Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pennzoil must not be selling , OR ?
by Kjmack. 09/25/18 11:51 AM
New black car, light swirls and water spots
by Redright9. 09/25/18 11:37 AM
Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Interesting video of diff with clear cover
by mrdctaylor. 09/25/18 10:15 AM
The death of American footbal
by Brigadier. 09/25/18 10:01 AM
Tire leaking from bead/rim
by Brybo86. 09/25/18 09:39 AM
2000 4Runner 3.4L
by ka9mnx. 09/25/18 08:59 AM
VW 508 Spec 0w20 Updates?
by Zee09. 09/25/18 08:36 AM
Laptop Recommendations
by buster. 09/25/18 08:24 AM
Mac OSX Mojave - vid card requirements
by OVERKILL. 09/25/18 08:05 AM
Age of first drive
by madRiver. 09/25/18 08:02 AM
Peppz, Jfa02, ibsfusion, Fearcat707, Perseo
66069 Registered Users
109 registered members (14Accent, 2010Civic, 16HC, 2009Edge, 2004tdigls, 10 invisible), 1,541 guests, and 40 spiders.
Topics290,996
Posts4,854,018
Members66,069
Most Online3,590
Jan 24th, 2017
2017 Trax #4506154
09/03/17 10:44 AM
09/03/17 10:44 AM
CentralPA
SilverGt Offline OP
SilverGt  Offline OP
CentralPA
I am currently using Castrol Edge 5w-30 in my DI Turbo Trax Would there be any harm in using the German Castrol Edge 0w-40 that I already use in my BMW ? I'll admit I'm a bit concerned with making this little turbo engine last
1984 Ford Mustang GT Castrol GTX 10w-40
2017 Chevrolet Trax Castrol Edge 5W-30
2003 BMW 325xi. Castrol Edge 0w-40
Re: 2017 Trax [Re: SilverGt] #4506160
09/03/17 10:51 AM
09/03/17 10:51 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
0w40 will work fine but id stick to mfr requirements while under warranty. Are you worried that 0w40 will protect better than 5w30? Id doubt much of a difference.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 2017 Trax [Re: SilverGt] #4506170
09/03/17 11:10 AM
09/03/17 11:10 AM
Winnipeg, Manitoba
mkskud Offline
mkskud  Offline
Winnipeg, Manitoba
my 2014 Trax 1.4T calls for 5w30 dexos1 or 0w30 dexos1 as a cold weather option.
Re: 2017 Trax [Re: SilverGt] #4506205
09/03/17 11:47 AM
09/03/17 11:47 AM
CentralPA
SilverGt Offline OP
SilverGt  Offline OP
CentralPA
I am worried about the DI and how hot the turbo gets the oil I thought the German Castrol would hold up better
Re: 2017 Trax [Re: SilverGt] #4506207
09/03/17 11:48 AM
09/03/17 11:48 AM
CentralPA
SilverGt Offline OP
SilverGt  Offline OP
CentralPA
Mkskud how has your trax been doing for you ?
Re: 2017 Trax [Re: SilverGt] #4506231
09/03/17 12:02 PM
09/03/17 12:02 PM
Texas
JustinH Offline
JustinH  Offline
Texas
Does the 2017 include any free GM oil changes?
I would do that as long as you can, then move to a proper Dexos motor oil that meets spec.
Also save receipts for everything you do to this car.
I would be concerned with always using very good fuel with this turbo engine as well.
Techron would be recommended every oil change as well. It is good insurance for $4 per dose.
'11 Hyundai Sonata GLS
'11 Scion XB
Re: 2017 Trax [Re: SilverGt] #4506237
09/03/17 12:07 PM
09/03/17 12:07 PM
Michigan
MrHorspwer Offline
MrHorspwer  Offline
Michigan
Your Trax doesn't have DI. Trax continues to use the same LUV 1.4L it's always had. This is a port fuel injected engine, not a direct injection.
The Encore is available with the LE2 1.4L in upper trims, which is a DI engine. Lower trims still get the LUV. Trax does not get this option.
Re: 2017 Trax [Re: SilverGt] #4506256
09/03/17 12:35 PM
09/03/17 12:35 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
I think what you have in the sump now is going to work well for you. I have a feeling these small turbos being used now won't be so forgiving to neglect like running a quart or two low and extended ocis on cheap bulk conventional. A Dexos approved oil - especially a full synthetic on a solid oci and checking the oil level regularly will go a long way to making this little turbo last.
2018 Challenger SRT
Re: 2017 Trax [Re: SilverGt] #4506259
09/03/17 12:42 PM
09/03/17 12:42 PM
Elizabeth. Colorado
c502cid Offline
c502cid  Offline
Elizabeth. Colorado
My 2015 Trax has been one of my all around solid value vehicles I have owned. I'm still using Dexos 5w-30 semi syn but will probably go full syn next oil change. 35000 miles on it. Never has used oil between changes.
17 SuperDuty 6.2 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Allison 4x4
00 Blazer 4x4
97/98 Civic's
84 Chev K30 454EFI 4x4
71 GMC Jimmy 502 RamJet
Re: 2017 Trax [Re: SilverGt] #4506266
09/03/17 12:50 PM
09/03/17 12:50 PM
USA
slacktide_bitog Offline
USA
My choice for the Trax would be PP Euro L 5w30, which is dexos2
Re: 2017 Trax [Re: slacktide_bitog] #4506458
09/03/17 05:26 PM
09/03/17 05:26 PM
Western usa
Ammofirst Offline
Ammofirst  Offline
Western usa
I've been considering The PP 5w-30 euro L : Does GM warranty allow Dexos 2 for a gasser in North America ?
Re: 2017 Trax [Re: SilverGt] #4507077
09/04/17 09:55 AM
09/04/17 09:55 AM
Winnipeg, Manitoba
mkskud Offline
mkskud  Offline
Winnipeg, Manitoba
it's a great vehicle, we bought it used, a 1 year old lease return. the only trouble i've had so far (touch wood) is a bad spark plug coil, replaced under warranty of course.
when i first got it, i changed the oil right away. the records showed the couple services it had since new were just oil changes etc, using dealer bulk dexos1 oil i'm assuming. when i changed the oil, the olm was only at around 30% i believe, but man that oil was rough looking. the filter had thick sludgy oil on it, and i could see some pretty thick stuff under the oil filler cap on the valvetrain... i've read that the sonic, cruze, trax 1.4 turbos called for dexos1 and at the time gm dealers sold and used a semi syn ac delco oil, which they may still use... but these 1.4T's are hard on oil and the semi syn ac delco stuff doesn't stand up at all. a short fill of pennzoil platinum sorted that out. since then i've always used a full syn 5w30, mostly pennzoil platinum or mobil 1, all dexos1 of course.
i'll run the olm down to 20% or under, which is about 8000 - 10,000km for me, once a year.
Re: 2017 Trax [Re: SilverGt] #4507081
09/04/17 10:00 AM
09/04/17 10:00 AM
Winnipeg, Manitoba
mkskud Offline
mkskud  Offline
Winnipeg, Manitoba
Re: 2017 Trax [Re: JustinH] #4507087
09/04/17 10:03 AM
09/04/17 10:03 AM
Winnipeg, Manitoba
mkskud Offline
mkskud  Offline
Winnipeg, Manitoba
funny you should mention that... in my '14 trax, for the hotter summer months i'll use mid grade 89 rating gas. i get much better mileage. over the winter i'll run the standard 87 grade gasoline.
