Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
40 registered members (Bailes1992, billt460, A1O, Billbert, bbhero, 6 invisible), 643 guests, and 25 spiders.
Topics287,672
Posts4,932,028
Members67,838
Most Online2,967
Mar 10th, 2019
OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? #4497811
08/25/17 02:14 PM
08/25/17 02:14 PM
Oregon
MrQuackers Offline OP
Oregon
Got a bunch to use if it is AOK.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4497823
08/25/17 02:38 PM
08/25/17 02:38 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
If you have clearance and the filter size 3600 doesn't hang lower than the cradle. On my 09' camry I have room to
Spare
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4497825
08/25/17 02:41 PM
08/25/17 02:41 PM
Oregon
Oregon
The OVERSIZE is about 1.5 inches longer.
coffeeMobil 1 USA
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4497830
08/25/17 02:46 PM
08/25/17 02:46 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Yup, if you have the clearance, they will work.
The 4386/3614/3600 are easily interchangeable as far as the specs go, heck, the PH16/PH8A size could also fit if there was room (same gasket size and bypass settings, just a larger diameter can)
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4497838
08/25/17 02:52 PM
08/25/17 02:52 PM
Oregon
Oregon
Also have some PSL20195 from the Kmart clearance.
coffeeMobil 1 USA
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4497839
08/25/17 02:53 PM
08/25/17 02:53 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
My 2010 Fusion specs the FL910s, which is equivalent to the Fram 3614 and the Bosch 3330, but I regularly use the FL400s and Fram 3600 filters.. and I currently have a Bosch D+ 3422 filter on the car.
Yes, they stick out a bit more, but I have never found it to be a problem.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 273,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 63,000mi
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4497852
08/25/17 03:08 PM
08/25/17 03:08 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
A little more surface area just means the bypass valve never opens!
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4498013
08/25/17 06:14 PM
08/25/17 06:14 PM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Depends on how you define "AOK" ...
If by that you ask if the filter will fit, it's easy for you to check and see. Likely nothing bad will happen to the motor as long as the performance and size specs match up.
If by that you mean "Is there any risk to using a non-approved filter that won't qualify for any warranty coverage by the OEM or aftermarket producer, resulting in a fiscal loss, time expenditures, and emotional grief the likes of which I've never experienced before, all for no tangible benefit in filtration effect?", then the answer is it's not AOK.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4498052
08/25/17 06:55 PM
08/25/17 06:55 PM
Oregon
Oregon
Thank you for stopping by DN3 smile
Yep, I know a filter company will not back a non specified filter. That is a given.
Have a wonderful day laugh
coffeeMobil 1 USA
Re: OK to use OVERSIZE (D3422, XG3600 etc) for Mazda5? [Re: MrQuackers] #4498110
08/25/17 08:09 PM
08/25/17 08:09 PM
New York
pbm Offline
pbm  Offline
New York
I bought several of these filters at the WM Clearance and I checked fitment on my Escape 2.5.....the bottom of the filter is still higher than the oil pan and front frame....I don't see any problem using them in my FL-910 supplication. I haven't checked fitment on my 2014 Focus but if the bottom of the filter is above other body/engine parts ..I'll use them in that application too.
'Journalism is Dead'
