Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
91 registered members (Al, 28oz, andyd, ABomb369, 2009Edge, 2004tdigls, 11 invisible), 1,705 guests, and 49 spiders.
Topics290,666
Posts4,847,917
Members66,011
Most Online3,590
Jan 24th, 2017
Fuel product for cleaning out catalytic converter? #4496071
08/23/17 12:07 PM
08/23/17 12:07 PM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
I have no idea if any such product exists, but right now I'd love to get my hands on one if I could. I just spend $930 on getting one replaced (price includes gaskets that were needed as well), and he warned me that there was another one on the Sienna, implying that that might need to be replaced as well at some point in the future.
I trust this guy--that's not the issue. I'm just wondering--is there something like techron that I can pour into the gas tank, that will help clean out the catalytic converter?
2005 Toyota Sienna LE; 156,000 miles
1998 Honda Civic DX; 202,000 miles
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496078
08/23/17 12:17 PM
08/23/17 12:17 PM
MN
Tman220 Offline
Tman220  Offline
MN
No additive that I could think of would make any difference at all.
The best additive as long as the Cats aren't too far gone already, is your right foot, use it! use it hard and use it often.
The best way to clean and keep a cat clean is heat, and working oxygen sensors of course.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496082
08/23/17 12:21 PM
08/23/17 12:21 PM
Toronto, Canada
KrisZ Online happy
KrisZ  Online Happy
Toronto, Canada
Nope.
There are some youtubers (ETCG maybe) that soaked the catalytic converters in mild acids or some other solution that was supposedly clean up the cats, with little to no effects. So if something like that doesn't seem to work, there is no way that a fuel additive will.
2015 Dodge Grand Caravan-27k miles.
2006 Mazda 3-163k miles
Re: Fuel product for cleaning out catalytic converter? [Re: Tman220] #4496084
08/23/17 12:23 PM
08/23/17 12:23 PM
Toronto, Canada
KrisZ Online happy
KrisZ  Online Happy
Toronto, Canada
Agreed. It also helps if the engine is not an oil burner.
Re: Fuel product for cleaning out catalytic converter? [Re: KrisZ] #4496088
08/23/17 12:26 PM
08/23/17 12:26 PM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
My mechanic mentioned the same thing. I told him that twice in the past couple of years, I've had to add oil (12 oz and 5 oz) to bring it back up to the full line, so it appears to be burning up a small amount of oil---but all the other times I've checked it (say, 5-6 times in the past 2-3 years) it has been at the full mark on the dipstick.
Originally Posted By: KrisZ
[quote=Tman220] It also helps if the engine is not an oil burner.
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496089
08/23/17 12:38 PM
08/23/17 12:38 PM
Toronto, Canada
KrisZ Online happy
KrisZ  Online Happy
Toronto, Canada
That's not an oil burner. When the oil level goes to the low mark, or below, during the regular OCI, that's an oil burner and even then a mild one.
Catalytic converters do go out. It's can be cause by many different things, like lots of short trips, poor quality gas, misfires, pre-ignition, etc.
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496090
08/23/17 12:38 PM
08/23/17 12:38 PM
Florida
bozo66 Offline
bozo66  Offline
Florida
I had that problem on a 2002 Toyota Solara, probably due to leaking valve stem seals; however I cleared it up by running lacquer thinner in the gas tank. As shown on Scotty Kilmer.com, it took two attempts and the code hasn't returned in two years.
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496092
08/23/17 12:40 PM
08/23/17 12:40 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Why did you replace the original cat? Was it clogged, damaged, flunk emissions? You burn out a cat by getting it hot then disconnecting the FPR vacuum hose so it will run rich. Then drive it for a half hour in 2nd to keep up the RPM and not get arrested. Reconnect the Vacuum hose and continue the Italian tune up. Did the mechanic replace or even test the O2 sensors?
