I had a '93 Corolla 5 speed that started having light grinding between shifts. I changed with multiple brands fluids, no additives and it continued or was worse. 3 shops said it would probably need rebuild. Friend who was BMW mechanic said to try
BG Synchro Shift II. BMW was using it per a TSB for the same issues in some of their cars. I tried it hoping for better but expecting nothing. 3qts was much cheaper than a rebuild.
20 miles later all grinding was gone, under load, high rpm etc. Car shifted great for next almost 100k until it was totaled in accident. I changed it 1x per year after that just because. I'd go for a better fluid rather than an additive IMO. Molacule had listed viscosities of many manual transmission fluids in other threads. I'm currently running GM Synchromesh FM in my Accord and it shifts a better than the factory fluid was.
I had tried some Redline and Ravenol in it prior but didn't like them as much for cold weather. I had tried the BG in my Sonata and it was much better than factory in cold but not as good as Pentosin that they had listed as a TSB for the Genesis in cold. Sonata HATED 2nd gear until fluid was warmer.
