Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
35 registered members (ArrestMeRedZ, Bailes1992, AndyB, Atesz792, bmod305, Brad_C, 3 invisible), 652 guests, and 61 spiders.
Topics286,442
Posts4,908,228
Members67,622
Most Online2,967
Mar 10th, 2019
Towing question #4427012
06/09/17 05:38 PM
06/09/17 05:38 PM
MO
FirstNissan Offline OP
MO
Hi, my in-laws have a 2016 Honda Odyssey and are gearing up for a cross country trip. They are planning on towing a small harbor freight trailer with approx 250 lbs of stuff loaded onto it. They are wondering about a transmission cooler and if that is something they should look at before this trip. Any suggestions?
Thank you all and have a good weekend!
2017 Toyota Sienna (Hers)
2017 Toyota Sienna (His)
Re: Towing question [Re: FirstNissan] #4427018
06/09/17 05:44 PM
06/09/17 05:44 PM
PA
copcarguy Offline
copcarguy  Offline
PA
With a trailer that small, it's not necessary IMO.
Re: Towing question [Re: FirstNissan] #4427022
06/09/17 05:49 PM
06/09/17 05:49 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
That's such a small amount of weight, it shouldn't cause problems.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Towing question [Re: FirstNissan] #4427024
06/09/17 05:52 PM
06/09/17 05:52 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
I can't say you need one but having one the right size installed correctly can do nothing but help. That plus an add on spin on fluid filter, too if you install the cooler.
Make sure you stick with Honda fluid and never use anything labeled "Universal". There are some high quality synthetic fluids out there that work just fine but if you're not informed about this kind of stuff and not 100% sure of what you're doing default default back to Honda fluid.
...and everyone knows how to drive carefully and this situation is one of those times. You'll still make it to where you're going even though you'll be a few minutes behind.
And last, get some test drives and visual inspections done before ever considering taking off on a trip. Check the fluid lever exactly as described in the owner's manual.
Don't take anyone's advice that is different from the manufacturer unless your sure you understand all this.
I used a $65 IR gun to check temps on my V8 4Runner after driving with out a load and also towing a loaded horse trailer on a summer day in the desert. I did not install a cooler because the temps using Red Line D4 were right in line with what was expected.
I switched away from Toyota fluid because I was familiar with the requirements and the performance of D4.
Re: Towing question [Re: FirstNissan] #4427056
06/09/17 06:15 PM
06/09/17 06:15 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I think your biggest problem will be remembering its back there. Make sure you can see part of it, as you'll need to back up at some point with it.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Towing question [Re: FirstNissan] #4427068
06/09/17 06:29 PM
06/09/17 06:29 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
What is the Odyssey rated to tow, and how much does the trailer weigh? Agree that they will likely not notice it, since the weight towed will only be the same as 2-3 people.
Thick vs Thin test: 15k / 43k miles complete
Re: Towing question [Re: FirstNissan] #4427082
06/09/17 06:50 PM
06/09/17 06:50 PM
Utah
CKN Offline
CKN  Offline
Utah
The transmission cooler is NOT NEEDED.
Re: Towing question [Re: FirstNissan] #4427087
06/09/17 06:59 PM
06/09/17 06:59 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
No need at all
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Towing question [Re: Kuato] #4427107
06/09/17 07:19 PM
06/09/17 07:19 PM
New England
gathermewool Offline
New England
Deleted
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Towing question [Re: CKN] #4427127
06/09/17 07:39 PM
06/09/17 07:39 PM
Texas
FZ1 Offline
FZ1  Offline
Texas
This^^^^
Re: Towing question [Re: FirstNissan] #4427148
06/09/17 08:04 PM
06/09/17 08:04 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
How about one of those racks that is about 2' x 4' and fits into a class 3 receiver.
Or on the roof.
If they tow the trailer carry a spare tire and maybe a new hub if the bearings fail.
2015 Ford F250 w/Powerstroke
Re: Towing question [Re: FirstNissan] #4427149
06/09/17 08:05 PM
06/09/17 08:05 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Yeah those Harbor Freight trailers are junk. I wouldn't haul one cross country, those bearings fail a lot.
Re: Towing question [Re: FirstNissan] #4427163
06/09/17 08:20 PM
06/09/17 08:20 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
That's a light load but a cooler to keep atf temperatures around 185-200 degrees would never be a bad idea for any transmission.
The "thinking" man's friend.
Re: Towing question [Re: FirstNissan] #4427180
06/09/17 08:39 PM
06/09/17 08:39 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I would recommend installing a cooler if they plan to keep the vehicle for a long time. I have one on my truck and have never towed anything...though I do some light off roading.
I am pretty sure the Odyssey is know for transmission issues, so again, long term I would say it will help a lot regardless if you never tow.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Towing question [Re: FirstNissan] #4427184
06/09/17 08:46 PM
06/09/17 08:46 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
http://pitstopusa.com/i-5077198-derale-heavy-duty-transmission-cooler-18500-gvw.html
Just don't bypass the original trans cooler in the radiator. You WANT the trans fluid to be around coolant temperature. A good trans cooler setup will give you the thermal envelope you want for towing while not overcooling the fluid.
That being said,
That Honda Odyssey was engineered to be able to tow 3500lbs. You are looking at putting a load of less than 750lbs on it. Statistically speaking, you're more likely to have a transmission issue caused by some fault in the aftermarket trans cooler installation (creating fault points of added hose clamps, rubber hoses, decreased transmission line pressure, etc) than you would if you left it alone.
So leave it alone.
too many cars and oil combinations to list in 150 characters or less