Thick oil is better grin2
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496094
08/23/17 12:42 PM
08/23/17 12:42 PM
London, England
bigjl Offline
bigjl  Offline
London, England
THere is Ann additive in the UK called Cataclean that has been proven to work.
It is often used when a car fails its annual MOT emissions check.
A car trade magazine tested it and found that it improved emissions.
I have used it a couple of times on newly purchased runarounds and cars I had bought to resell to good effect.
If memory serves it also cleans up the lambda sensors aswell.
https://www.cataclean.com/
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496101
08/23/17 12:53 PM
08/23/17 12:53 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I think our sienna actually has 3 cat's. The service records on mine with 278k miles indicates that 2 of them have been replaced. I am just hoping the third or any of them go anytime soon. My sienna doesn't burn oil within a 5k OCI. Expensive fix though. Just know that your 3.3 in your sienna will go the distance, it is very reliable.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496103
08/23/17 12:55 PM
08/23/17 12:55 PM
Utah
CKN Offline
CKN  Offline
Utah
There is absolutely no harm in NOT ADDING that oil to "top off" your crank case-with 5 to 12 oz of oil.(Your dipstick isn't that accurate to require that little oil). As others have said-that's not an "oil burner".
Re: Fuel product for cleaning out catalytic converter? [Re: TheKracken] #4496107
08/23/17 01:04 PM
08/23/17 01:04 PM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
Yes, I realize it is reliable. I took it to 8K conventional OCIs for the first 120K of its life and the darn thing never complained. smile I know better now, though.
If I average out the $930 over the last few years (this is the first non-maintenance bill I've had in several years---all the rest have been tires, brakes, etc.) this is pretty decent, and I suppose it could have happened regardless of what car I drove.
My mechanic never mentioned testing 02 sensors. He might have, I don't know. But I've taken my cars to him too many times for noises, only to get a call back later in the day with "nothing's wrong," and not even being charged a diagnostic fee, I don't question him at this point. The guy has proven his competence and his honesty, so I pay when he says pay and I don't when he doesn't.
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496109
08/23/17 01:06 PM
08/23/17 01:06 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Clogged catalysts are a good thing ! It's how the toyota reduces exhaust pulsation and drone for a smooth quiet ride. Some people really value that. Also it smooths out accelerator response by restricting exhaust flow for smooth driving and transient response. Also, other cars simply just burn oil because they suck and that's a pain and inconvenience but in the toyota, this is the exclusive automatic oil changing feature. All you need to do is add oil! How amazing is that?
Just take care of all the defects, be extra vigilant with the auto oil changer and keep fixing everything that goes out and you've got a 10,000,000 mile engine right there. laugh
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496133
08/23/17 01:35 PM
08/23/17 01:35 PM
N.H, U.S.A.
ARCOgraphite Online content
ARCOgraphite  Online Content
N.H, U.S.A.
If all ELSE is well ( AF metering, Lambda sense, etc)
Hardware/paint store stuff:
1 pint of Xylene, 4 oz Acetone and 1 pint of Toluol mixed over 2 gallons of gas into ~ 1/2 tank ( 6-10 gallons total)
Drive normally for day or 2 until car runs well then start to give it the Italian tune. WOT 2K up to 4K then gradually up to 5K. Let car cool after 2 or 3 ramp ups then do it again.
Best accomplished on the highway during non peak hours.
Let us know how it went if it didn't grenade.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Fuel product for cleaning out catalytic converter? [Re: paulri] #4496144
08/23/17 01:48 PM
08/23/17 01:48 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I just had the 3 catalyst y pipe replaced on my 06 Escalade because it was falling apart and rattling inside the pipes. First catalyst that has failed for me, first vehicle I've owned in 30 years that doesn't burn a drop of oil. The tailpipe so clean you can see surface rust inside. Maybe a little soot isn't so bad after all. Must have dried out, dehydrated and fell apart being so clean for 150k.
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
