Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
what happened to merk
by ernied
06/24/18 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
36 registered (Bailes1992, bmod305, Brad_C, billt460, Astro_Guy, bbhero, 2 invisible), 822 Guests and 37 Spiders online.
65317 Members
67 Forums
285954 Topics
Page 1 of 2 1 2 >
#4428872 - 06/11/17 08:17 PM Toro TXP 159cc OHV - oil recommendations?
jbedford Offline
Loc: Stouffville, Canada
Hello,
I just purchased a Toro Super Recycler with the 7.25 ft-lb Gross Torque Toro TXP 159cc OHV with AutoChoke.
Although the shop I bought it from said to change the oil at the end of the season, I though I would be safe and change the oil after the 5 hour break in period the manual recommends. I spent a lot of money on this mower and want it to last.
The manual calls for 0.5L of SAE 30 or SAE 10W-30 detergent oil.
My cars all run synthetic oil... question is should I also run synthetic in my push mower?
What does everyone recommend for lawn mower oil?
Thanks!
Edited by jbedford (06/11/17 08:18 PM)
#4428875 - 06/11/17 08:22 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
spasm3 Offline
Loc: North Carolina
I just bought a lawn boy with a kohler 6.5. After about 2 hours it will get amsoil hdd 5w30.
13 elantra 68k 5w30 QSUD
03 chevy avalanche76k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 3900 miles m1 0w20/0w40 mix
#4428877 - 06/11/17 08:26 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
Bud_One Offline
Loc: Spring,Texas
Any HDEO or Synthetic 10W30 would be more than adequate .
Currently running HDEO 15W40/10W30 in my OPE push and riding mowers.
Edited by Bud_One (06/11/17 08:30 PM)
16 Civic-M1 EP 0W-20, TG7317
14 Civic-M1 EP 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline Conv 5W-30, PH3593A
#4428890 - 06/11/17 08:51 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: spasm3]
jbedford Offline
Hi Spasm3,
I looked up Amsoil HDD and it indicates that it is Synthetic Heavy-Duty Diesel Oil. My engine is gasoline.
Will it hurt the mower to run 5W-30 when it calls for 10E-30?
I poked around the Amsoil site and they make a 10W-30 Synthetic Small Engine Oil.
http://www.amsoil.com/shop/by-product/mo...all-engine-oil/
Is this the stuff I should look for?
Thanks!
Edited by jbedford (06/11/17 08:52 PM)
#4428904 - 06/11/17 09:06 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
spasm3 Offline
Loc: North Carolina
I like it for the zinc. I also like the high TBN. If it will hold up in turbo diesels, it should hold up in my push mower. grin2
This is from the amsoil site;
"Series 3000 5W-30 Synthetic Heavy Duty Diesel Oil is recommended for diesel engines, including those that are turbocharged, gasoline engines and other applications that require any of the following specifications:
API CI-4+, CI-4, CH-4, CF-2, CF, SL, SJ
ACEA A3/B3, E2, E3, E5, E7
Global DHD-1
JASO DH-1
Mack EO-M, EO-N
DDC 93K214
Caterpillar ECF-1-a, ECF-2
Cummins CES 20076, 20077, 20078
Volvo VDS-2, VDS-3 MB 228.1, 228.3, 229.1
MAN 271/3275
MTU Type II "
Typical Technical Properties
AMSOIL Series 3000 5W-30 Synthetic Heavy Duty Diesel Oil (HDD)
Kinematic Viscosity @ 100 ̊C, cSt (ASTM D445)
11.7
Kinematic V
iscosity @ 40 ̊C, cSt (ASTM D445)
70.1
V
iscosity Index (ASTM D2270)
163
Cold Crank Simulator Appar
ent Viscosity @ -30 ̊C, cP (ASTM D5293)
5286
Pour Point, ̊C ( ̊F) (ASTM D97)
-47 (-53)
Flash Point, ̊C ( ̊F) (ASTM D92)
228 (442)
Fir
e Point, ̊C ( ̊F) (ASTM D92)
238 (460)
NOACK V
olatility (ASTM D5800) % weight loss
7.5
High-T
emperature/High-Shear Viscosity, cP (ASTM D5481)
3.5
Four
-Ball Wear Test (ASTM D4172) Scar, mm
0.47
T
otal Base Number
12.1
Edited by spasm3 (06/11/17 09:10 PM)
#4428913 - 06/11/17 09:22 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: spasm3]
jbedford Offline
Wow! That's a lot of technical jargon... Thanks! I will move to 5W-30 synthetic oil when I change my oil. Thank you!
#4428914 - 06/11/17 09:24 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
spasm3 Offline
Loc: North Carolina
I'm sure the small engine oil would work fine too. What i am using is probably total overkill for a pushmower.
#4428927 - 06/11/17 09:38 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: spasm3]
jbedford Offline
Overkill, maybe... but for a few extra bucks, well worth it in my mind.
I appreciate the help! Thanks!
#4428936 - 06/11/17 09:55 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: Bud_One]
Linctex Offline
Loc: Waco, TX
Same here.
Rotella 15W-40 or Super Tech 15w-40 in all OPE.
#4428958 - 06/11/17 10:18 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
NH73 Offline
Loc: Pa, USA
Yes, you can. It will hold well to the heat. 5w30 synthetic is as good as 10w30 conventional, if not better.
For myself, I been using 10w30 PYB in all my unfiltered engines. QSUD 5w30 is in my snowblower. M1EP 5w30 in my zero turn. The zero turn will get M1TDT 5w40 in its next oil change, that I got for a good deal.
Thanks!
Edited by NH73 (06/11/17 10:19 PM)
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
#4429010 - 06/12/17 12:08 AM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
bubbatime Offline
Loc: South Florida
If you run a synthetic 5W30 or 10W30 oil in your car already, then just run what you use in your car.
If your car calls for a 20 weight, and you have to go out and buy oil for your mower, then ANY synthetic 10W30 would be a good choice.
Heavy duty engine oil 10W30 (Rotella, Delo, etc) would also be a good choice. Most of these are dual rated for use in diesel and gasoline engines.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4429054 - 06/12/17 04:11 AM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
mattwithcats Offline
Loc: Virginia
Rotella T5 semi synthetic 10W-30,
or when it becomes available, T6 full synthetic in 10W-30.
Just bagged 20 quarts for a dollar fifty, after rebates and coupons...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#4429213 - 06/12/17 09:43 AM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
CT8 Offline
Loc: Idaho
The mower will not care what oil is run in it just so it meets the specs. Use what you run in the car if it is the proper viscosity. 5W-30 will work fine just keep an eye on the oil level.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4429254 - 06/12/17 10:17 AM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
zuluplus30 Offline
Loc: Fly-over country
Syn 5w/10w-30 or straight SAE30.
#4450656 - 07/05/17 06:20 PM Re: Toro TXP 159cc OHV - oil recommendations? [Re: jbedford]
scudpilot Offline
Loc: Pittsburgh,Pa.
Bought that exact mower, super recycler and have used it twice. After the 5th cut I'm going to run the Amsoil 10w30 small engine oil and change it every season.. had a JD JX 75 for 20 years that I just retired and that's what it got once Amsoil introduced it. Before that Amsoil 10w30 synthetic.
Make safety your first thought-not your last
Page 1 of 2 1 2 >
