Getting ready to do the spark plugs on my Liberty, switching out the NGK Vs for more of the same. Aluminum heads for FWIW. I've done them by hand always, but always open to a better/safer method, would using an air ratchet be a safer bet for removal? As in, less likely to result in broken plugs or damaged threads. I do it when the engine is cold.
Thanks!
Thanks!
