It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
71 registered (2009Edge, 2015_PSD, 63Marauder, badtlc, 10 invisible), 1189 Guests and 36 Spiders online.
65319 Members
67 Forums
285956 Topics
Page 1 of 2 1 2 >
#4490391 - 08/16/17 05:51 PM Spark plugs removal: Air ratchet or by hand
HoosierJeeper Offline
Loc: WI
Getting ready to do the spark plugs on my Liberty, switching out the NGK Vs for more of the same. Aluminum heads for FWIW. I've done them by hand always, but always open to a better/safer method, would using an air ratchet be a safer bet for removal? As in, less likely to result in broken plugs or damaged threads. I do it when the engine is cold.
Thanks!
Edited by HoosierJeeper (08/16/17 05:56 PM)
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4490397 - 08/16/17 06:00 PM Re: Spark plugs: Air ratchet or by hand [Re: HoosierJeeper]
bioburner Offline
Loc: Minnesota
I am for by hand.
After you park the warmed vehicle give the plugs a shot of penetrating oil to hopefully soak the threads and allow a easy extraction. I know Ford was requesting owners to bring in their trucks the night before so they could soak the plugs overnight.
Edited by bioburner (08/16/17 06:00 PM)
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4490402 - 08/16/17 06:02 PM Re: Spark plugs: Air ratchet or by hand [Re: HoosierJeeper]
eljefino Offline
Loc: ME
Get 'em loose by hand. If you're amazingly lazy use the ratchet after that but IMO it's overkill and with the weight of the hose etc you could cock a plug sideways.
#4490409 - 08/16/17 06:09 PM Re: Spark plugs: Air ratchet or by hand [Re: eljefino]
ArcticDriver Offline
Loc: USA
Agreed.
By hand you can "feel" if something is amiss and quickly stop.
Multiple Diesel and Gasoline vehicles
#4490416 - 08/16/17 06:14 PM Re: Spark plugs: Air ratchet or by hand [Re: HoosierJeeper]
danez_yoda Offline
Loc: texas
Hand,
Use the ratchet to break it loose the take theratchet off the extension and unscrew by hand. This is when will appreciate a knarled extension.
#4490422 - 08/16/17 06:24 PM Re: Spark plugs: Air ratchet or by hand [Re: HoosierJeeper]
9050lx Offline
Loc: FL
I wonder if a bit of rattle from an impact on an extremely low torque setting would help free some of the tight ones.Sometimes tightening slightly then untightening will help with removal.Would use an impact only at low torque for a couple seconds just to free them up.A 1/2 inch ratchet helps leverage in loosening the tight ones.
#4490425 - 08/16/17 06:31 PM Re: Spark plugs: Air ratchet or by hand [Re: HoosierJeeper]
slacktide_bitog Offline
Loc: USA
Do it by hand, and remember, never use any anti-seize on any NGK spark plugs smile
#4490428 - 08/16/17 06:41 PM Re: Spark plugs: Air ratchet or by hand [Re: HoosierJeeper]
AirgunSavant Offline
Loc: MD
Absolutely by hand.
#4490432 - 08/16/17 06:44 PM Re: Spark plugs removal: Air ratchet or by hand [Re: HoosierJeeper]
Merkava_4 Offline
Loc: Clovis, CA
I use a nut driver to take spark plugs out. I'm anti-air ratchet.
#4490435 - 08/16/17 06:45 PM Re: Spark plugs: Air ratchet or by hand [Re: AirgunSavant]
Kira Offline
Loc: Champlain/Hudson Valley
^^THAT^^
I'm thinking the question was one of those "fun ones".
I don't get all out of shape and use the word, "trolling" as many would because I don't know what it means exactly.
Everybody know that impact guns are used for plug installation ONLY.
And be blithe about it. The plugs will center themselves. (See, how do you like it?)
#4490438 - 08/16/17 06:48 PM Re: Spark plugs removal: Air ratchet or by hand [Re: HoosierJeeper]
2015_PSD Online   content
Loc: SE Texas
OT
I saw more than a few guys on YT using an impact wrench on Ford Triton V8 engines to prevent the two piece sparkplugs from breaking off in the head. Worked infinitely better than a presoak.
2018 MB AMG GLC43 3.0L Coupe - M1 0W-40/OEM
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 5W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
#4490439 - 08/16/17 06:49 PM Re: Spark plugs: Air ratchet or by hand [Re: 9050lx]
eljefino Offline
Loc: ME
With your typical six inch extension in the mix the extension will soak up that rattle.
I do use a battery powered impact driver to take off the dumb engine cover via its 10mm fasteners as well as the coils-on-plug. Perfect for that.
#4490444 - 08/16/17 06:52 PM Re: Spark plugs: Air ratchet or by hand [Re: slacktide_bitog]
Loc: WI
Thanks for the help everyone...sounds like by hand is the best. Will do.
I did last time...hope that won't be an issue for removal! First I've heard that about NGK plugs.
#4490454 - 08/16/17 07:00 PM Re: Spark plugs: Air ratchet or by hand [Re: HoosierJeeper]
Trav Offline
Loc: MA, Mittelfranken.de
If yu live in a salt area use the never seize even on NGK. NGK claims its coating prevents seizure, it doesn't always and the do not use is just a legal disclaimer.
I have had many coated NGK plugs seize in aluminum heads after years or being in there and been a real sweat getting them out.
#4490461 - 08/16/17 07:03 PM Re: Spark plugs: Air ratchet or by hand [Re: HoosierJeeper]
Loc: WI
Ok cool, these have been in for 2 years/25k miles, so hopefully nothing is stuck! I do live in very salty area. Is copper antiseize ok to use? It's what I used the past few times.
Page 1 of 2 1 2 >
