Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
28 registered members (BlakeB, 53' Stude, Ablebody, Duke, Drosselmier, 4 invisible), 758 guests, and 39 spiders.
Topics290,746
Posts4,849,464
Members66,033
Most Online3,590
Jan 24th, 2017
HM oil help with smog? #4507918
09/05/17 09:28 AM
09/05/17 09:28 AM
Rocklin, CA USA
Nicasio Offline OP
Nicasio  Offline OP
Rocklin, CA USA
I know HM oils help with rubber seals so would you say that would be good for our strict Cali emissions/SMOG checks?
2017 Nissan Armada AWD Platinum
2011 Honda Civic DX
2007 Subaru Impreza 2.5i Wagon
2006 Pontiac Vibe
2004 BMW 330i ZHP 6sp
1989 Mustang w/Vortech S/C 351w
Re: HM oil help with smog? [Re: Nicasio] #4507929
09/05/17 09:37 AM
09/05/17 09:37 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
I guess potentially, if you had some leaky valve stem seals that was slowed by the HM oil. No other seals in the engine could really affect exhaust emissions though...
They only tailpipe test cars that are model year 99 and older though. Anything 2000 or newer is just a check of obd2 monitors, visual and function test.
So for 2000 and later cars, no. It won't help.
Re: HM oil help with smog? [Re: Nicasio] #4507935
09/05/17 09:44 AM
09/05/17 09:44 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
If you are having problems passing smog due to oil consumption (primarily) there isn't much you can do to help it.
Maybe adding 6 bottles of STP might help it pass,,,,, maybe not
Re: HM oil help with smog? [Re: Nicasio] #4508046
09/05/17 11:57 AM
09/05/17 11:57 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Always change your oil just prior to a smog check
Re: HM oil help with smog? [Re: bigj_16] #4508195
09/05/17 03:45 PM
09/05/17 03:45 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
My 83 Silverado with the 305 has leaky valve guide seals for the last 25 yrs, smokes on the first start of the day, burns off and your good for the rest of the day, use Pennz High Mileage oil, she's passed all here smog checks, key is a good tuneup and oil change before going in for the test and a HOT engine, take my truck out on the highway and run high speeds for about 10 miles then straight to the smog station, been using Guaranteed to Pass fuel additive in the tank, don't know if it works but hey every little bit helps and she hasn't failed yet. Cheers2
Re: HM oil help with smog? [Re: bigj_16] #4510178
09/07/17 04:41 PM
09/07/17 04:41 PM
Rocklin, CA USA
Nicasio Offline OP
Nicasio  Offline OP
Rocklin, CA USA
Agreed. I always make sure of this. I remember a friend of mine with his minty IROC Z that he rarely drives failed smog. Had low miles, but oil went bad from sitting too long. Went home & changed the oil & passed SMOG the next day lol
2011 Honda Civic DX
2006 Pontiac Vibe
