
AGE OLD ADVICE: "Do one side at a time"
This way, during reassembly, if you forget something, you can run around to the other side and see what it's supposed to look like.
Get a set of those wee wire brushes from Harbor Freight so you can get "Deeeep into Corners" (from an old Windex ad)
#4513448 - 09/11/17 04:33 PM Re: Tips for replacing front rotors, pads 2007Explorer [Re: 2James1]
slacktide_bitog Offline
Loc: USA
My advice: get coated rotors, something with a coating to deter rust. This will help a lot! Popular choices include Centric Premium, Wagner E-Shield (part numbers ending in E), and EBC rotors
For pads, get Akebono, or Wagner OEX
You may want to flush the brake fluid, too. Speed bleeders are awesome smile
#4514429 - 09/12/17 05:57 PM Re: Tips for replacing front rotors, pads 2007Explorer [Re: 2James1]
2James1 Offline
Thanks everyone.
