Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
83 registered members (4WD, 2004tdigls, 4ever4d, 2002 Maxima SE, 69GTX, 7 invisible), 1,964 guests, and 37 spiders.
Topics295,103
Posts4,927,848
Members66,688
Most Online2,553
Oct 27th, 2018
U joint grease #4506493
09/03/17 04:59 PM
09/03/17 04:59 PM
texas
danez_yoda Offline OP
texas
I replaced my U-joints from the permanently sealed ones to MOOG one with the little tiny grease port (I hate that thing)
When I installed the MOOG I remove the grease that was in there and replaced with Green Grease http://www.autozone.com/greases-and-gear...ease/945652_0_0
After installation I pumped (with the special adapter) until green grease can out all 4 corners on all three U-joints.
At 5K Miles on I greased them again with the same grease and gun and much to my surprise It tool quite a few pumps to get old grease coming out of the caps. I had a light on them and all three joints did the same. I could see quite a splatter of grease on the underside of the truck so it looks like it got slung out of the caps. frown
Is there a better grease for U joints on a DD (2007 Tacoma) that pull a boats a couple times a month?
I don't like the idea of the joints running dry between oil changes. ;/ AND I'm not crawling under there every gas fillup either.
Re: U joint grease [Re: danez_yoda] #4506498
09/03/17 05:06 PM
09/03/17 05:06 PM
Northern, NY
Rob_Roy Offline
Rob_Roy  Offline
Northern, NY
If you are looking to stay with a lithium complex grease, check out Delo ESI, and Mystik JT-6 High temp.
If you have seen the light and want something other than a lithium complex grease, there are good options available from AMSOIL, Schaeffer, Texas Refinery, etc.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: U joint grease [Re: danez_yoda] #4506509
09/03/17 05:20 PM
09/03/17 05:20 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
To much work for me I would toss them as fast as I put them in for maintenance free ones. If you stick with those horrors I would use Mobil 1 synthetic grease. The driveshaft shop I use also makes driveshafts and thats all they recommend.
I tried Green grease once and promptly tossed it in the trash, its too stringy and thick for my liking, I really cant think of any application for the stuff.
Re: U joint grease [Re: danez_yoda] #4506527
09/03/17 05:42 PM
09/03/17 05:42 PM
NC
BigD1 Offline
BigD1  Offline
NC
I tossed a set of grease jobbers, and went with the Spicer sealed for my Toyota pickup. Better all the way around, and the sealed are actually a higher quality u-joint.
1992 Toyota Pickup--Harvest King Premium 10W-30--Fram PH3614
Re: U joint grease [Re: danez_yoda] #4506530
09/03/17 05:44 PM
09/03/17 05:44 PM
snow and sun
oliveoil Offline
oliveoil  Offline
snow and sun
286k on M1 grease and no replacemt of U-Joints on a 1996 Tacoma V6 4x4, greased at every 10k OCI.
Re: U joint grease [Re: danez_yoda] #4506585
09/03/17 06:26 PM
09/03/17 06:26 PM
texas
texas
I switched away from the sealed Spicer ones because I wore one out at 70K miles. Stock suspension and normal daily driving.
The other caps 11 looked good with lots of grease and still blue in color. The bad one ground the needles down to powder and the end to a nub about 3/4 the diameter it should have been. Made an alarming vibration at certain speeds. I thought it was tires...nope drive axle. This was the U-joint on the rear end.
I figured the seal leaked so why not just get the ones you grease at every oil change. I'm under there anyway waiting for the oil to drain and only 3 zerks... whats the big deal?
Re: U joint grease [Re: danez_yoda] #4506604
09/03/17 06:37 PM
09/03/17 06:37 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I have been using.....grease with moly in mine! Usually the black valvoline grease.
Some will say thats the wrong grease but I have over 200k between 2 cars and so far so good.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
