1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
116 registered members (2009Edge, 64bawagon, 4WD, 240_Ed, 2015_PSD, Altima2, 8 invisible), 2,234 guests, and 65 spiders.
Topics286,399
Posts4,907,608
Members67,614
Most Online2,967
Mar 10th, 2019
Oil Advice: South African Edition #4432146
06/15/17 09:31 AM
06/15/17 09:31 AM
Western Cape
CapeTownWill Offline OP
Western Cape
Hi Everyone,
If you're interested in an oil advice challenge, I think I'm your guy!
I'm having a hard time figuring out what oil I should put into my 2012 Lexus CT200h that's my daily driver here in Cape Town, South Africa, and I'd really appreciate any advice you can give.
The owner's manual (which seems to be written for the American market) suggests
"'Toyota Genuine Motor Oil' is used in your Lexus vehicle. Use Lexus approved 'Toyota Genuine Motor Oil' or equivalent to satisfy the following grade and viscosity.
Oil grade:
0W-20, 5W-20, 5W-30 and 10W-30:
API grade SL "Energy-Conserving", SM "Energy-Conserving" or ILSAC multigrade engine oil
15W-40 and 20W-50
API grade SL or SM multigrade engine oil"
No mention of change intervals in the manual, although the Lexus service person from last year seemed content with changing only once a year. (I bought the car two years ago.)
Some more details about my location and commute. I live a few blocks from a harbor, so there's some sea salt in the air (relevant?). Weather in Cape Town is mild: never below freezing, with an average winter low of 45F (7C), and not very hot with an average summer high of 80F (27C).
My commute is 5 miles (8 km) start to finish (I'm very lucky!). I drive through two quick traffic lights, then I'm on the highway going 55 mph (85 kph) for most of the way, one traffic light then I park at work. Despite the short commute, I probably drive the car hard, with a pretty fast acceleration onto the highway (where I sometimes go more like 70 mph for the first bit before the speed cameras); the highway also goes through pretty significant elevation gain and loss in both directions.
One of the difficulties is finding any of the above types of oil in the stores here in Cape Town. Of the types listed in the owner's manual, I've only found a very expensive Castrol EDGE Professional OE 5W-30 (and I'm not 100% sure that OE is the same as SL, SM, or ILSAC?) and a Castrol GTX 20W-50 API SL/CF mineral multigrade. So a big part of the challenge is to provide advice on oils that I can actually buy here, if you could, please :-)
I think my two main questions then are: given the above driving habits and location in Cape Town, is there an oil available in South Africa that I should I use and how often should I replace it? Or, of the two options I've found so far, which should I use, and how often should I replace it?
Thank you very much for the help!
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432159
06/15/17 09:45 AM
06/15/17 09:45 AM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
For that mild a weather and driving conditions I would think an API 5W20 SN would suffice.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432167
06/15/17 09:56 AM
06/15/17 09:56 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
South Africa has tropical weather, never freeze and can be hot at times.
IMO, you can probably just used 10W-30 and it should be fine.
The number before the "w" is the cold viscosity with lower number means better starting ability in cold weather like below 0 celsius.
I suspect, over there, it will probably will never goes below 20 Celsius so 10 before "W" is not out of line.
  • 2017 Toyota Sienna
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432222
06/15/17 11:13 AM
06/15/17 11:13 AM
Ontario, Canada
MobilinHyundia Offline
Ontario, Canada
I grew up near Capetown and know the weather down there. TGMO 0W20 should be fine but I will go with a 5W30. Castrol synthetic 5W30 will work well too.
I still miss Capetown, one of the most beautifull cities in the world.
RIP......2009 Sonata GL 2.4L (226000km)-QS FS 5W20, OEM oil filter
2009 Sonata LTD 2.4L (170000km)Castrol Edge 5W20,
2018 Sedona SX+ -TOTAL INEO mc3 5W30 with Kia filter
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432226
06/15/17 11:16 AM
06/15/17 11:16 AM
South Texas Rancho
TexasVaquero Offline
South Texas Rancho
Use 10W30 because it's never too hot not too cold.
2014 NISSAN VERSA 5spd M/T- M1 EP 5w30 and M1 EP Filter. 5k OCI.
2011 CHEVY IMPALA 3.5ltrs - M1 HM 5w30 and M1 EP Filter. 3k OCI.
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432236
06/15/17 11:30 AM
06/15/17 11:30 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Another for 10w30. Less vii and has reserve thickness for fuel dilution that is bound to happen with such short trips.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432250
06/15/17 11:48 AM
06/15/17 11:48 AM
Ontario, Canada
Ontario, Canada
Back in '80 I allways use 10W30 in South Afica.
