Originally Posted By: wantboost
Originally Posted By: Dyusik
Though Lucas will reduce your add pack and your cat will not be poisoned as much I say bump up the grade and leave snake oils behind.
What's a lot of oil, did you try to determine the cause.
lucas is safer? why? what u mean bump up the grade?
I burn 3 qts , car takes 6qts every 3300 miles. I added a catch can. Car has internal pcv system not a pcv valve. I assume its piston rings.....
Lucas is useless and you are trading engine protection for cat protection, and no brainer.
If it's the rings, soak em! B12 Chem tool comes to mind. I just used a blend of atf some thin synthetic oil and gasoline before and worked great. I'd give the new delo a go, 15w is plenty for cali, a 40 wt will give you a healthy bump in thickness. It works great,if not keep looking. It should help with any clogs as hdeo cleans stuff up nicely. 6qts is quite a bit, sounds like you have saturn, I mean problem. I'd look for the issue, as oil thickness is a band aid.
