VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
31 registered members (4WD, Burks21, A1O, antik, billt460, 6 invisible), 497 guests, and 54 spiders.
Topics286,267
Posts4,905,521
Members67,589
Most Online2,967
Mar 10th, 2019
Power Steering Pump & Rebuild Kit Options? #4511626
09/09/17 03:19 PM
09/09/17 03:19 PM
Phladelphia
NYSteve Offline OP
NYSteve  Offline OP
Phladelphia
I need to replace my Power Steering Pump in the GX470 (V8 4runner).
A new OEM is about $230 while rebuilt is about $150ish or so. Trying to avoid Cardone as they are $100. Car-Part/Ebay has used OEM for as low as $55ish.
Was thinking of getting the junkyard $55 and get a rebuild kit for the one I take out. The one I take it is more just to see what it's like to rebuild and to have a spare just in case.
My reason for the junkyard way is it's the cheapest option and still trust a used OEM more than a 'new' rebuild after hearing the state of rebuilds lately.
Thoughts?
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511655
09/09/17 03:59 PM
09/09/17 03:59 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Most bone yards give a 30 day warranty and if the pump lasts that long its probably going to last a lot longer with a couple oil changes. So many neglect changing fluids.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511665
09/09/17 04:15 PM
09/09/17 04:15 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
I rather throw in a low mileage junkyard pump/rebuild original pump or go with brand new OEM.
What's the mileage on the original pump? Mine is still going at 165,000mi with regular DexVI fluid changes.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Power Steering Pump & Rebuild Kit Options? [Re: Kibitoshin] #4511696
09/09/17 04:57 PM
09/09/17 04:57 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
+1. Just go for the junkyard pump. Rebuilt one failed on my Sienna and I went with another junk yard one after that.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511703
09/09/17 05:03 PM
09/09/17 05:03 PM
California
Kool1 Offline
Kool1  Offline
California
Personally aftermarket rebuilt power steering pumps have been nothing but problems for me. The only luck I have is when I use OEM new or OEM remanufactured power steering pumps.
Junkyard power steering pumps are a [censored]. If it's easy to get to in your engine compartment and not hard to change with a deep discount compared to the dealer, I'd give one a shot.
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511713
09/09/17 05:15 PM
09/09/17 05:15 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I would go straight to RockAuto and see what they had. They got better parts than what you can get locally for about half the price.
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511750
09/09/17 06:37 PM
09/09/17 06:37 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
I have a Cardone reman'd pump that's been working fine for 2 yrs *knock on wood.* A lot of people have had bad luck with them, though.
You should just go with a brand new or good condition used one. Don't want to do the job twice, especially if your pump is hard to access.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511770
09/09/17 07:21 PM
09/09/17 07:21 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
What is your pump doing? Just grumbling (bearing), or leaking, or...?
I rebuilt the one in our Lexus sedan 2 years ago, and the one in my SUV last month. It's easy and about $20 + a quart of fresh fluid. Then you know it's done correctly. I am not above using junkyard parts when necessary, but this isn't an efficient situation for that. The trickiest this repair gets is if the pulley is pressed on and you need to use a 3-jaw puller to remove it - and those can be borrowed for free from the LAS. $12 for a seal kit, $10 for a bearing, a Saturday afternoon, and you're done.
I almost always find that to be true.
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511913
09/09/17 10:14 PM
09/09/17 10:14 PM
ME
eljefino Offline
eljefino  Offline
ME
+2 on the pulley situation, more hassle than a junkyard one.
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511959
09/09/17 11:26 PM
09/09/17 11:26 PM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
Lexus sells a rebuild kit for the pumps a few bolts & everything comes apart easily. It's not hard replacing the seals on those. The bearing will be fine more than likely. If you need to change the bearing, it's held on with a snapring & a deep socket will fit over the shaft to tap the bearing off.
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4511968
09/09/17 11:52 PM
09/09/17 11:52 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I don't buy reman unless its OE from the dealer but most of the time I buy new if its available. I got so sick of changing bad PS pumps and wasting my time I find it to be the best and in the long run the cheapest option.
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4512656
09/10/17 08:15 PM
09/10/17 08:15 PM
Phladelphia
NYSteve Offline OP
NYSteve  Offline OP
Phladelphia
Thanks for all the input everyone. Need to research the bearing replacement as I am getting intermittent groaning that is the issue. With the pulley, it is splined and no pulled is needed per a few forum threads. Also, to remove the pump is disconnect the hoses, 2 bolts and 1 nut/stud and that is all. Not too bad there either.
Will keep everyone posted.
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4512666
09/10/17 08:33 PM
09/10/17 08:33 PM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
Just something to bear in mind....there is no cheap way to rebuild a power steering pump (and add modern AC compressors and CV joints to that as well).
Sometimes you luck out and catch a bad bearing early, and salvage a pump before the rotating components grind up the rotor vane/roller housing. Usually you don't. There is no cheap way to resurface and replate the rotor housing so most places attempt to polish the housing, and throw new vanes/rollers in the old rotor, and call it a day. If cost is primary, and labor is free, go rebuilt and budget your free time to do the job again. Don't get me started on power steering racks...........
Re: Power Steering Pump & Rebuild Kit Options? [Re: NYSteve] #4512797
09/10/17 11:54 PM
09/10/17 11:54 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
Stay far away from parts store pumps. Will be a never ending headache you will wish you just went to the dealer. I replaced 3 Oreilly's power steering pumps on my BMW, 2 on my Toyota truck. The BMW I finally just got a refund and put an OEM pump. The Toyota I sold and was starting to moan and groan again. They will either leak or just be so noisy it's embarrassing. Horrible and I will never again put a parts store Reman/rebuilt pump on my personal vehicles again. Don't buy into the "you didn't flush or have air in the system...." they are just junk. I put an OEM pump on my BMW and F-150. No noise, no leaks no nothing. Just work with no 100 step flush, purge, refill, reflush, vacuum, check barometer.....
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: Power Steering Pump & Rebuild Kit Options? [Re: punisher] #4514363
09/12/17 04:21 PM
09/12/17 04:21 PM
Phladelphia
NYSteve Offline OP
NYSteve  Offline OP
Phladelphia
This is exactly what I was looking for. Will be going new OEM.
Thanks everyone!
