'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
34 registered members (Bailes1992, ChrisD46, ArrestMeRedZ, ctechbob, billt460, Dave9, 2 invisible), 551 guests, and 56 spiders.
Topics286,049
Posts4,901,475
Members67,551
Most Online2,967
Mar 10th, 2019
brake caliper/ pad lube #4412811
05/24/17 01:49 AM
05/24/17 01:49 AM
Wiltshire, UK
bonjo Offline OP
bonjo  Offline OP
Wiltshire, UK
I had been using copper grease on the back of the pads, pins and area surrounding it in the calliper (not the calliper seal)
Is silicon grease a good replacement because of its temperature, low interaction with other materials and lubrication performance?
Re: brake caliper/ pad lube [Re: bonjo] #4412824
05/24/17 03:30 AM
05/24/17 03:30 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Silicone brake lube(recommended) is what I use and does not deteriorate the rubber boots around the caliper pins or the dust seal around the caliper piston. Also helps to reduce the chance of brake noise. Hope this helps.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: brake caliper/ pad lube [Re: bonjo] #4412830
05/24/17 04:12 AM
05/24/17 04:12 AM
Wiltshire, UK
bonjo Offline OP
bonjo  Offline OP
Wiltshire, UK
thanks
those are also my thoughts.
when you say silicon brake lube; is this the same as straight silicon grease?
Re: brake caliper/ pad lube [Re: bonjo] #4412839
05/24/17 04:43 AM
05/24/17 04:43 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Bendix Ceramlube is allegedly the mutts nuts. Bought some but lost it before I could try it out.
There's also "Red Rubber Grease", which is red, and ok for rubber.
Re: brake caliper/ pad lube [Re: bonjo] #4412843
05/24/17 05:07 AM
05/24/17 05:07 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Originally Posted By: bonjo
thanks
Well, I don't know exactly if they're the same which is why I just go for the good stuff. I also don't know what products are available to you in the UK. I use a variety of good name products from companies such as:
*Permatex
*3M Company
*Sil-Glyde
"Retired"
'15 Honda Civic LX
Re: brake caliper/ pad lube [Re: bonjo] #4412858
05/24/17 05:52 AM
05/24/17 05:52 AM
MN
WillsYoda Offline
WillsYoda  Offline
MN
Consensus: silicon lube for the caliper pins (prevents swelling of dust boot and is nice and slippery), anti seize for everything else.
Re: brake caliper/ pad lube [Re: bonjo] #4412915
05/24/17 07:23 AM
05/24/17 07:23 AM
Virginia
Hemispheres Offline
Hemispheres  Offline
Virginia
Sil-Glide
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: brake caliper/ pad lube [Re: WillsYoda] #4412970
05/24/17 08:20 AM
05/24/17 08:20 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
Who's consensus? Definitely not mine. Use only brake specific lubricants that are designed for that purpose.
My favorite is:
https://www.permatex.com/products/lubric...ts-lubricant-2/
Re: brake caliper/ pad lube [Re: WillsYoda] #4412978
05/24/17 08:35 AM
05/24/17 08:35 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
That's what I use, Silicone Paste on the pins and antiseize on the pad edge contact points. I have some Permatex Purple Ceramic grease that I bought before I knew of the boot swelling issue, so I use that on the backs of pads.
I've been thinking about changing it up though. I find that the ears of the pads and the stainless clips get pretty dirty and gritty with the antiseize. I'm thinking about going dry next time, or maybe even trying a super thin film of Silicone Paste.
My favorite is:
GMBoy, I think that's the exact stuff I have on hand. Even though the bottle says it should be perfectly fine, I've heard reports of if causing rubber parts to swell.
This is one of those topics that everyone has a differing opinion on....
Re: brake caliper/ pad lube [Re: bonjo] #4412988
05/24/17 08:49 AM
05/24/17 08:49 AM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I use superlube silicone dielectric grease
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: brake caliper/ pad lube [Re: E150GT] #4413007
05/24/17 09:12 AM
05/24/17 09:12 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
The Superlube is good stuff but it might be a little thin. I use the Sylglide made for brake use.
Re: brake caliper/ pad lube [Re: EdwardC] #4413179
05/24/17 12:33 PM
05/24/17 12:33 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
My favorite is:
I agree and excellent point. I didn't mean to sound harsh. I have not heard of the swelling issue with the purple lube...I may go back to the dark green style.
Re: brake caliper/ pad lube [Re: E150GT] #4413187
05/24/17 12:37 PM
05/24/17 12:37 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
That grease is not designed for the high temps of a brake system. It is probably already melted away.
Re: brake caliper/ pad lube [Re: GMBoy] #4413352
05/24/17 03:49 PM
05/24/17 03:49 PM
MI
doitmyself Offline
doitmyself  Offline
MI
3M silicone paste has a working temperature of -40F to 400F, Dow 111 is also 400F, and SilGlyde is 425F.
The Superlube silicone lists a working temp. of -40 to 500F
Re: brake caliper/ pad lube [Re: doitmyself] #4413575
05/24/17 07:58 PM
05/24/17 07:58 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
Oh Wow! I didn't realize that. I think I still prefer a dedicated brake lube but that sure sounds like it would be a viable option.
