Originally Posted By: MrQuackers
Got a bunch to use if it is AOK.
Depends on how you define "AOK" ...
If by that you ask if the filter will fit, it's easy for you to check and see. Likely nothing bad will happen to the motor as long as the performance and size specs match up.
If by that you mean "Is there any risk to using a non-approved filter that won't qualify for any warranty coverage by the OEM or aftermarket producer, resulting in a fiscal loss, time expenditures, and emotional grief the likes of which I've never experienced before, all for no tangible benefit in filtration effect?", then the answer is it's not AOK.
