Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Geardaddies, 01ws666, ariefnrst, tcoffin014, Schm1d
66658 Registered Users
115 registered members (ad244, 69GTX, 18 invisible), 1,993 guests, and 36 spiders.
Topics294,985
Posts4,925,395
Members66,658
Most Online2,553
Oct 27th, 2018
Miles or Time for 5 speed manual gear lube change #4474811
07/30/17 03:38 PM
07/30/17 03:38 PM
Billings Mt
mtlineman Offline OP
Billings Mt
I have an 06 Tacoma 4 cyl 5 speed with 31000 miles on it. Do I need to change the gear lube in it ? Changed to synthetic in the rear end at 15,000 miles. If I do what do you think of GL4 redline synthetic ? Thanks for the help
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4474846
07/30/17 04:19 PM
07/30/17 04:19 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Redline is supposed to be one of the best. You could change it or not. I never changed my old Mazda transmission fluid at all in the 115k I had it and my truck got changed at 238k for probably the first time. I'll probably change the oil on my new Mazda at 100k miles.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4474884
07/30/17 05:27 PM
07/30/17 05:27 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
you dont need to change it...but i would have changed it fairly soon after new, just because of break in. i would install redline of the correct weight for sure. seems they really have it together for gearbox lubes. 50k-100k is probably a good interval afterward.
ive installed the appropriate redline in my fusions and my f150s gearboxes...been very impressed.
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4474920
07/30/17 06:05 PM
07/30/17 06:05 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
WOW, you don't drive it much?
I change often, but only because all my manual transmissions are operated at peak torque rating about 50% of the time.
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4475262
07/31/17 06:31 AM
07/31/17 06:31 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Gear oil doesn't go bad sitting idle in the gearcase. Myself, I wouldn't drain it now unless it had water contaimination or was pulling a heavy load all the time.
The "thinking" man's friend.
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4475267
07/31/17 06:39 AM
07/31/17 06:39 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
I would drain it and replace it with:
https://www.redlineoil.com/product.aspx?pid=45&pcid=7
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4475861
07/31/17 05:50 PM
07/31/17 05:50 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Does it look like oil or is it grey from wear particles? If grey and yucky, drive and get it hot for better drain then refill with the redline
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Miles or Time for 5 speed manual gear lube change [Re: SilverFusion2010] #4476166
08/01/17 03:24 AM
08/01/17 03:24 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
If it has gray wear particles present in 31k miles, there's bigger issues going on other than gear oil.
Re: Miles or Time for 5 speed manual gear lube change [Re: MolaKule] #4476665
08/01/17 02:43 PM
08/01/17 02:43 PM
NC
BigD1 Offline
BigD1  Offline
NC
Excellent choice. thumbsup
It's going in my Toyota five speed soon.
Redline a Phillips 66 brand now?
1992 Toyota Pickup--Harvest King Premium 10W-30--Fram PH3614
Re: Miles or Time for 5 speed manual gear lube change [Re: Lubener] #4476946
08/01/17 07:52 PM
08/01/17 07:52 PM
Crawfordville FL
Crawfordville FL
Ex wife did terrible things to cars. I wish I had photos of the [censored] I got out of that transmission...
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4478007
08/03/17 07:21 AM
08/03/17 07:21 AM
KC
badtlc Offline
badtlc  Offline
KC
change based on shift quality for MTFs.
2007 Ford Escape XLS 2.3L ATX, M1 AFE 0W20, Fram TG, 167k
2015 Chrysler T&C, 80k+, M1 AFE 0W20, Fram TG OF
2018 Forester Premium
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4478367
08/03/17 03:33 PM
08/03/17 03:33 PM
Texas
SargeBB Offline
SargeBB  Offline
Texas
'08 Tacoma 5-speed M/T 4x4. Front differential & Transfer Mobil-1 75W-90, Rear end Amsoil 75W-110 and Transmission: Redline MT-90 (75W-90).
Re: Miles or Time for 5 speed manual gear lube change [Re: mtlineman] #4478373
08/03/17 03:38 PM
08/03/17 03:38 PM
Texas
SargeBB Offline
SargeBB  Offline
Texas
I didn't answer the question: Changed differential fluids, transmission & transfer all at 15,000 & again at 90K. 15K rear end fluid was nasty, front end certainly ready for a change, trans. & transfer fluids looked new. All 4 components' fluids looked fine at 90,000, but were changed anyway.