But a 5W30 should be just fine.
Re: Oil Advice: South African Edition [Re: MolaKule] #4432410
06/15/17 02:37 PM
06/15/17 02:37 PM
Balearic Islands , Spain
FordCapriDriver Offline
Finding 5W-20 In South Africa? good luck with that!
Anyway, your car would be served well by a 5W-30,10W-30,0W-40,5W-40, Full synthetic oil.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432461
06/15/17 03:24 PM
06/15/17 03:24 PM
Grand Rapids, MI
ThirdeYe Online content
ThirdeYe  Online Content
Grand Rapids, MI
For a vehicle that never seems to get up to operating temperature, I'd be inclined to go as thin as possible. Either a 20 or 30 grade depending on what you can find in your area.
07 Honda Accord - 614k - Havoline High Mileage 5W-20/Purolator Synthetic PSL14610
98 Camaro Z28 (Bright Purple Metallic, 1 of 104) - 122k - QS Defy 5w30/AC Delco PF46
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432534
06/15/17 05:10 PM
06/15/17 05:10 PM
ME
eljefino Offline
eljefino  Offline
ME
Get us a pic of the shelves at an auto parts store! Just for our culture.
The castrol Edge Professional you mention sounds great. Once a year is also good.
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4432584
06/15/17 06:09 PM
06/15/17 06:09 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Originally Posted By: CapeTownWill
Hi Everyone,
Oil grade:
15W-40 and 20W-50
Pick a 10w-30 and forget about it. If your gonna track it consider a 15w-40.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4433909
06/17/17 02:12 AM
06/17/17 02:12 AM
Illinois, USA
Triton_330 Offline
Triton_330  Offline
Illinois, USA
Oil grade:
15W-40 and 20W-50
I researched the capacity and it's 4.4qts, so buying a 5 quart jug would be the simplest and cheaper way to go. Assuming Amazon can ship to you, here's what I would suggest after reviewing your OP:
Either this:
https://www.amazon.com/gp/product/B01GDRWAB0
Or this:
https://www.amazon.com/Mag-20134-10w-30-Synthetic-Motor/dp/B01GDRWANI
As for your oil filter...
This:
https://www.amazon.com/WIX-Filters-57064XP-Cartridge-Filter/dp/B00FHG8180
Or this:
https://www.amazon.com/Mobil-M1C-154-Extended-Performance-Filter/dp/B004A6HRFG
Hopefully you can have these shipped to you at your location.
~Triton
2001 Ford F-150 XLT 4x4 5.4L V8 ~132k miles
-> PPHM 5w-20 w/Fram Ultra
1989 Chevrolet Camaro RS 5.0L TBI V8 ~48k miles
-> Milesyn SB 5w-30 w/Puro Boss
Re: Oil Advice: South African Edition [Re: SilverFusion2010] #4436722
06/20/17 12:19 PM
06/20/17 12:19 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I really don't think anyone would be a big enough glutton for punishment to take one of these to the track...
Re: Oil Advice: South African Edition [Re: CapeTownWill] #4436834
06/20/17 02:55 PM
06/20/17 02:55 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
Hi Everyone,If you're interested in an oil advice challenge, I think I'm your guy!
Oil grade:
15W-40 and 20W-50
I think my two main questions then are: given the above driving habits and location in Cape Town, is there an oil available in South Africa that I should I use and how often should I replace it? Or, of the two options I've found so far, which should I use, and how often should I replace it? Thank you very much for the help!
First why did you buy an hybrid for such short commute? You'll be driving mostly on your electric motor and your gasoline motor will never reach proper operating temperature, so for this reason I'd go with the lowest viscosity possible. 0W20 will be the best for you IMO.
Re: Oil Advice: South African Edition [Re: Pelican] #4436999
06/20/17 06:33 PM
06/20/17 06:33 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Oil grade:
15W-40 and 20W-50
Actually the engine will not kick off until operating temp is reached, it's not like a plug in hybrid, which would be excellent. But there is truth to the rest of it. The 0w20 however will not make a huge difference as the fuel efficiency is affected by the HSD tranny thingy, and it is temperature (viscosity or not) dependent. Mine will lose a healthy 10+ mpg in the winter, and will only improve during high usage of electric motor without help of the gas engine (ie city, hwy will take longer to warm up it seems).
Either way this bugger will warm up better than your conventional simple gas set up, because it heats up the coolant via exhaust by/in the cat.
Not trying to discredit anyone, just trying to help.
