Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Yesterday at 07:08 PM
Wheel says 50 mph max
by pda1122
Yesterday at 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
Yesterday at 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
Yesterday at 06:36 PM
Old Engine SOUND
by MasterSolenoid
Yesterday at 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
Yesterday at 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
36 registered (BoiseBound, alarmguy, billt460, bullwinkle, CB900F2, Blue_Goose, 5 invisible), 894 Guests and 34 Spiders online.
65282 Members
67 Forums
285683 Topics
#4478720 - 08/04/17 05:09 AM 85 Merkur XR4Ti, 2.3T, M1 15w50, 900 Miles
T_Bortz Offline
Loc: Pennsylvania
This was performed after the break initial break in (100-200 miles) with conventional oil.
Comments from Blackstone:
Wear metals read pretty high in this sample compared to averages, but a good amount of this is just lingering wear-in, and that should wash out with time. Note that chrome is pretty high, and that's not a metal we always see reading high in wear-in situations. It shows ring wear, though if it improves going forward, it should be all right. Silicon is from sealers, and it should improve too. Aluminum and iron show piston and steel wear, while copper is from brass/bronze and lead is from bearings. If the engine runs well, just check back next oil for progress.
First Oil Analysis(about 1000 miles on the engine, 800-900 miles in the oil):
Sample Date 7/27/2017
Make Up Oil 0 qts
ALUMINUM 7
CHROMIUM 9
IRON 25
COPPER 46
LEAD 12
TIN 4
MOLYBDENUM 69
NICKEL 2
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 110
SILICON 34
SODIUM 4
CALCIUM 1226
MAGNESIUM 549
PHOSPHORUS 860
ZINC 1032
BARIUM 0
Values Should Be*
SUS Viscosity @ 210F 78.7 75-90
cSt Viscosity @ 100C 15.19 14.3-18.2
Flashpoint in F 430 >380
Fuel % <0.5 <2.0
Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.1 <0.6
#4478783 - 08/04/17 07:01 AM Re: 85 Merkur XR4Ti, 2.3T, M1 15w50, 900 Miles [Re: T_Bortz]
bigt61 Offline
Loc: Virginia
Looks OK at this point, but I'd probably get another UOA in 5-10,000 miles.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4478831 - 08/04/17 08:30 AM Re: 85 Merkur XR4Ti, 2.3T, M1 15w50, 900 Miles [Re: T_Bortz]
Leo99 Offline
Loc: NJ
I had one of those cars. Really bad. Good luck with yours. Mine was possessed. Only had it for a month.
Plenty of information about them online. The oil is the least of your worries.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
#4478856 - 08/04/17 08:51 AM Re: 85 Merkur XR4Ti, 2.3T, M1 15w50, 900 Miles [Re: T_Bortz]
ARCOgraphite Offline
Loc: N.H, U.S.A.
I had one too! Turbo 2.3L correct? I had a problem getting the seats comfortable.
Nice handler with RWD,
what with the 50 grade pseudosynthetic?
Is this boosted?
Id break in with a 20w40 Marine oil.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4478892 - 08/04/17 09:43 AM Re: 85 Merkur XR4Ti, 2.3T, M1 15w50, 900 Miles [Re: T_Bortz]
T_Bortz Offline
Loc: Pennsylvania
Yes, turbo 2.3. The seats are terrible to get a comfortable spot.
Builder rebuilt the motor with loose tolerances, so with the 50 grade, i am getting about 23ish psi oil pressure at idle.
27psi with a big turbo, forged internals, should hopefully last.
#4478942 - 08/04/17 11:05 AM Re: 85 Merkur XR4Ti, 2.3T, M1 15w50, 900 Miles [Re: T_Bortz]
BrocLuno Offline
Loc: Kalifornia Kollective
Only way to know on a rebuilt engine is to run consecutive changes at say 2,500 miles each and watch the trends. If it all comes into line by the third change, you're OK.
Install magnetic drain plug. Check it for excessive "Hair" (Fe metal shavings) and irregular hard cornered bit (broken off something).
Magnet glued on the outside of the oil filter will help too. Cut open filter and look at wall with magnet location for unusual metal bits ...
Recaro seats out of VW Sirocco Special Edition should fix the comfort issue and look age appropriate smile
#4479304 - 08/04/17 08:11 PM Re: 85 Merkur XR4Ti, 2.3T, M1 15w50, 900 Miles [Re: T_Bortz]
Leo99 Offline
Loc: NJ
I didn't notice anything bad about the seats but then, I didn't get to drive it that much before the evil forces took hold and I had to get rid of it before it killed me.
The headliner will fall down.
It's too hot under the hood and it cooks the battery. There are tutorials to move the battery to the trunk. I never got around to doing this.
