A guy with a 2013 Ecoboost F150 stopped by to pick up a horse and we talked vehicles.
He's got just over 200K miles and all of them with conventional Castrol 20w-50 at 5K intervals with Motorcraft filters. All his driving has been in the desert, high desert or mountains and mostly towing. He's had nothing done except routine maintenance. What he called 5w-20 oil can't be repeated here so I take it he prefers a bit thicker oil. He's had trips where he's towing maximum weight for 8-10 hours in the desert with temps in the triple digits and he won't risk his rig to thinner oils.
He also changes his air filter based on a delta gage and he's added a really big gas filter/water separator with a warning light and a coolant filter with a sacrificial anode along with an extra really big tranny cooler and a spin on filter with synthetic tranny fluid with a drain and refill every 30K miles. The diff also gets a heavier synthetic oil changed every 30K miles.
As hard as he works his truck I'd say he's doing okay with his changes.
I just thought BITOG members might like to hear what someone is doing with their Ecoboost in a real working truck.
