Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
108 registered members (Alfred_B, aquariuscsm, ArrestMeRedZ, acme, 69Torino, allgm59, 8 invisible), 2,049 guests, and 62 spiders.
Topics286,236
Posts4,904,936
Members67,582
Most Online2,967
Mar 10th, 2019
Bubbles on dipstick #4486328
08/12/17 07:37 AM
08/12/17 07:37 AM
Denmark
shDK Online content OP
shDK  Online Content OP
Denmark
Hi all.
As i wrote in a threat yesterday. My car has a overfill that is About 1 cm on the dipstick. Today i saw Really Really tiny bubbles on the dipstick. But only on one side of the dipstick. And no foam. Do people think those bubbles are a result of the oil being wipped by the crankshaft?
Thanks all.
Søren
Re: Bubbles on dipstick [Re: shDK] #4486333
08/12/17 07:48 AM
08/12/17 07:48 AM
PimTac Offline
PimTac  Offline
Possibly. I would drain some out to correct it.
Cannot see signatures any longer so it doesn’t matter.
Re: Bubbles on dipstick [Re: shDK] #4486340
08/12/17 08:02 AM
08/12/17 08:02 AM
Denmark
Denmark
Og is just after i shut i off. And it Goes away within a minute
Re: Bubbles on dipstick [Re: PimTac] #4486361
08/12/17 08:24 AM
08/12/17 08:24 AM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
I read your thread yesterday. I am not familiar w/ your engine and how 10cm overfilled would or would not cause an issue.
When you checked the dipstick, did you just pull it out and look at it?
If you pulled it, wiped it and then checked it and it had bubbles, then I would be more concerned.
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
Re: Bubbles on dipstick [Re: shDK] #4486378
08/12/17 08:43 AM
08/12/17 08:43 AM
Denmark
Denmark
It is both Before and after wipe off. But they are less then a mm in size. Othervise the oil is clear and normal in collor
Re: Bubbles on dipstick [Re: shDK] #4486382
08/12/17 08:48 AM
08/12/17 08:48 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Some engines are more sensitive than others to overfill, 1cm over is significant at least 1 litre possibly.
SUV tend to have more leeway for overfill given the all attitude operation. Just think what happened when you are on a 30 deg incline - where is the oil then ? My Rogue doesn't seem to car much and it may even LIKE a 0.5L overfill depending on oil thickness.
Is it easy enough to get the filter off and drain 1/2 litre? Maybe get a small gauge tygon tube and siphon some out?
OTW its back off the drain bung and let some go frown
Re: Bubbles on dipstick [Re: shDK] #4486516
08/12/17 12:36 PM
08/12/17 12:36 PM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
that would indicate a serious issue!
stop leaving shop rags in the engine?
Re: Bubbles on dipstick [Re: shDK] #4486535
08/12/17 01:06 PM
08/12/17 01:06 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
I thought by the thread title that someone had added some bling to their dipstick. Whats next?
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Bubbles on dipstick [Re: shDK] #4486576
08/12/17 02:08 PM
08/12/17 02:08 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I'd drain a little and then you don't have to worry. .5 cm over wouldn't bother me. 1cm is too much imo
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Bubbles on dipstick [Re: shDK] #4486599
08/12/17 02:30 PM
08/12/17 02:30 PM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
I am not sure why the OP keeps agonizing over this issue. Just drain or suck out enough to bring the oil level down to the full line and be done with it.
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Bubbles on dipstick [Re: shDK] #4488294
08/14/17 11:06 AM
08/14/17 11:06 AM
N.H, U.S.A.
N.H, U.S.A.
I can be a pain - if you're OLDER and you just paid somebody else to do the job BC you don't have the time.
I used to do ALL my OCI. Now I do maybe 1/2 the Wifes and 90% of mine; Like out of eight OC in the Nissan, I've done seven of 'em myself.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Bubbles on dipstick [Re: ARCOgraphite] #4488471
08/14/17 03:21 PM
08/14/17 03:21 PM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
This would bother me. Op, if you had someone else do the work take it back. I had that happen once on my Buick, took it back and they understood I wasn't happy so they removed some, they even had to add a little back because they removed to much.
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: Bubbles on dipstick [Re: shDK] #4488542
08/14/17 05:08 PM
08/14/17 05:08 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
