Originally Posted By: bonjo
BTW are the rubber parts these days not made of synthetic material resistance to petroleum based products?
This is a VERY GOOD QUESTION, to which I've never seen a good answer, though I've asked similar questions a few times.
It seems to be generally recognised that you shouldn't use oil-based greases on rubber brake components, and I wouldn't choose to do so, especially on the old cars that I usually drive.
However, I SUSPECT that, since you can't apparently get any brake greases here in Taiwan, mechanics just use ordinary lithium general purpose petroleum-base grease, and I have personal experience of British mechanics doing this on a sticky piston of my 4 ton Renault Dodge truck wheel cylinder, which I found a bit alarming.
This might suggest that you can get away with it, at least for a while, and that while might be long enough, especially here, and especially if it wasn't your car.
I recently asked a related question about the rubber compatibility of greases used on other components like CV and track rod end boots. This was completely ignored, which I find a bit odd considering the endless and largely pointless "what oil should I use" discussions on here.
I don't know rubber incompatability is a problem in those applications, but I can't see why it wouldn't be unless they use more oil resistant rubber than is used for brakes.
I've never seen this discussed, AT ALL, ANYWHERE, apart from by me. I am
the rubber duck in the room.
If it is a problem, it still may not matter as much as the lubricant performance, which might be why it is generally ignored and people go for a molybdenum grease.
I suppose the optimum might be a silicone grease with molybdenum in it. I dunno if this exists but if it does its a fair bet I couldn't get it here.
