Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
88 registered (2002 Maxima SE, 2015_PSD, 71Chevyguy, 1JZ_E46, 14Accent, 9 invisible), 1533 Guests and 44 Spiders online.
65303 Members
67 Forums
285863 Topics
Page 1 of 2 1 2 >
#4436100 - 06/19/17 05:51 PM Adapter to run a larger diameter filter?
Corelokt Offline
Loc: Tug Hill, NY
Basically I am looking for a plate to make a smaller diameter gasket size base work with a wider o ring, one larger than the base.
I picture a plate with a rubber gasket on the engine side and a flat surface on the filter side. No threads at all.
Edited by Corelokt (06/19/17 05:53 PM)
86 CUCV. 6.5L. Level-3 4L80. NP205. 9-16 14 ply tires, HX35/40 turbo. WMI. 5" exh. ARP studs heads & crank. Cooling upgrades. Rattle can camo.
#4436109 - 06/19/17 06:05 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
4WD Offline
Loc: Texas
I know my MagnaFilter "plate" allows use of various OD filters ... thread must be the same ...
#4436116 - 06/19/17 06:08 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
fdcg27 Online   content
Loc: OH
Whatever for?
17 Forester 12K MSS 0W-20
12 Accord LX 86K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
#4436138 - 06/19/17 06:34 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
goodtimes Offline
Loc: california
That's double the chance of gasket failure, which could lead to engine failure.
#4436157 - 06/19/17 07:01 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
Corelokt Offline
Loc: Tug Hill, NY
Fuel filter.
#4436168 - 06/19/17 07:12 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
Loc: OH
Couldn't you just tap a big boy in somewhere along the line?
95 318i
#4436184 - 06/19/17 07:31 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
Corelokt Offline
Loc: Tug Hill, NY
Just looking for a flat plate sandwich to make the surface wider.
#4436196 - 06/19/17 07:41 PM Re: Adapter to run a larger diameter filter? [Re: goodtimes]
Lubener Offline
Loc: N.Ohio
+1
The "thinking" man's friend.
#4436209 - 06/19/17 07:55 PM Re: Adapter to run a larger diameter filter? [Re: Lubener]
Ducked Offline
Loc: Taiwan
+1
-1.
Fuel filters don't usually cause engine failures. Just engine fires.
And who's scared of them?
Edited by Ducked (06/19/17 07:59 PM)
#4436302 - 06/19/17 09:52 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
Corelokt Offline
Loc: Tug Hill, NY
So what your saying is that an engine that won't run is the safest?
#4436312 - 06/19/17 10:07 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
Gokhan Online   content
Loc: Los Angeles, California
For something like that, you would have to design it and have it machined yourself. It's leak-prone, as you won't be able to change the gasket every time you change the oil filter.
Just research for the largest oil filter that fits and you will be fine. Pick a synthetic one for even better performance.
1985 Toyota Corolla LE, 4A-LC engine, ~ 270,000 M
Toyota (TGMO) 0W-20 SN synthetic
Mobil 1 EP M1-103 filter, 90430-12031 drain gasket
#4437804 - 06/21/17 04:53 PM Re: Adapter to run a larger diameter filter? [Re: Gokhan]
kohnen Offline
Loc: So. Cal.
Why not? When you make it, get a bunch of plate-to-engine gaskets and go ahead and change it. Or, you might be able to seal it to the block by degreasing both surfaces really well, and using a form-a-gasket to glue the plate to the engine.
If you're really adventuresome, you can always JB-Weld the plate to the engine block.
2017 Chevy Bolt
2015 Chevy Volt
#4437812 - 06/21/17 05:04 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
SirTanon Offline
Loc: Phoenix, Arizona - USA
I'm thinking perhaps this thread should be moved to the proper subforum. He's looking for a way to go with a bigger FUEL filter, but has posted this in the OIL filter subforum.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 257,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 55,000mi
#4437814 - 06/21/17 05:08 PM Re: Adapter to run a larger diameter filter? [Re: Corelokt]
4WD Offline
Loc: Texas
Can you post a picture of filter?
#4437892 - 06/21/17 06:55 PM Re: Adapter to run a larger diameter filter? [Re: SirTanon]
He said it was a fuel filter. Perhaps it could be moved to the other-filters or maintenance sections.
I wouldn't mess with fuel filters for obvious reasons mentioned by other posters.
Page 1 of 2 1 2 >
