Tire on Church 15 Passenger Van
by Gebo
14 minutes 58 seconds ago
Battery Disconnect Switch?
by Pike51
38 minutes 30 seconds ago
03 Maxima Cam sensor questions
by LeakySeals
Today at 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
Today at 11:08 AM
2006 Prius
by Kira
Today at 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
Today at 10:18 AM
Mouse Visiting Car
by Ifixyawata
Today at 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
Today at 10:00 AM
Let's Talk Bed Pillows
by LoneRanger
Today at 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
Today at 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
Today at 08:41 AM
CVT Discussion
by Sierra048
Today at 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
Today at 07:34 AM
Need mini grease gun
by Duffyjr
Today at 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
Today at 06:57 AM
Brake Bleeder
by supton
Today at 06:56 AM
As close to blowing out as you can get
by wwillson
Today at 06:04 AM
changing tranny filter
by Dennisistheman
Today at 06:04 AM
From small things...
by Silk
Today at 05:57 AM
Anyone signing up for the Space Force
by Shannow
Today at 03:58 AM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
89 registered (03s, billt460, ARB1977, BillyTheKid, 2015_PSD, 14 invisible), 1628 Guests and 41 Spiders online.
65276 Members
67 Forums
285649 Topics
Page 1 of 2 1 2 >
#4490102 - 08/16/17 11:51 AM Does Tundra breaks have the same problem as Ford?
CaptainFreon Offline
Loc: Indiana
When Ford loses break fluid for one wheel, all four wheels lose break. That has happened more than once on my 97 F-150. Another man said the same on his newer Ford.
I did not have that problem on the one 1980's-ish GM I had. I was told the GM master cylinders keep rear and front separate, so that you have at least TWO breaks working....Unlike Ford. Ford's design could have killed me once.
How does Toyota Tundra's breaks compare?
Thank you.
#4490115 - 08/16/17 12:01 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
cookieman214 Offline
Loc: SC
Thank you.
In the industry, this is referred to as "Breaks Broke"
#4490121 - 08/16/17 12:04 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
L_Sludger Offline
Loc: Ohio
The only fuel I want to throw on this genuine dumpster fire of a thread is the following historical note.
When hydraulic brakes were developed in the late 1930s, Henry Ford stubbornly refused to incorporate them into the Ford lineup. They even marketed their prehistoric mechanical braking system as "The Safety of Steel from Pedal to Wheel"
Oh, and the Tundra has a dual circuit brake system.
ps, dual circuit brakes have been Federally mandated for fifty years.
too many cars and oil combinations to list in 150 characters or less
#4490124 - 08/16/17 12:07 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
SoNic67 Offline
Loc: VA, US
Isn't the F150 dual circuit?
Probably you lost the front circuit and the rear brakes, on any truck, can't do too much when bed is empty (proportioning valve is basically closed, so no braking on rear).
Edited by SoNic67 (08/16/17 12:09 PM)
#4490125 - 08/16/17 12:10 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
exranger06 Offline
Loc: Guilford, CT
Pretty much all modern vehicles, including your 97 Ford, have dual circuit brakes. The problem is it's not a very effective system. If you bust a brake line, you're basically going to have no stopping power, even if you have dual circuit brakes.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
#4490139 - 08/16/17 12:28 PM Re: Does Tundra breaks have the same problem as Ford? [Re: exranger06]
Loc: Indiana
Dual circuit or not... What you said is EXACTLY what happens. This is the 3rd time.
ty
#4490144 - 08/16/17 12:31 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
MNgopher Offline
Loc: Lakeville, MN
Dual braking systems have only been mandatory since the government mandates their use in 1967 - 50 years ago.
If your 97 F150 was like mine, it had drum rear brakes, which when out of adjustment and combined with the abs brakes could feel like no brakes..
#4490162 - 08/16/17 12:51 PM Re: Does Tundra breaks have the same problem as Ford? [Re: MNgopher]
Loc: Indiana
All the fluid squirts out of a rotted break line. master cylinder empties, and peddle is dead at floor. Perhaps there is something else wrong ?
#4490213 - 08/16/17 01:55 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
HerrStig Offline
Loc: Boston, MA
Vehicles have BRAKES. Dual circuit master cylinders have a divided master cylinder reservoir, one circuit can empty and fluid will remain in the other part of the reservoir. As others have mentioned, if the front brakes develop a leak the rears will still work, but rear drums don't work that well on a pickup with no load because of a valve which is supposed to compensate for the lack of traction and reduce lockup. Regards to Mr. Dunning and Mr. Kruger.
Edited by HerrStig (08/16/17 02:02 PM)
#4490235 - 08/16/17 02:24 PM Re: Does Tundra breaks have the same problem as Ford? [Re: HerrStig]
Loc: Indiana
Why would the master cylinder empty, losing all breaks with a bad leaking rear wheel break line?
bad master cylinder?
Edited by CaptainFreon (08/16/17 02:24 PM)
#4490239 - 08/16/17 02:28 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
Cujet Offline
Loc: Jupiter, Florida
It's always possible the rear brake cylinders are frozen. The Ford system on the late 90's trucks were absolutely dual systems. However, the loss of the front does not mean the other works normally. It does not. The pedal will go to the floor and the truck will not have any significant braking power even with the rear system 100% intact. They are drum brakes, and there is little pressure actuating them, as the pedal will move to the floor. The dual master cylinder has no way to maintain a firm pedal with the loss of one system.
Modern vehicles with anti lock brakes have their own set of more complicated problems. Especially as they age.
#4490251 - 08/16/17 02:46 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
mcrn Offline
Loc: FL
Brakes
2012 Nissan Rogue
#4490255 - 08/16/17 02:59 PM Re: Does Tundra breaks have the same problem as Ford? [Re: mcrn]
4WD Offline
Loc: Texas
Are they covered by the 20 year extended warranty?
#4490260 - 08/16/17 03:10 PM Re: Does Tundra breaks have the same problem as Ford? [Re: mcrn]
Bandito440 Offline
Loc: NEUS
Originally Posted By: mcrn
Brakes
Brakes broke
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
#4490267 - 08/16/17 03:22 PM Re: Does Tundra breaks have the same problem as Ford? [Re: CaptainFreon]
Starman2112 Offline
Loc: East Tennessee
Gimme a brake...
2010 Toyota Camry LE 2.5L, Mobil 1 AFE 0W-20, OEM filter
1998 Nissan Frontier XE 2.4L, Castrol GTX HM 5W-30, M1 filter
Page 1 of 2 1 2 >
